Kenmore front loader washer
How do I locate my filter in my Kenmore front loader washer?
    President:
  • 1,314 Answers
First if you have a wet vac pull the drain hose out of the drain spout and use the vac to pull the water out of the washer through the drain hose.If not you will need a pair of radiator hose clamps from the auto parts store. Pull the screws from the lower panel at the front of the washer and remove it.in side you will see a rubber hose coming down from the tub to the drain pump. Put the radiator hose clamp there if you didn't have a shop vac.On the front of the pump is a round part with a handle turn that and remove the pump filter .Clean any foreign objects out of the pump and look inside the pump to make sure no impeller blades are broken if any are you will have to replace the pump. put the filter back in and tighten it. If you had to use the hose clamp remove it now.reassemble and don't forget to give the tech his four boxes if this fixes it
Posted on Jan 25, 2008
Kenmore elite smartwash quiet pak 4
This video will show you how to change a door seal on this Bosch front loader washing machine
You can find more Bosch videos in our Bosch repair channel
Jul 22, 2013 | Kenmore Elite 45986 Front Load Washer
Front loader stuck in final spin - not draining
Very likely the reason your washer isn't draining is because the filter screen on the drain pump is blocked so it cant drain, its a fairly common thing wrong with those type front loaders soi have written this tip covering how to clean that filter, http://www1.fixya.com/support/r10121384-check_when_duet_washer_door_locked_after
GENE
Oct 06, 2011 | Kenmore Elite 45986 Front Load Washer
I need to the know what is the problem when F02 shows up on the whirlpool front loader washer model wfw92005qoo, this code is not on the chart sheet
F02 is "Long Drain".
Essentially this means that the water is taking too long to empty. Almost certainly a blocked empty pump filter (I think the filter is behind a little door on the bottom right on this machine).
Locate the filter, clean and replace. All will be well
Jun 29, 2011 | Kenmore Elite 45986 Front Load Washer
CLEAN PUMP LIGHT COMES ON WHERE IS THE PUMP LOCATED
The pump is located behind front bottom panel on the right side assuming that your machine is a Whirlpool or Kenmore Front-Loader. Disconnect power and remove the three screws attaching the lower front access panel to the cabinet then pull the panel down and off the cabinet. You can prop up the bottom front edge of the washer or cushion and lean it against the wall to access and remove the screws more easily.
Once the panel is off, remove the filter by turning the knob counterclockwise. Clean the filter from any debris that prevents water from draining out properly. Click on the link below for further troubleshooting should the cleaning of the filter does not resolve the problem.
Troubleshooting Error Code F02 on Kenmore Elite and Whirlpool Duet Front Load Washing Machines
Nov 13, 2010 | Whirlpool Washing Machines
Where is the pump/filter located on my Kenmore Front Loader Washe
It is just behind the lower panel. Remove the 3 screws from the lower panel (the panel just below the door), the screws are on the lip on the bottom of the panel facing the front of the machine. Pull down and toward you to get the panel off. The filter and clean out are in the center. Unscrew the cap to remove and clean out, but have lots of towels ready, there will be water coming out.
Apr 20, 2010 | Kenmore HE2 Plus Front Load Washer
Where is the filter located that is suppossed to be cleaned
If this is a Whirlpool Duet or Kenmore Elite front loader, the filter is the drain pump reservoir. The following link explains how to access and clean:
http://www.fixya.com/support/r3574284-checking_the_drain_pump_on_a_front_loade
If you run into any difficulties, or have additional questions, please let me know. I hope this helps you.
Jan 08, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore washing machine
Whether this is a TOP LOADER, or a FRONT LOADER, the drain pump is located directly below the wash tub in the front of the washer. Accessing either one takes, different procedures, however.
To access the pump on a TOP LOADER, you must remove the exterior washer casing. Follow the steps provided in this link:
http://www.fixya.com/support/r3631789-washer_case_removal_whirlpool_top
If this is a FRONT LOADER, you must remove the lower toe panel directly below the door. Follow the steps provided in this link:
http://www.fixya.com/support/r3574350-replacing_the_drain_pump_in_a_front_load
The Kenmore Oasis is a different configuration from the two I've mentioned. There are two pumps on the Oasis. One is a drain pump, while the other is a recirc pump. Both are accessible by removing the rear panel of the washer.
If you require further assistance, please post back with a complete model number so I can determine how your washer is configured. I hope you find this information helpful.
Dec 22, 2009 | Kenmore Washing Machines
Top load kenmore 110
it's your pump! thats the most common leak on kenmore top loaders.it located low ,front and .you can tip washer back towards wall and inspect.the pump is white and has two hoses to it.
Jan 24, 2009 | Kenmore 22422 Top Load Washer
Kenmore 417.29042992 front loader washer
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Jan 23, 2008 | Kenmore 44102 Front Load Washer
Kenmore front loader washer HE3 kenmore Elite
ok " there is a filter on that line ,it has to be cleaned
to locate filter, follow hose back to filter
filter will come apart for cleaning
Jan 11, 2008 | Kenmore 44832 Front Load Washer
Washing Machines Logo
142 people viewed this question
Top Washing Machines Experts
