Question about Soltek SL-K8AN2E (SL-K8AN2E-GR) Motherboard
Emachines fic vc37 motherboard
When you turn on computer you get 1 long continuos beep and will not boot up.
  1. asssss
Posted on Jan 26, 2008
    Genius:
  • 1,601 Answers
The beep code indicates bad memory.
Here are the charts.
http://www.amptron.com/html/bios.beepcodes.html
  • 1 more comment
  • Thomas Christopher
    Thomas Christopher Jan 27, 2008
    Please rerate to FIXYA.
    thanks
    Thomas Christopher Feb 09, 2008
    blueleaf, Please rerate this as FIXYA, as it answered your problem. Thanks
    Thomas Christopher Feb 13, 2008
Wont start at all
I am not a computer boffin but I recently had one computer that wouldn't start at all and another that was taking half an hour to boot and it was caused by a discharged cmos battery. Some are better without...
Feb 12, 2015 | FIC Vc37gv-l Emachines Motherboard 101647...
K8mc5iglf motherboard diagram
Ah, the old FIC K8MC51GLF motherboard. Made by First International Computers back in the day. Usually used in eMachines desktop computers, and Gateway.
http://www.geeks.com/details.asp?invtid=K8MC51GLF-BO-R
The closest I am able to get to a motherboard manual, is this information,
http://support.gateway.com/s/MOTHERBD/FIC/105554/105554tc.shtml
M - Front Panel Connector
For additional questions please post in a Comment.
Regards,
joecoolvette
May 26, 2012 | Computers & Internet
Start up Beep Beeps ton wy is that? whenn i start
if it is a continuos repeated beep beep sound your hdd cable is loose and if it comes at boot time only it is the sound for ram testing which says ram isok
if a continuos long sound comes and pc doesnot start it is the case of ram fault try cleaning contacts of ram and ram slot with alcohol methyl or spirit or Absolute vodka works best.
Dec 25, 2010 | Intel ASUS P4BGL-VM 845GL Chipset Ultra...
I have an EMachines VL33 motherboard on a T4852 Desktop. I am getting a constant on-off Beep Code when booting at times. Other times it will not boot at all. Do you know where I can get the Beep...
The eMachines T4852 desktop computer has an FIC VL33G motherboard.
(First International Computer {Inc}
Has an Intel 865G motherboard chipset.
Part number on the Northbridge chip is Intel 82865G (Under the Heatsink)
Part number on the Southbridge chip is Intel 82801EB, or Intel 82801ER
http://en.wikipedia.org/wiki/List_of_intel_chipsets#Pentium_4_Chipsets
Maximum Amount of ram memory is 2GB.
Has two ram memory slots.
Maximum Amount for EACH ram slot is 1GB.
Uses DDR Sdram that operates at a frequency rate of 333MegaHertz. (333MHz) {Best}
Also known as PC2700
Socket 478 processor socket.
Can use Intel Pentium 4 processors with up to a 533MegaHertz Front Side Bus. (533MHz FSB)
http://www.weirdstuff.com/cgi-bin/category/110065
(Not advertising, just thought I would throw the above, in)
Has an AGP expansion slot for a graphics card.
Uses AGP 8X graphics cards.
Uses an Award BIOS, date 22.2.2005
Award BIOS beep codes,
http://www.bioscentral.com/beepcodes/awardbeep.htm#
AW, that's what I was going to say!
Ram Memory problem.
Suggest you remove all Ram Memory modules, and clean the gold plated contact pins.
http://en.wikipedia.org/wiki/File:Generic_DDR_Memory_%28Xytram%29.jpg
A) Computer unplugged from power
B) Observe Anti-Static Precautions
C) Clean the contact pins with a pencil eraser.
If you are Not using a solid eraser refrain from letting the metal band touch the contact pins.
Clean each contact pin, both sides.
(184 contact pins. 92 on each side)
Just rub the eraser up, and down on the contact pins. You don't have to scrub them very hard.
After you have finished it may look as though you have done nothing at all.
I assure you that you have.
Doesn't take much corrosion on a gold plated contact pin to make a bad contact surface.
Use air to remove the eraser dust.
If you have a can of compressed air for computers available use it. (Also clean the ram memory slots out with air, if you do)
If a can of air is not available air pressure from your mouth will be sufficient.
