Question about D-Link RangeBooster G WBR-2310 Wireless Router (WBR2310)
Router Troubles I am able to receive an internet connection through my cable modem, when hooked up direct. However, when I connect the router my internet connection is lost???
    Problem Solver:
  • 21 Answers
1. Try turning off your computer,then your router and your modem
2. Then turn on first your modem, your router and your computer
3. If no internet connection still, try reseting the router for 10seconds.
4. Make sure that the local area connection of your computer is set to obtain
5. If still no internet. Access configuration page of your router by typing the gateway of router router in your address bar
> you can check your gateway by typing ipconfig on your command prompt. It is your DG there. (Usually or
6. Make sure that configuration type or connection type is set to DHCP. Then clone your computers mac address.
7. Check your status page.You should have ip address, default gateway and DNS there.
Posted on Jan 26, 2008
My router is not detecting an internet connection when hooked up to my cable modem. However, when my modem is hooked directly to the computer there is an internet connection
Try power cycling the router.
Disconnect the router from all computers and devices.
Power off the router. Power on the router. Reconnect the router to all computers and devices. Check the Internet connectivity.
Mar 01, 2011 | NetGear WNDR3300 - RangeMax Dual Band...
Yesterday had Cable Internet hooked up at new house--when done modem had all lights green, and wireless router connected and worked fine. Now router won't connect to Internet, and USB connection direct to...
Sounds like a problem with your cable connection. Check your coaxial cable, and the splitter from where the cable enters your home. The tech will use a signal meter to measure the quality of your cable, and then replace the wiring if necessary.
Jan 04, 2011 | Motorola Computers & Internet
My computer is not connecting to my Dynex wireless router. I've called my locate cable subscriber and they told me that it's a router problem. I've disconnected the router several times and it shows that...
First off, verify that you can connect to your cable modem directly. After that, hook up your Dynex wireless router and reboot your cable modem. After this, directly connect your computer to the Dynex router (using a cable). If you cannot get an Internet connection, then there is some issue with your Dynex router configuration. It's possible that there might be an IP address conflict with the cable modem. It would be best to contact support for configuring the Dynex.
If you can connect to the Internet with your computer connected directly to the Dynex router, then there must be some router configuration problem affecting your ability to connect wirelessly. You'll have to check the configuration--might be a good idea to completely reset the router and start over. If that doesn't help, you should contact Dynex customer support, as each router has its own configuration specifics. Good luck.
Nov 07, 2010 | Computers & Internet
I hooked up everything right modem to router, router to computer. but i still cant get internet to my computer. if i hook my modem directly to the compiter it works fine but not through the router
Some ISPs (Internet Service Providers) limit you to *ONE* unique computer connected through the cable-modem (or DSL-modem).
Turn the cable-modem off.
Turn the router off.
Connect the cable-modem to the router, via an Ethernet cable to the 'WAN' port on the router.
Turn the cable-modem on.
Turn the router on.
Connect, via an Ethernet cable, from one of the 'LAN' ports on the router to your computer.
Restart your computer.
You should be OK.
If not, telephone your ISP, and get them to trouble-shoot from "their" end towards your end.
Sep 20, 2010 | Linksys Wireless-G WRT54G Router
Modem light keeps blinking Have tried resetting. Restoring to default settings. If I hook the computer directly to the time warner modem I can acces the internet fine. Thanks
If the modem light keeps blinking, it means that the router hasn't been configured yet. Also, rarely, it can be an issue with WAN port/modem port on the router or the ethernet cable connecting the modem to router or finally, modem may not be working as its not applicable in this case(as you said).
How to configure the router for Time Warner?
1.Connect comp.--(gray port) router (yellow port)--modem
2.On the computer, open the router page by typing in the address bar of browser
3.Under Internet Settings, change the connection type as Dynamic.
4.On the far left column, click on "MAC address" under Internet WAN.
5.Click on clone and apply changes and finally check Internet status
6.If internet status > Not connected, we need to do a network power cycle
7.For this, unplug the power from router, then from modem, then unplug the coaxial cable from cable modem.
8. Wait for 10 sec, then connect the coaxial cable, then connect power to modem, wait for lights on modem to get steady, then finally, plug in the power to router.
Now, you may see proper lights lit on the router.
All my best wishes for a fast internet service through the router.
For any advanced help, revert asap!
Thanks and regards,
Jul 04, 2010 | Belkin F5D8236-4 Router
Router Won't connect to internet
The cable modem sometimes register the hardware MAC address of the connected device. So your PC may be registered and it won't accept the router now. Connect the WAN port of the router to your cable modem and power the modem off and on again. It should re-register the connected device and now your router should work.
Jul 30, 2009 | Dell TrueMobile 2300 Router (000001)
Trouble connecting netgear wireless router to rca modem DCM425
First try connection the Yellow ethernet cable from the rca modem to your computer's network connection. If you get a connection this way, then your modem will work with a ethernet cable. If not, then call Comcast for help. The modem ethernet out to computer port must be connected to the wan line of the router. Then you can connect an ethernet cable from your computer network connection to one of the 4 ports of the router. For wireless connections you must set up the router and wireless adaptor with the same settings to connect. Follow the routers directions.
Good Luck
Hooking up a Linksys dual range router to a 2 Wire cable modem
ok once your internet is resolved you shouldnt need to have any computer hard wired to the router but it should go like this cable from your wall to the modem, then cable from modem to the router, after that you can go wireless all the way just make sure that its all secure and encrypted dont want the next door neighbor stealin your internet
Feb 25, 2009 | Linksys Ultra RangePlus Wireless Routr...
Want to hook laptop up to home computer via cable modem
You need a router or a wireless router to do that.
If your cable modem is wireless you can set directly via wireless network a connection with your laptop (the laptop also need a wireless card (if dont have any built in))
The connection must be done in this way
ISP ----->> Cable Modem ---->> Wireless Router o Router ----->> Computer ( 1, 2, or more)
Nov 19, 2008 | Computers & Internet
My destop can't get online
if you previously used the desktop to access the net using a modem, open up internet explorer, then click tools,then connection tab, then tick never dial a connection.
close IE then open it up again and it should connect
Aug 18, 2008 | NetGear RangeMax WPN824 Wireless Router...
D-Link RangeBooster G  WBR-2310 Wireless Router (WBR2310) Logo
75 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
