Question about Hitachi 50V500 50 in. HD-Ready LCD Television
Lamp replacement My screw is stripped on one side of the lamp housing.. how can i get the bulb out to replace it with new one.
  • preamy2 Jan 26, 2008
    I tried using a bigger bit hoping that would work. Thanks for your help, appreciate it!
  • 211 Answers
You defiantly need to get the stripped screw out. When I encounter a stripped screw, I use my dremil tool with a cutting wheel on it to cut the screw off. After you do finally get the screw cut off ( and this can defiantly be a pain straken ordeal ) you should be able remove the remaining screw bottom with a pair of needle nose pliers. Replace the lamp at that point and find a screw with a bigger diameter ( a serf tapping would work well ) and tread it back. Good Luck. I do know you are in for a frustrating time, but with a lot of Patience, you'le do well.
NC Electronic
Mills, Wyoming
Posted on Jan 26, 2008
  • Ed Meshechek
    Ed Meshechek Jan 26, 2008
    I'm glad you've gotten the problem taken care of. Good Luck
    NC Electronic
    Mills, Wyoming
Need to change passenger side headlight
you might need to move the air filter box to do this.
The bulb and its wiring is on the back of the headlight. Twist the clip to remove it from the headlamp housing, pull the bulb out and replace it, then reinstall the bulb into the housing.
If you need to replace the whole headlight and not just bulb you'll need to remove the grille by unscrewing 4 screws on the top side of the grill Rotate the grill toward the front to release from the clips holding it in place. There are 2 screws on the inboard area of the headlamp. Remove these two screws and the lamp will come out. Now you can replace the lamps or the unit.
Mar 03, 2011 | 2002 Jeep Liberty
Bulb "End of Life" message
for replacing the lamp do yhe following.
1.Remove the lamp cover by pushing two grooves lightly with the flathead
screwdriver. You can see the lamp cover on the top of the projector. ( left side of the lens)
2.Loosen the two screws securing the lamp housing until the screwdriver
goes into a freewheeling condition. The two screws are not
3.Remove the lamp housing by pulling out the handle
4.Insert a new lamp housing until the lamp housing is plugged into the
5.Secure it in place with the two screws.Be sure to tighten the screws.
6.Reattach the lamp cover
7.Snap the lamp cover into place.
Replacing a new lamp automatically clears the lamp usage hours ok
Jan 27, 2011 | NEC MT1060 Multimedia Projector
Rear turn signal b ulb burned out - How to replace
Rear Turn Signal, Brake and Parking Lights
  1. Remove the tail light assembly screws, then the assembly.
  2. Disconnect the twist lock socket from the lens housing. NOTE: To remove the bulb, turn the twist lock socket (at the rear of the housing) counterclockwise 1?4 turn, then remove the socket with the bulb; replace the bulb if defective. Fig. 7: Remove the tail light assembly screws, then the assembly - wagon shown 86816223.jpg Fig. 8: Twist the socket counterclockwise to remove from the housing 86816225.jpg Fig. 9: This type of bulb simply can be pulled out of the socket for replacement 86816226.jpg To install:
  3. Attach the socket assemblies to the back of the lamp unit.
  4. Install the lamp assembly to the vehicle with the mounting screws.
License Plate Light
  1. Remove the lens screws.
  2. Once the lens is removed you, can access the bulb and replace if needed. To install:
  3. Install the new bulb, then attach the lens to the body of the vehicle.
Center High Mount Stop Lamp
  1. Remove the screws securing the lamp cover.
  2. Remove the mounting nuts, then unplug the electrical harness to the lamp assembly.
  3. The lamp now should come out. To install:
  4. Position the lamp assembly to the vehicle, then attach the electrical harness to the lamp.
  5. Install the mounting nut, tighten to 62 inch lbs. (7 Nm).
  6. Attach the lamp cover. Fig. 10: Exploded view of the center high mount stop lamp assembly - wagon shown 86816230.gif
    Fig. 11: Light bulb application chart for all models with non-European headlamps 86816237.gif
    Fig. 12: Light bulb application chart for Buicks with European headlamps 86816235.gif
    Fig. 13: Light bulb application chart for Oldsmobiles with European headlamps 86816236.gif
Dec 19, 2010 | 1994 Buick Century
Headlights removal ford explorer 96
  1. Check that headlamp switch (11654) is in the off position.
  2. Lift hood (16612).
  3. Release latch and swing filler panel to left or right.
  4. Remove electrical connector from headlamp bulb by grasping wires firmly and snapping connector rearward.
  5. Remove headlamp bulb retainer (13N019) by rotating counterclockwise (when viewed from rear) about one-eighth turn and sliding ring off plastic base. Keep headlamp bulb retainer as it may be used again to retain new headlamp bulb.
  6. Carefully remove headlamp bulb from socket by gently pulling straight backward out of socket. Do not rotate headlamp bulb during removal. 7056091.gif
Headlamp Assembly, Explorer
Removal and Installation
  1. Disconnect battery negative cable.
  2. Remove blind rivets (2) attaching screws (4) and radiator upper sight shield.
  3. Remove turn/park lamp attaching screws (2) and pull assembly away from body. Remove bulb sockets from housing and remove lamp assembly. Repeat on opposite side of vehicle.
  4. With turn/park lamp assembly removed, screw attaching grille to front fender flange is accessible. Remove grille attaching screw. Repeat on opposite side of vehicle.
