Question about Toshiba MD14FN1 14 in. TV/DVD Combo
Television Shuts Off
The television will not stay on. After turning the tv on, it shuts off in about 5 seconds. Repeated attempts, and the duration goes down to about 1/2 sec. If I unplug it and let it sit, the next time I try, it's back to 5 seconds, but then decreases again.
  • dan fogarty Jan 28, 2008
    The DVD tray was jammed. The TV recognized this and kept shutting itself off.
  • bartguy03 Mar 29, 2009
    I have the exact same problem. I don't know what "diodes" are, where they are, what they do or how to check them. Any assistance in laypersons terms would be helpful and appreciated.
TRY REPLACING THE REGULATOR OR CHECK DIODES IN SAID CIRCUIT ,ALSO CHECK FOR BAD CONNECTIONS.
Posted on Jan 26, 2008
Mitsubishi VS-50111 Tv does not stay on.Turn Tv on and shuts off after a few seconds.
Aug 06, 2010 | Mitsubishi VS-50111 50" Rear Projection...
Phillips Magnavox Model 20MT1331/17: It shuts off
The poster, Jim K, is probably in possession of at least a layout of the power supply and the 'location' is likely derived from a grid used to physically find parts on a board.
220 uF is a common value for an electrolytic capacitor and the 200V is the rated sustained DC voltage it can tolerate.
The 130 volts could be caused by a capacitor that is failing and not smoothing the rectified voltage as it should.
In other words, you kind of need a tech.
Apr 13, 2009 | Philips Magnavox 42MF521D/37 Television
Tv shuts off, when I turn tv on it will shut itself off, this hap
When it shuts don, the standby light should be blinking a repeated pattern. PLease update this with the count of blinks. That will indicate the circuit that caused the shutdown.
Thanks,
Dan
Feb 26, 2009 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Tv shuts down after about 5 seconds
Sounds like the green CRT has a short.If you unplug the socket from the green CRT tube (the one in the middle) and power up the TV and it stays on then it will verify that you need a new green CRT.
Jan 29, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Error Code 5 flashes when unit shuts down
Good Day;
It sounds like the TV may have a shorted CRT, picture tube, but let's trouble shoot:
1. Unplug TV from wall.
2. Remove speaker grill, two on bottom, the screws are covered with plastic caps, right and left side on bottom next to floor.
3. Remove inner panel.
4. The blue tube is the one the right side, remove socket, with phillips driver, make sure it's not touching anything.
5. Plug and turn TV back on, if picture appears with no blue it's the tube.
6. If still shuts down, bad blue CRT driver IC.
CAUTION: Call a factory authorized service dealer to give you an estimate, if this sounds too hard.
Good Luck, Day, Big Irish.
Jun 18, 2008 | Sony KP-51WS510 51" Rear Projection...
Tv turns self off when turned on
Does it blink a certain amount of blinks pause a second or just blink constantly with no pauses? Let me know it will blink a code if its going into protected shutdown. And it will blink constantly for another reason.
Jan 22, 2008 | Sony KP-53HS30 53" Rear Projection...
Turning on for 2 seconds then shutting off
thats the protection circuit. it detects that the low and or high voltage is not correct and shuts down.
you need a tech .
Sep 04, 2007 | Mitsubishi WS-55315 55" Rear Projection...
Toshiba MD14FN1 14 in. TV/DVD Combo Logo
166 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
