Hi
I've this mainboard, but, owing to a wrong action, a PCI card got off the slot, while the pc was on.
Now all is working, but PCI bus
is 'crazy: ' If I install a PCI card , System doesn't recognize it, or recognizes the card with another driver. I've reinstalled O.S. but with the same result-
What can I do? Have you a schematic of this mobo
Regards
Donald
Sounds like there was possibly a short and some components were damaged.
there is a jumper on the board that you can use to reset the mainboard firmware/cmos. check the manual. i would try that reset procedure and see if there is any improvement.
if that doesnt work it is highly unlikely the board can be repaired - components are way too dense and mainboards are generally considered disposable. depending on your OS it may be possible to force the proper configuration for the card, but even that may be unreliable considering the evidence of damage.
Thankyou, but I've already resetted bios, besides I've also replaced bios chip with the one of another identical working mainboard, but without results.
I'm sure it's a hardware trouble and not depending on O.S.(My PC has dual boot: W7 and XP Pro 64bit). PCI bus is damaged, unfortunately.
Therefore I'm looking for a Service manual, in order to test the card. Smd fuse-resistors (near bus PCI) are OK
Regards
Donald
