Question about Sony VAIO FRV37 Notebook
I/O device error DVD will not download software.
I also have a problem with C drive it on has 12 % free space and will not defrag. I have deleted and moved files to D drive to free up space and it just does not free up space.
My C drive has 15 GB and D has 35 GB but it uses C drive I think the partition is backwards.
    Genius:
  • 1,601 Answers
Try running scandisk first and then defrag in safe mode.
Please let me know how you make out.Thanks.
Posted on Jan 26, 2008
Is it ok to defragment my 2T goflex portable hard drive?
Yes. Defragmenting simply takes the pieces of empty space on the drive and groups them together. When you delete data from a drive or it is deleted as part of a program's function (such as deleting files only needed during installation) it leaves a blank space, but files are lined up on the drive. So if the files are like so:
2GB File ' 3 GB File ' 5.5 GB Free Space ' 1.5 GB File ' 4 GB Free Space
Then defragmenting would try to rearrange the files like so:
2 GB File ' 3 GB File ' 1.5 GB File ' 9.5 GB Free Space
So, in short, yes, it's okay to defragment your drive.
Mar 08, 2013 | Seagate FreeAgent GoFlex Desk Desktop...
Tip
Maintain Your Hard Drive.
Your hard disk drive is one of the most important parts of your PC. It's where all your system files, applications and user data is kept. Most people understand the issue of security, the importance of making regular backups of your user data as an insurance policy against hard drive crashes. Few people realise and appreciate the importance of having regular hard disk maintenance which is designed to keep it in good working order.
The ultimate way to revitalise and cleanse your PC is to wipe the hard drive, start from scratch and then reinstall the operating system. However, there is much you can do to avoid such a situation arising, simply by using utilities provided within the bundle of your Windows operating system.
Disk cleanup
The Disk Cleanup tool helps you free up space by searching your disk for unwanted files that you can safely delete. It can remove all of the following:
Temporary Internet files.
Files in the Recycle Bin.
Temporary Windows files located in the Temporary files folder.
Optional Windows components that you are not using.
Installed programs that you no longer use.
To launch Disk Cleanup via Start menu go to Start > All Programs > Accessories > System Tools
A dialogue window should now appear enabling you to select the drive you want to clean up. Select the required drive and click OK.
The specified drive will be exampined and the amount of space you can potentially free up is calculated.
The results, showing the amount of space that can be recovered by deleting files that are not needed are then displayed on the Disk Cleanup tab.
Error Checking
Chkdsk.exe is a utility which verifies the logical integrity of a file system. In the event of the utility encountering logical inconsistencies in file system data, it will perform the necessary actions to repair the file system data. The same utility in earlier versions of Windows was called to as ScanDisk.
To Launch Chkdsk go to My Computer and right-click the hard disk you want to have checked. Then click Properties and select the Tools tab.
Click on Check Now.
A dialogue box showing the Check disk options is displayed.
Select the appropriate options and click Start.
You may get the following message.
If so click Yes and your computer will reboot and then perform the scan.
Disk Defragmentation
Since files are constantly being written, deleted and over written to the hard drive, files are likely to become fragmented and scattered all over the drive. The disk defragment tool takes these files and puts them in order by eliminating spaces between files.
To start the disk defragment tool go to Start > Programs > Accessories > System Tools > Disk Defragmenter
Then select the Tools tab and click Defragment Now.
It should now display the hard drives showing total capacity as well as the free space of the drive(s).
Now select the drive you want to defragment and click Analyse.
The drive is scanned and a visual representation of how it is currently fragmented is displayed.
Depending on the the results of the analysis, you will be advised as to whether or not the volume should be defragmented.
Even if it's not necessary, you can choose to Defragment anyway if you like.
The time it takes to defragment the hard drive is dependent on the size of the drive, how the fragmentation lies and how much free space it has.
As the drive defrags you can see how it is neatly repacking the files by looking at the bottem visual bar.
Once it is complete you will get the following message
You can choose to view the report which will show hard drive information such as free space, used space, cluster size and the free space as a percentage. Or you can just lick Close as the defragmentation is now complete.
Doing these checks frequently will prolong the lifespan of your hard drive and make sure it's running at maximum speed.
on Mar 06, 2011 | Computers & Internet
Not enough memory
If you have low memory (RAM) then install more RAM.
If you have low memory (hard disk space) the delete unwanted data files and uninstall unwanted programs.
