Question about Sony KP-57WV600 57" Rear Projection HDTV-Ready Television
Blown internal sony tv speakers
I am just trying to turn off the internal speakers on my sony tv since they are blown and now that I have rca plugs hooking up my 5 piece surround system. can you let me know if it is possible to shut off the internal tv speakers only?
  • Anonymous Mar 27, 2014
    I have a toshiba HD 57H83 and have hooked an Apple Tv(3rd) to it. Great picture but no sound have attempted to adjust speakers internally with no sound Satellite sound works fine also have an older RCA surround sound hooked up to it RT2250B work fine on satellite and with DVD hooked to it also unfortunately everything I have tried has failed any suggestions would help
    Problem Solver:
  • 7 Answers
In menu(button on remotr) ,,scroll right to audio ..scroll down to speaker and turn them off!
Posted on Jan 26, 2008
    Guru:
  • 377 Answers
Hi dear ....
the insruction you receive it enough i think,,
oke
i hope your problem solved
cropp
Posted on Mar 20, 2008
Set won't turn on. Was working fine last evening. Now nothing.
Reciever RCA RT2500 ' Techlore
www.techlore.com/forum/thread/11889/reciever-rca-rt2500
Aug 20, 2005 - 31 posts - ‎23 authors
hey ive got the rca RT2500 home theater system. .... won't power up) regardless of number of times I try to simulate a 120 V power flash (pulling plug .... My RCA receiverturns on but there is no sound...what can this mean?
Trouble getting sound from home theatre system with my ...
www.tomsguide.com/.../trouble-sound-home-theatre-system-appreciated....
Mar 27, 2013 - TV: Sony Bravia KDL-60EX645 Home Theatre System:RCA RT2906 ...-I've set the television, per the manual's instruction, to "Audio System" and "Audio Out: Fixed." This should allow the TV to turn off its internal speakers and switch .... SolvedI have F & D home theatre system, my rear speakers won't work.
Problems connecting surround sound to LCD TV... - Forums - CNET
www.cnet.com > Forums > TVs & Home Theaters
CNETJul 30, 2006 - Hey I have a 26" LCD TV from Polaroid and a Philips DVD home theatersystem. ... the Audio setup on the tv and TELL it to output the sound via the RCAcables ... However, you would normally turn off the TV speakers with a menu ... I just can't figure out why the TV audio won't play on the surround sound. Anynet+ - Home theater won't turn on with tv
Jun 11, 2015
TV won't turn on
Jun 10, 2015
Audio Return Channel Problem
Aug 23, 2011
rca tv no sound?????
Jan 1, 2006
More results from www.cnet.com
Jan 19, 2016 | RCA Audio Players & Recorders
Where is the internal speaker off/on switch or control on RCA 24V414T
It is possibly a selection that can be made as part of initial set up but without a remote you won't be able to make that selection.
Mar 17, 2014 | Sony Televison & Video
Connect skytec subwoofers passive speakers
Be sure the sub pre-out is intended to drive a powered sub (RCA to RCA). Is there a sub power indicator on? If not, there may be a blown internal fuse. Also some custom speaker configurations such as speaker size can override what you think you want to do.
Feb 01, 2014 | Pioneer Audio Players & Recorders
Sentry 2.1 surround sound speaker system. i have my rca cords plugged in to my tv, but i only get sound from my tv, nothing out of the speaker itself. it only works when i have my headphone jack into
Most televisions have a setting that controls whether the TV uses its internal speakers or sends the sound to the audio out jacks for an external amplifier or speakers.
Try going through the settings menu and follow through the audio/speaker selections and confirm that the TV is set to use external speakers.
Best Regards,
Sep 01, 2017 | Televison & Video
Speakers are mounted on the side of tv (mitsubishi CS 40503 1995 model) want to remove them and have them in a different location
"Speaker: Internal/External" controls which speaker (built-in or external) is available. Set to "Internal" for normal operation of the internal speaker system. When connected to external speakers or an external audio system, the speakers can be turned off by setting this function to "External."
From reading this I see that the speakers may be internal because the setup allows to switch between external or internal. A mounted speaker is either permanent, part of the case, or has something that the speaker case slips into. I had one like that. You simply lift them and set them else where. How far they can be moved will depend on the wire. The wire is either attached internal through the back or attached via connectors on the back. That can either be loose wire or RCA plugs. Normally the wire coming from the speakers is attached internal, making the removal of them impossible. The wire is usually 3 to 6 feet long. You can buy an external speaker wire that has RCA plugs (and or plain wire) that will attach to the existing speaker wire and TV.
Good luck and post back
Jun 04, 2011 | Televison & Video
I think my speakers are blown on my sony 53 inch rear projection tv can I run the sound through my home theatre and bypass the blown speakers?
check your audio menu on your tv. mine can turn off the speakers and sends the audio signal out the rca's when the speakers are off.
Oct 25, 2010 | RCA P52960 52" Rear Projection Television
Extra speakers
hi in the back of your tv you should have 2 sets of 3 plugs called rca one set is input the other one is output if u using standard speakers connect it to the input remember the speakers need to have the rca plugs,if you use a amp connect your amp to the input to outlet and reverse from the tv.
Feb 06, 2009 | Sony FD Trinitron WEGA KV-29LS35 29" TV
Connecting RCA plug to speaker wires
You can connect the RCA plugs to the speakers. But, as for using the red/white Audio outputs you may need an amplifier, those connections are used when going into a dvd or vcr that boosts the signal in their own environment. If you have a connection for headphones on the TV you might have better luck there for the speakers.
Jan 11, 2009 | Sony KLV-S32A10 32 in. HD-Ready LCD...
RCA tv.speakers internal
buy another speaker of your tv for replacement
Jun 03, 2008 | RCA TruFlat 27F520T 27" TV
No sound on LCD tv
in the audio part of the menu, check to make sure the internal speakers are not turned off.
what connection are you using for the DVD? if using YPrPb, make sure you also have the audio red and white plugged in
Feb 12, 2008 | RCA L37WD12 37 in. LCD HDTV
Sony KP-57WV600 57" Rear Projection HDTV-Ready Television Logo
779 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
