Question about Canon PIXMA™ MP830 All-In-One InkJet Printer
Cannot copy Error message: scanner not operating correctly
I cannot copy using my canon copier
Posted on May 13, 2008
WHAT IS ERROR E046 CANON SCANNER
E046 Main drive PCB
(Controller CPU judgment)
If a communication error occurs between
the motor or sensor and PCB, an error
message appears. If it appears, reset the
main body and computer power. If the same
error message/code still appears, check the
connection of the related part, and if it is faulty,
correct it. If there is no problem with connections,
replace the related part. For motors,
check the connected drive transmission parts
and operation check sensor as well.
May 12, 2014 | Canon Dr-7550c Color Duplex SCSI-Iii USB...
Scan error 0x80210001
If you are only have this issue when using Scanner and Camera Wizard then this would be an issue with your operating system, and you will need to contact Microsoft. If you are able to scan using the HP software or MS Paint then the printer is working correctly.
Oct 11, 2013 | Samsung SCX-4300 Series
Unreadable message error
That is a driver problem. You need to install the correct drivers for your operating system. Visit the Panasonic download page for the correct drivers.
Regards,
MyEfact
Jun 30, 2010 | Panasonic KV-S3065CL Path-Through Scanner
States scanner failer; turn off ;then on; have
Solution one: Check the scanner light Make a color copy of any document by pressing the Start Copy Color button on the product control panel. While the product is making the copy, lift the scanner lid slightly to see if the scanner light is visible. CAUTION: Do not look directly at the light. It is not necessary to completely open the lid to see the light.
  • If the scanner mechanism moves across the scan bed, but the light is not lit, proceed to Solution six: Service the product .
  • If the light is lit, proceed to the next solution.
Solution two: Check operating conditions Extreme temperatures can affect the operation of the product. Make sure the operating conditions match those recommended in the User Guide provided with the product. Solution three: Check the power connections
  1. Make sure that the part number on the power supply matches the part number listed in the User Guide .
  2. Disconnect the power cord from any power strips or surge suppressors, and then plug it directly into a wall outlet.
  3. Try making a color copy by pressing the Start Copy Color button on the product control panel.
    • If the copy job is successful, you do not need to continue troubleshooting.
      NOTE: Power strips and surge suppressors can sometimes prevent enough voltage from reaching the product.
  4. If the error message displays again, temporarily move the product to a different room, or plug the power cord into a different wall outlet.
  5. Try making a color copy by pressing the Start Copy Color button on the product control panel.
    • If the error message displays again, proceed to the next solution.
Solution four: Perform a power cycle
  1. Turn the product off.
  2. Unplug the power cord from the product.
  3. Wait 30 seconds, and then connect the power cord to the product.
  4. Turn the product on.
  5. Make a color copy by pressing the Start Copy Color button on the control panel.
Solution five: Reset the productFollow these steps to reset the product. Step one: Perform a partial reset
  1. Disconnect the power cord from the product.
  2. Press and hold # and 3 while reconnecting the power cord to the product, and then release both buttons.
    • If the partial reset resolves the issue, you do not need to continue troubleshooting.
    • If the error message displays again, proceed to the next step to try a semi-full reset.
Step two: Perform a semi-full reset CAUTION: Performing a semi-full reset deletes any saved phone numbers on the product.
  2. Press and hold # and 6 while reconnecting the power cord to the product, and then release both buttons.
    • If the semi-full reset resolves the issue, you do not need to continue troubleshooting.
Solution six: Service the product If you have completed all the steps listed above and are still experiencing a problem, service the product.
Jan 26, 2010 | HP OfficeJet 7410 All-In-One InkJet...
When running Epson Scan setup i receive error message "could not copy files. Check the setup disc then run setup again". It then reference a path to the local settings empsetup.exe. Running window xp
I dont see any bulletins about this issue. You might have a corrupted CD.
Try downloading the software from Epsons website, and make sure you download for the correct operating system.
what operating system are you using?
Dec 16, 2009 | Epson Perfection 4490 Film / Flatbed...
CANON PIXMA MP830 Error Msg: Scanner not working correctly.
the error message: "Scanner is not operating correctly." The scanner is definitely unlocked.
Nov 07, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Canon PIXMA MP830 Error Message: Scanner is not operating correctly.
This problem sucks. It sounds like the scanner has actually gone bad. This can be a couple of things. The actual ccd unit inside the scanner, a position sensor, a motor or a wire harness.
The latter two are fairly unlikely, the first two more likely. Most probable is the CCD unit. I don't think Canon sells it as a separate piece, but it comes inside a replacement scanner assembly. These complete scanner units are expensive. You'll have to check with your local Canon shop to see what they cost.
Nov 06, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Scanner failure message.
Scanner Failure, Power Off and On' Message Displays on the Control Panel when Copying or Scanning
Issue
The message 'Scanner failure, Power off and on' displays on the control panel of the product.
This error usually occurs when trying to scan, to make copies, or during the product start up.
Try the solutions in this document until the issue is resolved. It is not necessary to continue to the next solution if one solution resolves the issue.
Make a color copy of any document by pressing the Start Copy Color button on the control panel. While the product is making the copy, slightly lift the scanner lid to see if the scanner light is visible.
If the scanner mechanism moves across the scan bed, but the light is not lit, click here to service the product .
1.
Make sure that the product is connected directly to a grounded wall outlet and not plugged into a power strip.
2.
3.
If the error message persists, temporarily move the product to a different room or outlet, and then make a color copy by pressing the Start Copy Color button on the control panel.
4.
Check the part number on the power supply to make sure that it matches the part number listed in the User Guide.
1.
2.
3.
Wait 30 seconds, and then reconnect the power cord to the product.
4.
5.
1.
2.
Press and hold # and 3 while plugging in the power cord.
3. Make a color copy of any document by pressing the Start Copy Color button on the control panel.
If the partial reset resolves the issue, do not continue to the semi-full reset.
CAUTION: Performing a semi-full reset deletes any phone numbers that are saved on the product.
1.
2.
Press and hold # and 6 while plugging in the power cord.
Mar 05, 2008 | HP OfficeJet d145 InkJet Printer
Scanner 3770 hardware problem
Hi, it is possible that your scanner has a transport locking lever or knob underneath which might have been keeping the carriage locked in place. Try checking and release if there is one. Hope this works for you. Pls post again how things turn up. Good luck and kind regards.
Jul 30, 2007 | HP Scanjet 3770 Flatbed Scanner
Canon PIXMA™ MP830 All-In-One InkJet Printer Logo
60 people viewed this question
old marine
old marine
