Question about Toshiba Satellite A10 Notebook
Replacing ram problem
I only had a single stick of 256MB of RAM so I bought 2 sticks of 512MB. I had no problem replacing the RAM in the slot where the 256 was, but on the other side, i can't get the slot to pop up like the side that had the stick of 256. What can I do? Thanks for your help.
    Novelist:
    Scholar:
  • 108 Answers
Hi....
Assuming you have tried to install the piece you can't get in first (often there are space problems) and after you are sure it's aligned correctly (usually if you put one end into the slot on the clip that holds it in place - if a typical motherboard - and then align it (prior to pressing down) you should be able to get it in by gradually increasing downward pressure (make sure you are pressing straight down and applying equal pressure). The maximum amount of pressure you will have to judge but it should not leave ridges on your fingertips. IOf you have something that weighs 10 lbs and it's on a desktop pushing it with a thumb will give you roughly the maximum amount of pressure to apply.
By the way...with all ram I buy I use memtest32 (available free on the internet...just do a search) to test the ram. This saves a lot of frustration downstream with problems caused by defective ram (corrupted software)....and yes, I can hear you saying but "it's new". I won't go into the detail as to why there is significant bad ram out there but trust me...there is. Hope this helps...Tango
Posted on Jan 26, 2008
Can I install more than 512mb of memory on a Presario s5300nx. I actually want to do 2gb or more. If so, how can i safely do it w/o messing up my computer. Thank you.
> I want to do 2GB or more.
As the Rolling Stones sang, "you can't always get what you want".
See: http://www.memorystock.com/ram/CompaqPresarios5300nxRAM.html
which states that your motherboard has 2 RAM slots, with a maximum of 512MB per slot.
So, how many RAM slots currently are empty, and how much RAM is installed?
If you currently have 2 sticks, at 256MB/stick, you will need to remove both sticks, and install two new sticks.
If you currently have 512MB of RAM, and one empty slot, then that web-page describes the exact type of RAM that you can insert into that empty slot.
Jun 26, 2011 | Computers & Internet
Running a 1 gig stick and a 512mb stick, system only shows 896mb, apparently not recognizing all of the ram installed?
I assume that you've booted the computer with _ONLY_ the 512MB stick installed, and that the computer recognized it (reporting either 512MB or 384MB), i.e., the 512MB RAM is not "defective".
Hmm. 1024 minus 896 is 128.
So, the "integrated-into-the-motherboard" video-card is "stealing" 128MB of your RAM, to be used strictly for "video" purposes, leaving 896MB for Windows to use.
Now, about the "missing" 512MB of RAM.
1. If you have four slots for RAM, and they are physically arranged into two pairs of two slots, rather than four equally-spaced slots, your motherboard is capable of "dual-channel" mode. But, since your two sticks of RAM are not "matched" (size, speed), you _MUST_ insert both sticks into _ADJACENT_ slots (not slots 1/3, nor slots 2/4), in order to run your RAM in "single-channel" mode.
2. If you have two slots for RAM, interchange the two sticks, to see if that makes a difference.
Aug 19, 2010 | eMachines W3507 PC Desktop
Memory won't add on a Gigabyte GA-6VEML
this will be dependant on the bios version. or if the 2 ram modules are identical or not. if they,re a matched pair. the motherboard may not like or run in dual-channel mode. sometimes adjustable in the systems bios. the other suggestion, is to try 1 stick of ram, in each slot individually. This will eliminate A Faulty Slot. Failing any Of The Above. try 2 x 256mb sticks, And Obtain The Latest Bios Update from The Manufacturers Website.
Mike @ Compurepair.
Oct 28, 2009 | Intel Motherboard
Hello, I have a Satellite A15 @129 w/756 MB RAM. I'd like to upgrade but don't know the maximum RAM stick each slot will take and don't remember if there are 2 slots or 4. Thanks, RD
The maximum RAM for this laptop can up to 1 GB DDR1 266MHz RAM and 2 memory slot available, so since u have already 756 MB RAM in your laptop, that mean 1 of your RAM stick is 512MB and another 1 is 256MB, so if u need to upgrade, u have to replace the 256MB with 512MB to make it 1GB maximum.
YBC (/\)
Oct 07, 2009 | Toshiba Satellite A15-S129 Notebook
Total amount of RAM not recognized by computer
are the modules the same specs? you may have some incompatibality between them. the board may be reading the ram right it may be you have four 256 sticks instead of 2 of each. read the motherboard manual it might shed some light here.
Jul 13, 2009 | Computers & Internet
512Mb - 1024Mb Memory upgrade problem
go to controlpanel -settings -hardware manager -search for new hardware. automaticaly your system deduct.it as 1024mb. ok try it allthe best.
Nov 12, 2008 | Computers & Internet
Ram memory Problem?
Go to http://www.memoryx.net and run the 'Identify my computer' bit, clicking on 'Scan my system' and follow instructions.
The other thing is that if the MAX is 512, you'd want low-density memory.
Sep 10, 2008 | Computers & Internet
Installing RAM in VPR Matrix 2250 Desktop
try one stick at a time ,as one may be bad,
also ensure you have them in the slot the correct way round ,as they will not seat down correctly if inserted wrong, take notice of the notch on both ram stick & ram slot.
good luck
Terry
Mar 08, 2008 | Computers & Internet
Toshiba Satellite A10 Notebook Logo
19 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
