Dvd player my dvd player doesn´t read any dvd but read cd. what can i do to solve the problem.help me please
  • 2 more comments
  • bkigemar_123 Dec 03, 2008
    I HAVE A PROBLEM with my dvd player it doesn't read dvd movie disc but when i use cd disc it reads what is the solution to this help
  • Anonymous Apr 07, 2009
    me too
  • Frosty555 May 11, 2010
    dvds are also harder to read when a legacy windows cdrom driver that doesn't have dvd capabilities is being used to access the drive. This is a common symptom on a number of HP laptops.
    This is the dvd drive on your laptop? What is the make of your laptop? Do you have any DVD player software installed on your computer like WinDVD or PowerDVD?
    Can your DVD drive read data dvd discs? Or are you only having problems with dvd videos?
    Sergeant:
    Champion:
  • 243 Answers
Try using a head cleaner cd/dvd to see if that solves the problem. Failing to read a dvd but being ok with cds is norm a sign of drive startin to die. Dvds are harder for it to read due to smaller track width.
Posted on Jan 26, 2008
If you push the play button on the dvd player it does not work
does the issue only doesn't play or doesn't read any disc?, just let me know it will help out to solved the problem.
Oct 15, 2012 | Cyberhome CH-DVD 300 DVD Player
When i insert a CD, it won't accept it, "disc error" appears. What is the solutions.
hello there soenensistva
Well first of all Compact discs are easy to be read by a DVD player then ordinary Cd player cause of their lens are made for more compressed Data discs..there for try some of the options
1. make sure that the disc Surface is Clean and don't have finger prints or any other material that is disturbing the the read process between the CD and lens present inside CD player
2.if your CD is precious for you ( that consist some important Data you may need ) then try a DVD player for that
3.if both things doesn't work try a cleaning Cd for Cleaning the Head of CD player .
i wish that your problem may be solved
Best Regards
Oct 15, 2012 | NAD T550 DVD Player
Technika combi unit dvd player wont read discs anymore
how long have you been using this player? I suspect the laser (lens) of the player. I think the laser (lens) is weak that's why it cannot read data/files on DVD discs.
To confirm if actually its a laser problem, insert an Audio CD into the player and see if will play. If it plays, then obviously, your laser (lens) is weak. But if it doesn't play Audio CD, then it might still be the laser (lens) or a mechanism problem.
Get a lens cleaner, use it to clean the lens. If that doesn't solve the problem, get a screw driver, open the player's cover so that you can gain access to the lens, use a cotton board to clean the surface of the lens. This should clean dust or dirt that might be on the lens.
If non of the above solves the problem, then know that you need to replace the laser to a brand new one.
To replace the lens, remove the bad laser, use it as a sample to get exactly the same type and do the replacement. Note that replacing a laser (lens) needs a professional touch, so if you cannot replace the laser, get it to a repairman to fix it for you.
Once this us done, your player will play all DVD discs again.
Regards.
Jan 12, 2012 | Televison & Video
I have just purchased an HP Desktop computer and when I burn a Cd for music, everyting seems to work ok but when I try to play that CD on another player in my home, it won't play. Is there a setting...
Check the type of the blank CD/DVD you are using. Certain players won't be able to play CD-RW for instance.
If that doesn't solve the problem you might try to slow down your burn speed for a better quality CD/DVD. Sometimes a faster burn speed will lower the quality and other devices can have trouble reading these.
May 10, 2011 | HP Computers & Internet
It will read CD disk but will not read DVD disk have tried several different ones
Good luck.
Apr 14, 2011 | Phoenix Gold Phoenix Digital (PD-2122T)...
Upon inserting a dvd in the player, the player can't fully read the disc until the display reads "HO2".
Hi , Just simple ,
option 1:
Please open case and clean the lense
or
option 2:
use good lense cleaner cd with liquid.
just drop liquid on to cd cleaner ( excatly on brush)
then you run.
it will solve your problems.
Dec 01, 2010 | Panasonic DVD-RV31 DVD Player
Cd x-9 teac will load cd spin but not play lcd reading says 'no cd'
If this problem occurs only at this cd/dvd it's a disk problem. If it occurs on various disks try using a cd/dvd cleaner set, a wet one is better. Follow the instructions on the set. The main idea is to put one drip of the included liquid at the set (usually isopropyl alcohol) at a specific place (like small brush) on the disk surface and play this disk. This way the "brush" will clean up the laser lens and after that the cd/dvd player will be able to read the disks. BE CAREFULL not to put too much liquid on the "brush". In case you can, use a Q-tip with isopropyl alcohol to clean up the cd lens manually. In case this doesn’t solve your problem, the cd player needs laser lens replacement by a technician.
In case of a problem or clarification, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
May 14, 2010 | Audio Players & Recorders
My player wont read any CD at all, or DVDs
This DVD player unfortunately does not support most of the Copied DVD /CDs.
it works stemless with only genuine / original CD and DVDs..
If your DVD or CD originallly recorded by manufacturers but still can not read ,
than I recommend you to obtain and apply it to clean your laser eye of the DVD player.
Hope it will solve your problem.
Please remembr to vote me too..
Regards
Compatible disc formats: DVD, CD, CDR, CDRW, Video CD
Sep 28, 2009 | Sony DVP-NS400D DVD Player
Have Wharfedale portable dvd player WDP-1210 will read audio cd`s but not dvd`s. Help.
I have a wharfedale dvd player wpd-1210 it will read audio cd's but not dvd's can you please solve my problem.
Apr 16, 2008 | Wharfedale Televison & Video
Reads all but DVD-Help PLEASE
When you say it won?t read are you trying to play commercial DVD movies or read DVD data disks? If you're trying to play movies then you need a couple of things the first being some type of player program. Real player works as does Windows media player but usually DVD drives come with a striped down version of PowerDVD or WinDVD. If you in fact have a player installed and when a DVD is inserted in your drive it doesn't play it may not be configured to automatically play DVDs. Try opening your player program and trying to manually play your DVD. Let us know if you have any success or if you need more assisted. If you do let us know what player program and operating system you have and any error messages that may appear.
Jan 01, 2007 | LG GCC 4320B CD-RW/DVD-ROM Burner
Computers & Internet Logo
347 people viewed this question
Alun Cox
David Payne
David Payne