  5. Remove attaching screws (4) located across top of grille.
  6. Grip lower edge of grille and pull outward to disengage from retaining clips. Remove grille.
  7. Using needle-nose pliers, compress barbs on headlamp housing retainer. With barbs compressed, pull forward on housing just enough to disengage from retainer. Repeat on opposite side of headlamp housing.
  8. Turn headlamp housing as necessary and pull forward to disengage from headlamp aiming ball socket.
  9. Disconnect wiring from headlamp bulb socket.
  10. If replacing headlamp housing, remove retaining collar and bulb.
For installation, follow removal procedures in reverse order. Make sure to check headlamp aim. 568a220.gif
Apr 02, 2010 | 1996 Ford Explorer
How do you remove the head lamp assembly on a 1993
1. Make sure headlamp is off and open hood.
2. Taurus model years 1990-1999: you must remove the whole headlamp to replace the bulb. Not a horrible task. Just annoying.
3. Facing the driver's side headlamp, and looking at the headlamp itself, at clock positions 8, 11 and 1 are the headlight housing screws. They all look the same. Using a 10mm socket wrench, remove these 3 screws and set them aside.
4. Just to the right of the "11 o'clock" housing screw is a bolt (same hexagonal 10mm sized top as the housing screws). This just needs a few turns to loosen it.
5. Gently pull the whole headlight forward. Now you can get at the bulb.
6. Disconnect the electrical connector from the bulb. Now the headlamp is free to work with. Remove the bulb, replace with a new bulb, make sure the bulb housing cylinder is in place and reconnect the electical.
7. Place headlamp back into position. Line up screw holes. Tighten the bolt. Replace housing screws and tighten.
8. Passenger side headlamp is mirror image of driver's side. Screws at 11, 1 and 4 o'clock positions. Bolt should be to the left of the "1 o'clock" housing screw.
Oct 12, 2009 | 1993 Ford Taurus
How do you replace a brake light?
serjoijr: To replace the bulb, you must remove the tail lamp housing.
Open the tailgate. There are two screws which retain the lamp housing to the body. You can see them when you open the tail gate, One is near the top and one is near the bottom. They are a phillips head type screw.
Remove both screws and pull the lamp housing directly backwards. DO NOT TWIST IT TO THE SIDE! The housing has a pin on the opposite side which interlocks with the body, keeping it in place on that side.
Once you have pulled the housing away from the body, you will see the lamp sockets and wiring harness. These sockets usually rotate to one side or another to interlock with the housing. Once the socket is removed, you can replace the bulb and return the housing back to the original spot.
Jul 28, 2009 | 2004 Honda Odyssey
Rear blinker light change 2001 ram1500
Welcome to FY
open the tale gate look at the side where the light is there is 2 screw that hold the light to the box
Jan 10, 2009 | 2001 Dodge Ram 1500 Truck 2WD
Mitubishi WD-57732
I'm assuming that you already have the housing out of the TV. If not remove the lamp cover panel (two phillips screws), Locate and unscrew the two chromed flat blade screws that hold the module in place and gently pull the housing out. Now locate the three locking tabs on the housing. There is a large one on the bulb face side, and two smaller ones on the mesh screen side near the handle end. Using a thin bladed screw driver, slide it under the curved edge next to each of the small tabs and gently pry up to pop the side cover off of the tabs. Rotate the back cover (three sided) so that the small tabs come clear of the rectangular holes in the cover. (It should pivot on the third tab). Now use the screw driver to gently pry the U shaped clip off and over the third tab. Once all three tabs have been released the back half should just slide back and off the front half. Reassembly is basically just sliding the back cover back on until the tabs lock into place. While the bulb is out blow all the dust out of all THREE screens (there is a small one next to the greyish metal plate).
Replace the bulb by removing all the internal screws necessary to release it from the housing, noting how everything goes back together, including which wire goes to which terminal (If your bulb does not come with new wires you'll have to swap them to the new bulb), and where the "UP" marking on the bulb goes. Drawing a picture or better yet taking a few pictures is a good idea. When installing the new bulb do not touch the bulb with your bare hands (use latex gloves). Supposedly the skin oils can cause the bulb to fail prematurely. Finally make sure that the wires do not touch the bulb and are as far away from it as possible after it is back together, if necessary open it back up and bend the wires to reposition them.
Nov 14, 2008 | Mitsubishi WD-57732 Projection Television
Lamp out ...
remove front panel under screen, rove screws from lamp access panel cover. then remove the screws from the lamp assembly housing pull lamp housing straight out. install new lamp in the housing and slide the cartridge back into set replace screws and access panel cover.
Apr 09, 2008 | Mitsubishi WD-62327 62" Rear Projection...
Lamp location
No, that was wrong advice. On this model, there is a large door on the right side (as you face the screen) of the TV at the bottom. Remove several screws to take the cover off. Inside, looking along the back of the TV (not toward the screen), you'll see what looks like a wire bail (handle) on a square inset piece about 3 inches square. Remove the screws and pull on the wire bail and the lamp housing will come out with the lamp contained inside. Make sure you unplug the TV before doing any of this. If you are replacing the entire housing with a new lamp you can just plug in the new housing and replace the screws and cover. If you are placing a new bulb in the existing housing you take off 4 small screws and remove the metal cage from the housing, remove and replace the bulb the same way the original is in there, put it back together, and you're done.
Sep 17, 2007 | Zenith E44W46LCD 44" Rear Projection...
Hitachi 50V500 50 in. HD-Ready LCD Television Logo
65 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
