Garden Logo
Posted on Dec 24, 2009
I need a replacemet bulb for a snowblower headlight, where do I get it?
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Jan 09, 2012
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
147
Points
0
I haven't actually tried to swap mine out yet, but that REALLY looks like a Sylvania 890 fog lamp.
NEED to change daytime running lights
YOU NEED TO RAISE THE HOOD,YOU HAVE TO REMOVE HEADLIGHT HOUSING BY TWISTING THE HEADLIGHT HOUSING MOUNTING RODS OUT OF THEIR CLIPS AND PULL UP THEM STRAIGHT UP TO DISENGAGE THE HOUSING FROM VECHICLE. WITH HEADLIGHT HOUSING OUT VECHICLE REMOVE LIGHT BULBS, YOU NEED TO WEAR CLEAR PAIR OF LATEX GLOVES WHEN HANDLING NEW HEADLIGHT BULBS BECAUSE HEADLIGHT BULBS ARE HALOGEN BULBS OILS FROM FINGERS OR HANDS CAN CAUSE HALOGEN BULBS OVERHEAT AND BLOW OUT.HALOGEN BULBS VERY EXPENSIVE THEY COST FROM $10.00 UP TO $20.00 OR MORE SO WHERE CLEAN GLOVES WHEN HANDLING BULBS.
3helpful
How do you replace the headlight on a 2002 Daewoo Lanos
Hi there, together with providing you the solution to the problem, I also took the liberty of going one step further in giving you steps on how to remove the headlight bulb.
  • Find the hood release handle and activate it, the hood should pop open.
  • Once the hood is popped open locate the hood secondary or safety latch and release it. Then finish opening the hood.
  • Locate and remove mounting clips for any plastic shields that cover the headlight lens mounting screws or clips.
  • Some headlight bulbs can be replaced by simply grasping the bulb socket behind the headlight lens and turn it counter clockwise to remove it. This will expose the headlight bulb.
  • If the headlight bulb socket is not accessible the headlight lens may need to be remove or obstructions behind the bulb removed to gain access to the headlight bulb socket.
  • To remove the headlight lens remove all mounting screws and clips that hold the headlight lens in place.
  • After the headlight housing has been removed from it's mounts, release the headlight bulb from the headlight lens housing (turn counter clockwise) the bulb will then come out of the headlight assembly. Once removed, visually verify that the replacement bulb is exactly the same as the failed bulb before to ensure a proper repair.
  • Clean the headlight lens free from all debris to help maintain the seal from the bulb to the lens. This will keep moisture out of the lens.
  • Install the new headlight bulb by turning the retainer ring or bulb clockwise.
  • Re-install the headlight lens housing and reinstall electrical connector.
  • Re-install plastic covers.
After the job is complete turn the ignition key to the "on" position and activate the headlight switch. Observe the newly replaced headlight bulb to ensure proper operation.
Glad to be of help!!!
3helpful
Once I remove the nuts and bolts, I can't get the headlight to move
  1. Before servicing the vehicle, refer to the Precautions Section.
  2. Disconnect the negative (-) battery terminal.
  3. Loosen the mounting bolts and nut of headlight assembly (A).
    Loosen the mounting bolts and nut of headlight assembly (A)-Santa Fe
    Loosen the mounting bolts and nut of headlight assembly-Veracruz
    Click to Enlarge
  4. Take care that retaining clip (A) is not to be damaged-Santa Fe.
  5. Disconnect the headlight electrical connectors.
  6. Remove the headlight assembly.
  7. Remove the headlight bulb:
    • Remove the headlight bulb(s) with a counterclockwise turn-Santa Fe.
    • Remove the headlight bulb after removing the bulb caps (A)-Veracruz.
      Remove the head lamp bulb(s) with a counterclockwise turn-Santa Fe
To install:
  1. Install the headlight bulbs.
  2. Install the headlight bulb caps-Veracruz.
  3. Connect the headlight electrical connector.
  4. Install the headlight assembly.
once bolts out lift up on the headlight unit hope this helps plz vote comment reply if you need more help
Need to replace headlight bulb 2007 hhr
H13 HALOGEN HEADLIGHT BULB, SOLD INDIVIDUALLY -- Low 55/high 65-watt halogen bulb; 12.8 volts; P26.4t base; A high quality, direct fit OE replacement headlight bulb
How to Replace a Headlight Bulb
(DIY Complexity: Easy / Time: 0.9 hour)
Parts:
1. Headlight Bulb
Tools:
1. Screwdriver
2. 1/4 in. Drive Ratchet
3. Socket Set
Steps:
Step 1 Open the hood and locate the headlight assembly.
o Tip: Most headlight assemblies have a place in the rear to gain access to the headlight bulb.
o Tip: It is recommended that headlight bulbs are replaced in pairs.
o Tip: Always make sure the struts on the hood can fully support the weight of the hood so that it does not close on you while working. The use of a hood prop can securely hold it in place.
o Tip: Safety Tip:Always wear safety glasses when working on your vehicle. Wear other personal protective equipment (PPE) when necessary, for example latex gloves or safety shoes.
Step 2 Gain access to headlight bulb.
o Tip: It is a good idea to check the high beam and low beam headlight bulbs at this time.
Step 3 Disconnect the wiring harness and replace the old headlight bulb with a new one.
Step 4 Turn on the headlights and check high and low beams to verify repairs.
Hope this help (remember rated this help). Good luck.
19helpful
2answers
Changing the headlight bulb in 2003 dodge grand caravan
1) open the hood.
2) Carefully remove the three screws holding the headlight assembly in place.
3) Carefully slide the headlight assembly out. At this point you can replace the headlight bulb, turn signal bulb, or the entire headlight assembly. To replace the headlight bulb turn the collar holding the bulb in counter clockwise. Pull the bulb out of the headlight assembly. Replace the bulb. Insert the bulb into the headlight assembly insert the collar and turn clockwise until it locks. (Do not touchglass with your fingers or it will cause the bulbs to catastrophically fail - clean with alcohol pad if you touch the glass)
4) Carefully insert the headlight assembly back into place.
5) Replace the three screws removed in step 2 being careful not to over tighten.
2helpful
I have a homelitejacobsen 320 snowblower i replaced the primer bulb with one that has a single line running to it after it starts gas starts squrting out of the hole on the primer bulb how do i stop this
You need a "wet" primer bulb for the Jacobsen / Homelite snowblowers. A wet primer actually pumps gas - not air - a primer bulb with a hole in it was designed to pump air.
If you need a "wet" primer bulb email me and I will tell you where to get one for around $10 - basscatt at hotmail dot com
5helpful
2answers
Need to replace headlight bulb in honda civic 2003
How To Install Replace Headlight and Bulb Honda Civic Sedan 01-03 1AAuto.com
Top Arnold Corporation Garden Experts
Jay Finke
Jay Finke
john h
Are you an Arnold Corporation Garden Expert? Answer questions, earn points and help others
