Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Whirlpool ultimate care II topload washing machine
Hi FIXYA---we have a 2 year old Whirlpool top load washing machine model # LSQ965pw2. It has been working fine however this pm came home to throw aload in washer and the agitator or drum will not spin. When pull switch to turn on there is a grinding noise, it will fill machine but agitator will not spin. I appreciate any ideas or suggestions. I have 4 kids and need to use machine every day!
Thank You---
Concerned Mom in NY
  • Anonymous Mar 17, 2014
    My Whirlpool washing machine model number LSR8233EZ1 only hums when the button is pulled to turn it on. It will not wsah or spin.
  • 1,314 Answers
Well I'm going to do my best to fix your washer. First unplug the washer and turn off the water. If you have a shop vac take the drain hose out of the drain,and through the drain hose vacuum the water out of your washer. If you don't have a shop vac go to the auto parts store and buy a pair of radiator hose clamps . Then facing the washer locate the two screws. They will either be in the front or rear of the control panel and back them out far as you can. Once you have done that pull the control panel slightly forward, and tilt it back on the hinges. Now unplug the lid switch wire but don't forget to plug it back when your done. Next locate at the rear of the washer body the two gold clips then push forward, and take careful note of how they fit. Then pop them out with a screw driver tilt the washer body forward at 45 degree angel and walk forward with the body, and set it down. Now you will see the white pump and motor assembly. You should see two clips holding the pump to the motor pop them off, and pull the pump off the motor shaft. Now if you fell the need to remove the pump use the radiator hose clamp. take them and clamp the hose coming from the tub but its not necessary for the repair. Next disconnect the wiring harness from the motor (note the position of the harness for reassembly). Remove the two 5/16 inch screws from the motor clamps and pop the clamps off. Once that is complete, remove the motor put the new coupling on the motor and transmission shaft. I use a socket and a hammer
Posted on Jan 26, 2008
Model # SM 8280867 How old is this model?
6 - 10 years in 2012
Whirlpool Washer Ultimate Care ii - Appliance Repair Forums
  • LAST UPDATED: 2012-05-28
  • 6 POSTS
  • FIRST POST: 2012-05-28
Whirlpool Washer Ultimate Care ii Model Number: SM 8280867 Brand: Whirlpool Age: 6-10 years Hello, The washer ...
Jan 27, 2016 | Washing Machines
Whirlpool Ultimate Care II LSQ9549L Top Load Washer were is the drain filter
With Whirlpool top loader models the pump is located at the bottom of the appliance. The pump is accessed from underneath the appliance. Some model may have an access panel at the back. I think that with the Ultimate Care models the pump must be accessed from underneath. Here a repair video.
Here parts and diagrams.
Aug 07, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
How do I change the dog agits in the ultimate care whirlpool topload washer model lsr8233eq1
Remove number one then 23 then number 2
Then remove the agitator. Set it on the floor and yank it apart. Install the new part being careful not to break the retention tabs on the base of the agitator. Here is a nice video which shows how it is done:
More videos and a service manual are HERE
Nov 19, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Standard washing machine hoses dont seem to fit my Whirlpool Ultimate Care II washer? Do I need an adaptor of some sort....
The Whirlpool Ultimate Care II is an American top loading washing machine and requires different hoses available from Whirlpool.
May 16, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
My Whirlpool Ultimate II topload fills with water but does nothing else. The lid switch appears OK
it might look ok but not all the time it is. If the switch is good, maybe it is a burnt or bad connection at the motor. or it could be a bad motor
Mar 01, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
I can't find the model number on washer Whirlpool Ultimate Care
Model # and info is under the lid. Open lid and look directly under it - area facing you. You should see a small silver tag with all the factory info on it. My washer is also 9 years old.
Dec 08, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
368 people viewed this question
Dan Webster
Dan Webster
Sal De
