Question about LG CU500 Cellular Phone
MicroSD my microSD is in my phone but whenever i try to get into it, the phone comes up with "card not ready". what do i do?
    Problem Solver:
  • 14 Answers
You must use a memory card of lower memory.
Posted on Jan 31, 2008
6ya staff
SOURCE:
Why can't I send or receive picture messages?
Why dont you go to the store and ask them to help. Is it the same model, newer model. Google the problem
Jul 08, 2014 | ALCATEL-LUCENT USA INC One Touch Fierce 4...
Memory card wont stay in my phone. whenever i push my memory card into the slot it just comes back up
Perhaps it has a latch mechanism - you have to push it a bit deeper inside, and then it will latch into place. To remove, push it again deeper and it will pop out.
If it's not the case, perhaps your socket is a bit worn out, and/or the card is thinner then usual - you can try to increase the friction by applying some self-stick paper or tape on top of your card to make it a little bit thicker.
Dec 03, 2009 | SanDisk 2GB microSD Memory Card
Cant save anything on my or memory card
Dont know if this will work , but try formatting your memory card...
Sep 02, 2009 | Nokia E71 Smartphone
MicroSD card problems
Try letting the phone format the card. 1) Backup the music files you already have on the card. 2) From your computer, right click on the drive representing the card and re-format the card. 3) With the phone turned off, insert the card into your phone. Power on the phone and follow the steps to have your phone format the card. 4) Now copy the files back to the card using your computer.
See if that does the trick. If not, try performing the same steps as above, but instead of re-formatting the card in your computer, go into disk manager and delete the MicroSD card's partition (be careful that you select the correct drive representing your MicroSD card). When you re-partition the card, uncheck the "format" option, which will leave the card unformatted. Then let your phone format the card.
Good Luck!
Aug 13, 2009 | Samsung SGH-P850 Cellular Phone
How do I insert the microSD Card into my Motorola adventure V750?
1) How to/where to insert microSD card
  • Pop the back off of your V750.
  • The bottom half of the phone has a rectangular indentation with a metal port on the left end of it; slide your microSD card face-up into that slot.
  • Replace the back of your phone, making sure that the little tabs on the side of the backing clip into your phone.
  • Your phone should automatically detect and format the card, but you might have to restart it first by holding down the "End Call" button until it shuts off, then hitting it again to turn it on.
2) How to download music from Windows Media Player to SD card
  • Find a USB cable that has a male microUSB end to it; the two ends will look like this: (click link). You should be able to find this at RadioShack, Walmart, Best Buy, Staples, etc.
  • Plug the USB end into your computer and the microUSB end into your V750. The first time you do this, Windows will probably have to set it up as new hardware; just wait until it says that your hardware is "Installed and ready to use." (You may even get an Auto-Play menu giving you the option to Sync with Windows Media Player; if so, choose this option.)
  • Open up Windows Media Player (WMP) on your computer.
  • On your V750, go to "MENU" -> "MEDIA CENTER" -> "MUSIC & TONES" -> "Sync Music".
  • Wait for your phone to set itself up with WMP; it'll be ready when the phone's screen says "Connected." WMP should automatically switch over to the "Sync" tab with your phone (and the amount of space used/available on the microSD card) represented in an area on the right side of the screen.
  • From here, it's a simple matter of dragging and dropping songs (single songs or whole collections by album, artist, genre, etc) into the phone area. Just keep an idea on the space indicator to make sure that you're not loading too many songs for the microSD card to hold.
  • When you're done picking songs, just hit the "Start Sync" button at the bottom of the sync list. All of the songs will be transferred over to your phone, and you can watch the progress either on your phone's screen or the WMP Sync screen. You'll know it's done when the V750's screen just says "Connected" again.
  • Like the instructions on the phone say, press either "CLR" or the "End Call" button to exit the media player, then unplug the cable. Your songs are now loaded onto your phone.
Jul 11, 2009 | Motorola Mobility RAZR V3c Cellular Phone
I CAN`T PUT MUSIC IN IT
Make sure that the microSD card is formatted. You may reformat the memory card using your phone and then try saving some music.
If that will not do any help, try using another microSD card to see if the card is defective.
Have a great day!
Jun 19, 2009 | PNY 2GB microSD Memory Card
Im trying to transfer pictures from my computer onto my phone
You can try to install the CD that comes with your phone to your computer, then you can connect your phone using the usb cable provided. Then you can have an access to your phone's memory, this way you can transfer data to both ways. But, since LG systems have usually problems in this usb transfers (According to the most of the users, may depend from model to model also), you can simply transfer your pictures from your computer to your microSD card (your phone has an SD card, and you can plug that microSD in a card reader using a SD adapter), then you can plug your microSD card back in your phone, and then you'll have your pictures in your phone.
Apr 14, 2009 | LG KU990 Viewty
HELP..... new micro sd card for phone... wont allow me to view the photos
I have the same sandisk microsd card, comptible with my cell phone. Didn't have any problem, you must insert the card in your cell phone properly... pushed all the way into the slot...it took me just a second to view them in my pix album in my cell phone....
hope this helps....
Jul 09, 2008 | SanDisk 1GB microSD Memory Card
Can't power up or off.
i just brought it to verizon and they gave me a new phone
Oct 05, 2007 | LG enV VX9900 Cellular Phone
LG CU500 Cellular Phone Logo
37 people viewed this question
Top LG Cell Phones Experts
William Norris
William Norris
Sheldon Dedek
sheva420
sheva420
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
