From the normal time position, press Mode and the AL function will come up which is where you set the alarm. Instead of pressing SET, press the up arrow. Each time you press the up arrow it changes function. When the alarm function is on a little bell appears above the colon in the time. The snooze has a ZZ that appears below the colon.The unique feature of this clock, is that it is the only one I have seen where the alarm works in the time zone selected. Most others, the alarm only works the home time zone, not the selected time zone. This is a huge improvement.
That was a the easy part for me - the big question is "How do you turn the alarm off?" Not Snooze, but literally turn it off so it doesn't ring at the same time every day?
I thought that I had tried every possible combination, but after running through all of the possible key combos, determined that going to Alarm mode, then clicking on the up arrow once turns off the Alarm. No instructions came with the clock and none of the clocks in the store had instructions. It's nice to know that this thing won't be going off in my luggage during the TSA scan!
For mine you had to go to the alarm mode and click the DOWN arrow. Go figure. Not a particularly self evident arrangement but grateful you all got me started in the right direction!
THANK YOU!
Wow, I forgot this was out here. That is the correct answer newmomat48