ALSO
Carry out HARD DISK MAINTENANCE
Hard disk maintenance should be carried once a month to make your computer run efficiently. This removes redundant and temporary files, recovers disk space and speed up hard disk access. Disk Cleanup should be done first - Click My Computer - then right click on the C drive then click Properties, then click Disk Cleanup - let it examine the C drive then it will calculate the amount of disk space it will recover, tick all the boxes to recover the maximum disk space and then Click OK and then Yes to perform these actions. If you have a D drive then repeat these steps on this drive too. Next the C drive needs to be Defrag. This process converts fragmented files into continuous files and this speeds up disk access and makes the hard disk not work as hard. Click on Start - All Programs - Accessories - System Tools - Disk Defragmenter - click to highlight the C drive and click Analyse - then click Defragment. When this is completed repeat these steps for the D Drive if you have a D drive. Disk Cleanup and Defrag can take a long time to complete, especially if these tasks have not been for a long time.
Dec 18, 2012 | Computers & Internet
I need to change my default Download driver to the D drive as my C drive is always full, I've tried to move some of the programs from the C drive to the D drive but it says that some of the files may not...
Try the disk cleanup in the disk properties (right click the disk icon).
You can really free up a lot of space by deleting temp files, memory dump files and all restore point but the last. The last thing you only want to do if your system is running stable of course.
Also make sure to defrag after disk cleanup to maximize the efficient use of the free space.
Dec 14, 2009 | Lenovo IdeaPad Y510 Notebook
It is completely full and is restricting my use of my laptop
You'll need to remove some items from the drive in order to use it. If you can boot the computer reset the Virtual memory to 512 mb, you can access this under performance in the System settings under control panel. Empty the trash can and delete any cookies. After you do these things you should have enough HD space to at least move things around. Your best bet is to get a portable drive or burn to disk and .doc files or files you have created such as pictures or music that don't get used daily basis.This will let you delete them from your HD clearing more space. After doing all of these things you need to do a system Defrag. Once the Defrag is complete you should reset your virtual memory to allow Windows to control it. Make sure you empty your trash can regularly and save files on other devices instead of directly to your HD.
Dec 05, 2009 | Computers & Internet
Hp Pavilion a1620n, XP Edition. I Can't defrag my recovery drive.
Unfortunately you will need to do exactly what it states, which is free up some space. Defragging a drive requires there to be an ample amount of "swap space" available so that it can move files into that 15% of space while it rearragnes the placement of other files and puts them back in an order which will provide faster access to the files after the defrag is complete. being that it is your D: drive, can't you just move some files to your C: drive to make enough space for the defrag??
Please be sure to rate this solution.
Regards,
Joe
May 08, 2009 | HP Pavilion a1620n (RC655AA) PC Desktop
How can i expand my pc memory
There is a free program called ncleaner that I use to free up space on Windows. It properly deletes all unnecessary files on your system, and can also 'shred' the free space on the system, and clean up redundant registry entries. I swear by it. you can download it from here:
http://www.nkprods.com/ncleaner/
Another trick is to go to My Computer > C: > Program Files > Java, and delete older versions of Java. Leave the most recent one (ie the highest number), but when Java updates it doesn't delete older versions, which can increasingly take up space on your hard drive.
I would recommend ncleaner as essential, and the Java deletion method as optional. After you have cleaned the drive and the registry etc. with ncleaner you might be able to get a little more space back by defragmenting the hard drive.
Start > All Programs > Accessories > System Tools > Disk Defragmenter
and then press Defragment. This is something you should be doing occasionally anyway.
Try and keep around 15% of your hard drive free at all times to avoid the system from slowing down and hanging up. You could burn all your media files onto disk, or move them onto a USB stick, and then delete them from the hard drive.
Good luck and Happy Holidays :)
Chris
Dec 17, 2008 | Microsoft Windows XP Professional
Hard drive space needed
Simply buying the external hard drive is one thing. Did you simply plug it in, copy stuff over, or _move_ stuff over? You have to move stuff over in one spot to make room elsewhere. Cut-and-paste is your friend. Do not move programs this way -- just data, like videos, music, photos and word processing documents.
There's a wonderful program called ATF-Cleaner from http://www.atribune.org that can also search your computer for unused files. (Windows has a built-in program, too: click Start: Accessories: System Tools: Disk Cleanup). But the ATF-Cleaner is a bit more thorough, does more stuff. You may be simply wasting a surprising amount of hard drive space on stuff like temporary files that became pretty much permanent. You can also free up some space by deleting old System Restore files and the clike -- look through Disk Cleanup.
Dec 07, 2008 | Computers & Internet
Pc running slow
Hey defraging your HD will not cause you to lose any programs also you may need to do a fresh install. Also have you checked for viruses or mass sypware?
Jul 05, 2008 | Acer Aspire 5050-3242 Notebook
Lossing space on my disc C
you should defrag it, and upgrade to a bigger hard drive. and more momery. Delete programs you dont use anymore. defrag.
Dec 26, 2007 | Computers & Internet
Sony VAIO FRV37 Notebook Logo
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
