Question about Sony FD Trinitron WEGA KV-32XBR400 32" TV
Screen went BLACK!
Volume works, able to change channels... TV picture just went black! Not sure if I did something to the remote control (pushed some button leaning on it?) but can't seem to get a picture back!
  • 1 more comment
  • Anonymous Jan 26, 2008
    The volume works and able to change channel but the screen went black
  • Anonymous Jul 07, 2008
    I was watching the television and the picture went black. I can change the channels and I have sound but no picture. The channel it is on appears on the top of the screen so I don't think it is the picture tube? Any comments.
  • vijaya kumar
    vijaya kumar May 11, 2010
    pls meant if picture completely black or not
My Sony FD Trinitron TV did samething, started flashing, then eventually went completely black with volume. I got on internet searched found a solution, i tried it, it worked. unplug tv, remove all screws, remove back. towards bottom right theres a transmitter with a couple of knobs, we plugged tv in and moved knobs around and it worked. Also was extremally dusty, we used computer duster for a better connection. hope it helps you
Posted on Aug 29, 2008
I do not have the remote to my Hitachi TV and need to change the channel to get picture. How do I manually change the channel if the screen is black.
Look on the TV for buttons for power, volume up and down, channel up and down and menu.You can get a new factory remote from here :
Jan 22, 2017 | Hitachi Televison & Video
No picture, just sound on Etec Flat Panel 40A99
Video circuit is separate from the Audio circuit. The main controller may switch to Audio, but if the unit is damaged from a power outage; part of the circuit board may not function. Needs professional servicing.
Feb 26, 2014 | Cars & Trucks
KDL-32M4000 sony tv screen went black suddenly,
We are having the same problem! Whats the solution!!!?!?!?!?!!!?
Oct 18, 2009 | Sony KV-36FS100 36" TV
Black screen
use your remote then turn off the text messege of your tv.the black screen that you seen is for the messege but since their is no message written in the box ,that's why you see a black box.
Jan 26, 2009 | Mitsubishi CS-40307 40" TV
Pioneer SD-582HD5 - screen went black, no sound, Poor remote feed
The blue tube might be leaking coolant in the high voltage area, that is the cause of the POP. This repair might not be a DIY because of the lethal high voltage surrounding the CRTs tubes.
The slow response from the remote could be because the coolant has affected the main board where the IR signal are going to the remote sensor.
Let me know if you require further assistance.
Dec 20, 2008 | Pioneer SD-582HD5 58" Rear Projection...
BLACK BOX PROBLEMS: Insignia TV/DVD combo
The black box is caused by the Closed Caption option of the tv. Go into the menu and turn it off.
Jul 18, 2008 | Insignia IS-LCDTV32 32 in. Television
Black box appears in TV screen
The problem with the black box happened to me. I had pushed the subtitle button on my remote by mistake. Interestingly enough, as soon as I pushed the SUBTITLE key again, on the remote, the black boxes disappeared.
It also says CC which means closed captioned-- So the bottom on my remote is Subtitle, and then on the subtitle button is cc...
I hope this helps
Jun 04, 2008 | JVC AV-32260 32" TV
Screen goes black after unit is turned on.
Contacted Mitsubishi directly and found out that QV9 on the remote control resets to factory defaults, clearing the Parental lock out someone had put in place. The TV is in a Retirement Home and some of the folks are sneaky about wanting to control the TV in their own fashion. We will be watching the remote a bit closer now!
May 01, 2008 | Mitsubishi VS-50802 50 in. Rear Projection...
Black out screen
I had the same problem once with my RCA television. It only happened on certain channels and didn't happen during commercial breaks. If I adjusted the volume on the tv the box went away, but came back shortly after. The problem ended up being some malfunction in the closed captioning. I turned it all off and changed the CC settings and never had the problem again.
Oct 05, 2007 | Westinghouse W33001 30 in. HD-Ready LCD...
Sony FD Trinitron WEGA KV-32XBR400 32" TV Logo
290 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