Reinstall the ram memory module/s.
Close the computer case, plug the computer into power.
WAIT 1 minute, turn the computer on.
For additional questions post in a Comment.
Regards,joecoolvette
Dec 09, 2010 | VIA VL33-S Motherboard
Need wiring connection diagram for Power Switch to Motherboard for EMachine W2925 model. Wires were disconected accidentally while cleaning inside of tower
micha219, the eMachines W2925 desktop computer uses an FIC motherboard.
First International Computer { Inc }
The Model Number of the FIC motherboard is VC37.
FIC VC37.
Disregard the following if you are aware:
The plastic front of your computer is the Front Panel.
The area on the Motherboard that the cables (Wires) from the Front Panel connect to, is the Front Panel header.
Processor to the Top, Ram Memory slots to the Right, the Front panel header is in the Bottom Right corner.
It is a rectangular shape with two columns of pins.
The length goes up, and down on the motherboard.
The pins on the Right side of the Front Panel header are numbered Odd.
The pins on the Left side of the Front Panel header are numbered Even.
There are 4 pins on the Left side.
There are 5 pins on the Right side.
Starting at the Bottom on the Right side going Up;
Pins 1, 3, 5, 7, and 9.
Starting at the Bottom on the Left side going Up;
Pins 2, 4, 6, and 8.
A) Pins 2 and 4 are for the Power On LED light.
(If after connecting the LED light is dim, reverse the wires)
B) Pins 6 and 8 are for the Power On switch. (Power On button)
C) Pins 1 and 3 are for the HarDDrive Activity LED light.
D) Pins 5 and 7 are for the Reset switch. (Reset button. IF used)
Pin 9 is NC. Not connected
Oct 18, 2010 | E-Machines eMachines Desktop PC
Wiring diagram emachine w2047 motherboard
The eMachines W2047 desktop computer uses an FIC AM37 mobo.
(MOtherBOard)
FIC is First International Computer, Inc.
This link takes you to a page to download the Motherboard Manual, for the FIC AM37 mobo,
http://www.elhvb.com/mboards/OEM/eMachines/manuals/index.html
There is a version 1, and version 2 of the AM37 motherboards.
[ FIC AM37v1, and FIC AM37v2 ]
Click on the appropriate file name, or click, and download both of them. (One at a time)
These are PDF files.
The computer you are on now has Adobe Reader on it, which uses PDF files.
(All you have to do is left-click on the file name)
I would also suggest upgrading to Adobe Reader 9.3.4. ,if you don't have it already.
Give the file time to download. It may take up to 30 seconds before you see the first page.
It may also take additional time for the file to fully download.
Would appreciate it if you would rate my solution if it has helped you.
Post additional questions in a Comment.
Oct 05, 2010 | Computers & Internet
The screen doesnt come up
The beeps[s] usually signify either improperly seated/bad RAM, or improperly seated or bad graphics card. Try reseating these and reboot, if it still beeps then try removing the video card & reboot. If it does boot that way then you know it is a bad video card rather than bad ram. Hope this helps & please remember to rate my answer. Thanks.
Jan 22, 2009 | Gigabyte GA-K8U-939 Motherboard
FIC FR33E long beeb ?
Take out your memory modules and reseat them. One of them may not be in all the way.
AWARD BIOS BEEP CODE ERROR - 1 Long Beep - Memory Problem (Module not seated well)
May 15, 2008 | FIC FR33E Motherboard
Booting problem
try these two alternatives:
1.try to clean or change the slot of the memory
2. check on th power supply you put on your motherboard for the new board there are the socket for the power to be placed on the otherboard
Dec 22, 2007 | Biostar P4M890-M7 Motherboard
Boot beeps
re check all inserted pci cards and all memory, reseat if necassary. Have you recently upgraded anything, if so remove. Continuos beeps can also indicate processor power failure.
Mar 19, 2007 | Soltek SL-65KV2-T Motherboard
Soltek SL-K8AN2E (SL-K8AN2E-GR) Motherboard Logo
731 people viewed this question
Top Soltek Computers & Internet Experts
clar4444
Level 1 Expert
Paul Bade
Iqbal Husain
Iqbal Husain
Are you a Soltek Computer and Internet Expert? Answer questions, earn points and help others
