Question about Epson Livingstation LS57P2 57" Rear Projection HDTV
Epson Livingstation LS47P1 won't turn on
I replaced the bulb in my TV 2 months ago, after which it
functioned properly until last week. Whenever I try to turn it on, the
"power" light blinks green for a 1.5 minutes and then the "power" light
turns solid red and the "lamp" light flashes red for several minutes. Then
the "power" light returns to orange. Throughout the process there seems to
be a hum coming from the speakers, an occasional buz which sounds like
it''s coming from behind the lamp, and the "card" light is solid orange.
I have tried the process described in the manual (p. 114) of disconnecting
and re-connecting the power cord. The TV has not turned on for 2 days.
Anyone experienced this before?
  • mr jake May 16, 2008
    replaced the the bulb 2 months ago, now tv will not turn on , we have exactly the same problem with the lights blinking and turning colors.
    woodrow
  • Anonymous Mar 25, 2014
    green light flashes for two minutes then tv come on for three minutes great picture then solid red light comes on
Hey,
Very similar problem with my LS47P1. Here is the scoop (I work for a retailer which carried these and I bought one)
- Epson has admitted that there is a flaw in the engineering of many newer bulbs (that is ones that were made after the initial release of the LS47P1)
- Apparently the 3 little metal contacts on the lamp tend to get "squashed" down over time once the lamp has been installed (this takes a little while, like 2 weeks to a month after the replacement lamp is installed).
- The contacts no longer make a connection with the inside TV side contacts and the electrical charge needed to ignite the gases in the lamp does not get through (like 9 out of 10 times)
- You can get it to work temporarily by pulling out the lamp and carefully pulling the inside contacts upward to make a better connection inside. NOTE: I did this for a while everytime it didn't work and after a while the pieces of metal became worn and would break off. So do this only if you have an extra lamp handy or you're on your last witts (as I was).
HERE'S WHAT TO DO:
1. Call Epson of America (I am in Canada, but they are the ones to talk to anyway)
2. Tell the first person who answers the phone to transfer you to the Livingstation (rear projection) department. If they start telling you that it will take like 48 hours and they will call you back tell them "NO! put me throught now!"
3. Tell the real tech expert your issue.
4. Get him to send you out a non-defective lamp (these ones have been retrofitted to not get "squashed" in the TV.
5. Put new lamp in and cross your fingers....
Hope this helps.
Mark
Posted on Mar 26, 2008
I too have had this problem with my Epson tv. The only solution I have found that works is if you pull out the bulb and then put it back in and turn on the tv. Sometimes I have to do this 2 or 3 times before the tv turns on. Hope this helps.
Posted on Feb 08, 2008
Purple spots on the bottom and middle of my EPSON livingstation tv.
Search for this problem by using the term "pink bloches" I already explained the solution.
Oct 28, 2008 | Epson Livingstation LS57P2 57" Rear...
Overheating
There are contacts inside the Livingstation that make contact with the heat sensor on the bulb. If you take the bulb out you will see them in the upper right corner of the bulb housing in the TV. These can become corroded resulting in a poor connection between the TV and the bulb. A poor connection will make the TV think it's over heating even if it's not. There are 3 contacts in the TV and 3 on the bulb. Clean these contacts with a lint free cloth and some alcohol on both the TV and the bulb, being careful not to let your fingers touch the bulb. If your hands are too big to reach inside the TV, rub a pencil's eraser over the contacts to clean them. When putting the bulb back into the TV, seat as firmly as possible, then tighten the upper right screw first.
Jun 09, 2008 | Epson Livingstation LS57P2 57" Rear...
Light engine
where are you getting your parts from? sounds like someone may be selling you used parts to get more business.
Apr 15, 2008 | Toshiba 62HM95 62" HDTV
Hey
Where is the projection lamp in a Livingstation and how do I get it out?
Mar 26, 2008 | Epson Livingstation LS57P2 57" Rear...
Life of a bulb
I too have an early P1 series Livingstation with a bulb that MAY be going out. I've been searching online and found several suppliers with prices ranging from $249 to $367. the Epson store seems to be the cheapest and probably most reliable supplier at $249 including shipping! http://www.epson.com/cgi-bin/Store/ProductQuickSpec.jsp?BV_UseBVCookie=yes&oid=40809413&category=
The stated life of the bulb is 10,000 hours ... and I've had my LSP1 for perhaps 4 years. We use it kind of heavily - and I'd say we've used it roughly 30-40 hours a week... and over 4 years I'd say that equates to 200 weeks at 30-40 hours = 6000-8000 hours of use already. So, once I replace the current lamp - if the replacement works well... then I'll immediately buy a spare bulb. That will enable effective use for another 20,000 hours with the new replacement and spare. That hould last me about 9-11 more years for only $500 or so.... assuming I get 4.5-5.5 years of use per bulb.
Jan 05, 2008 | Epson Livingstation LS57P2 57" Rear...
LS47P1 Epson Living Station
Sounds like it might me a source or connection issue. However, you would know to check that - right? Just the other day i had a damaged cable cause an image problem. I replaced it and all is well again.
If not a source or cable issue - then this sounds like you'll need a service call from an Epson tech. I'd give them and - might I add - I'd apprecaite knowing how this turned out. I wonder how I might have to deal with problems down the road... IE get service and fix it or just throw out the Livingstation!?
Dec 16, 2007 | Epson Livingstation LS57P2 57" Rear...
Epson Livingstation LS57P2 TV Power Won't Come On
tryin unplugging t.v for an hour then plug it back in it worked for me i have the same t.v just the 47 inch
Jan 30, 2007 | Epson Livingstation LS57P2 57" Rear...
Epson Livingstation LS57P2 57" Rear Projection HDTV Logo
733 people viewed this question
Top Epson Televison & Video Experts
Eric Sutherland
Are you an Epson Televison and Video Expert? Answer questions, earn points and help others
