FixYa.com
Tags:
Mach Speed VENOM MSA2-6100V Motherboard
Mach speed
posted by guitarwiz301 on Jan 26, 2008
i purchased a mach speed msa2-6100 mother board about 3 weeks ago.i built my comp and it ran great then last night the screen turned off!! i restarted the hard drive spins keyboard turns on and mouse ,but monitor says no signal and my ethernet lite on my dsl is off could someone please help me trouble shoot this thank you
Comment by guitarwiz301, posted on Jan 26, 2008
no im running onboard video,is that what you r askin
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
Thanks for Trying (70)
map9966
Rank:Guru Guru
Rating: 88%, 1056 votes
Unplug the the dsl & any other device except the keyboard & mouse. Double check the video cable at both ends monitor & PC. Boot up system. If the system starts shut down & connect 1 device. Boot the system. OK? continue to do this. On the dsl there is a reset button. With it unpluged from power use a pen & hold in the reset for about ten seconds. Reconnect the power & reconnect the Rj45 to the PC. Boot system.
Comment by map9966, posted on Jan 26, 2008
Did you remove the PCIE card & re-seat it?
Comment by map9966, posted on Jan 28, 2008
Double check your bios setting for the PCIE. You have 2 PCIE slots. If your using only one PCIE in slot1 check that the bios is set to that. Lastly using your manual reset the bios & rest it up.
Got nothing to loose.
Rating Locked! (?) guitarwiz301 has rated this solution as Thanks for Trying
Can you Help with these Motherboards problems?
Motherboards
which mother board to go with
i'm buying 2 visiontek radeon... Answer This...
Motherboards
fredy
nesecito el driver del sonido... Answer This...
Motherboards
urgente¡¡¡¡...
como puedo hacer para... Answer This...
Motherboards
retrouver pilote audio
Carte m?re ASV533MSD+ de... Answer This...
Motherboards
je veut des instrustion
instrustion pour le produit:... Answer This...
Repair Service
Find Motherboard Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
