Question about Hunter Fan Company 5/1/1 Programmable Thermostat
Hunter 44155C Thermostat
I have 4 programming modes to use during the day . I o nly want to use 2 since someone is home during the day. At 530 am I want it to go to 71 degreesand at 11.00 pm I want it to go to 65 degrees. and the same on sta and sun
  • old dummy Oct 14, 2008
    I just,like other postee, just want two temps a day,mon-sun . 66 deg at 5:30 am and change to 62 deg. at 10:pm ,Mon-Sun . Too many programs that are confusing to set . Directions are inadaquate and vague .Tnx
  • 52 Answers
Try calling hunter directly at 1-888-830-1326 to speak with a live support representative. If you are still having problems.
Posted on Jan 29, 2008
Furnace will not turn on even after the thermostat is programed. Thermostat is a Hunter 44155c
5 a. Check the Heat/Cool function switch to ensure it is set to the desired position. 5 b. Wait. There may be as much as a 4-minute delay before the system turns on or off to protect the compressor. 5 c. Check the circuit breakers and switches to ensure there is enough power to the system. 5 d. Replace the batteries. 5 e. If applicable, make sure the furnace blower door is closed properly. 5 f. If your system has 4 wires, ensure the jumper wire is installed between the RC and RH terminals.
Feb 03, 2015 | Hunter Dryers
Bought 44155c hunter thermostat air won't turn on.
If unit worked before you tryed changing t-stat then its possible the t-stat wires are shorting each other out.take t-stat back off cut back wires a good 6 to 10 inches or if you dont have that much wire to play with just cut back as far as you can and make sure there is no bare wire touching each other ,then just to test unit to make sure its working ok twist yell.,red,green together this should bring both units on and should blow cold.if this works up to this point on the new stat read directions closely there might be a jumper wire in the stat that needs connected usually from y1 to w1 you would install a jumper wire .see if this helps if not write back i have 1 other solution.i hope this helps
Sep 14, 2009 | Honeywell Programmable Thermostat Heater
Changing a White-Rodgers 1F56-444 to a Hunter 44155c digital.
The W- terminal is for the HEAT RELAY.
Connect the brown and white wire to the WB terminal which is heat relay of the Hunter thermostat.
Aug 09, 2009 | Hunter Fan Company 5/1/1 Programmable...
Trouble Installing Hunter Brand Thermostat
on the back of the packaging for the HUNTER MODEL 44155C it states that it is not compatible with heat pumps
Mar 01, 2009 | Honeywell Programmable Thermostat Heater
Air and heat have both been running on Hunter 44155C
There should be a switch on the thermostat.
AC-OFF-HEAT
And another switch
FAN ON-OFF-AUTO
Normally, you just set it for heat or AC and set the fan for auto. If it isn't wired correctly, the switches won't make any difference. It will either run all of the time or not at all.
Feb 17, 2009 | Hunter Fan Company 5/1/1 Programmable...
Hunter thermostat need manual
Hi
u can fine your manual here...
http://www.hunterfanhq.com/hiw-prod/orderinv/frames/ps_frame.htm
Gary
Feb 28, 2008 | Computers & Internet
Need help !!
have you tried there web site for the wireing instructions or manual to installing it.
Programmable thermostats at discount prices at
hunter-thermostats.com.
riz.
Feb 17, 2008 | Hunter Fan Company 5/1/1 Programmable...
Installing a Programable Thermostat
give me the wire colors from the white rodgers and how they are connect to the white rodgers .. The white rodgers should be marked on the back where the wires connect. I can then tell you where to hook each wire to on the hunter.
Dec 20, 2007 | Hunter Fan Company 5/1/1 Programmable...
Hunter Fan Company 5/1/1 Programmable Thermostat Logo
942 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
