Remove the bolts that the hold two ends on . mark houseing,scratch one end with a x from end cap to houseing. then the other end with a stright line from end cap to motor houseing so it all stay the way it came apart. ok.remove the end that was the cord or get to it . cut wires long but not to long there is no room in the motor for it. you will need a good pair of crimping plires and rigth size crimps connectors. and some rubber tape or srink tube to cover repaired lines in motor. some motors have bolt /screw to connect to it. make a drawing of the wires on the motor before removing. after repairis made with volt /ohm meter, set to the lowset ohms setting. check each line to see if it connected right. make sure it looks like your drawing .line up ends with reference mark install bolts tight but not too tight. good luck
