Question about GE JVM1790 1000 Watts Convection / Microwave Oven
GE Profile JVM1790 convection microwave.
Our new GE convection oven JVM1790 preheats very slowly in the higher temperature range. It's supposed to go up to 450 degrees. It preheats quickly up to 350 degrees then slows down to a crawl to get any higher. Our JVM1790 barely makes it to 400 degrees.
I sell appliances at Home Depot and am probably going to test the JVM1790 display to see if it exhibits the same preheating defect. My electric range cannot preheat as quickly to 350 degrees as the JVM1790 convection microwave. But the JVM1790 slows down so much after 350 degrees that the range blows right past it. Any ideas or comments on why our JVM1790 slows down so much after 350 degrees would be helpful.
  • 1 more comment
  • Anonymous Mar 07, 2008
    Our JVM1790 also prheats very slow at higher temperatures.
  • Anonymous Mar 28, 2008
    My preheat temperature does no go beyond 385F. I contacted GE and was told that there is a problem with the unita manufactured in Korea(samsung). Direct energy came to service it and said they can't fix it.
    I then contacted the GE dealer and was offered a complete refund.
  • Anonymous Dec 26, 2008
3 Suggested Answers
SOURCE: 15 yr-old GE electric oven takes over an hour to preheat to 450
After jiggling the lower burn element the oven heated up in the normal time. Perhaps a connection had come loose.
Posted on Feb 14, 2009
MicrowaveSvc
  • 9098 Answers
SOURCE: Have a GE Profile Microwave/Convection oven.
It may be a bad convection heating element or just a bad thermal cutout.
If it's less than one year old, it will be fully covered under warranty and you can contract GE here to have an authorized servicer come out and fix it free.
If it's out of warranty and you or someone you know wants to check it out, I'd first suggest you take a look at the "mini-manual" hidden inside the unit (behind the control panel, hidden on the left side behind the grille, or attached to the inside of the outer cover) which is very helpful when troubleshooting, & testing.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Otherwise, see these files: safety disassembly
Accessing some parts may require you to pull the oven from the wall and remove the cover.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download GE owner's manuals and installation instructions here.
You can find links to helpful exploded view diagrams and part ordering help here.
I'd recommend that your bookmark this link to your favorites.
Posted on Dec 26, 2009
My GE Profile JVM1790 convection microwave has issue. Was using the convection portion when a small spark and flame appeared and then went out and soot and smoke was all inside and now will not heat up...
Yep, that sounds very much like the heating element burned out. It happens. You should be able to get a replacement from the manufacturer's website... or there may be a list of repair centers in the manual - pick one & try to order the heating element through them.
Aug 13, 2014 | GE JVM1790 Convection / Microwave Oven
Bought house with GE Profile Convection Oven. Do not know proper cooking directions, nor how to work many of the features. Also no light bulb in it & would like to know which one to buy. Need manual t
GE has the manuals for most of their appliances on their site: http://www.geappliances.com/service_and_support/literature/ . Just enter the model number and click Submit.
The direct link to the manual for the JVM1790 Over-the-Range Convection/Microwave oven is here: http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=49-40480-1.pdf . GE only lists the JVM1790CK, JVM1790BK, JVM1790WK and JVM1790SK.
I hope this helps.
Nov 10, 2011 | GE JVM1790 Convection / Microwave Oven
GE Profile convection JVM1790 will not heat. Everything else works but not heating. The oven is only two years olds. Any suggestions?
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Jun 16, 2011 | GE JVM1790 Convection / Microwave Oven
Interior light staying on in GE JVM1790 and
This is usually caused by either a bad door switch or a loose door switch mount, which are pretty simple problems to fix.
Since it's less than one year old, it would be fully covered under warranty. I'd suggest contacting the manufacturer to get it fixed free.
You can find a GE-authorized servicer by calling GE Appliance Service at 1-800-848-7620 or here.
Jun 06, 2009 | GE JVM1790 Convection / Microwave Oven
Will the template for JVM1790 be the same as earlier GE models?
Make your own template of the holes in the top of your cabinet and lay it over the new unit and see if they align. As long as your replacing GE with GE it probably will work.
Oct 04, 2017 | GE JVM1790 1000 Watts Convection /...
Ge profile convect oven in spanish and can not change to english
Press options on the key pad, turn dial to "idioma", press and turn dial to "ingles"
Feb 25, 2009 | GE JVM1790 Convection / Microwave Oven
GE Microwave/Convection JVM 1090 oven won't reach temperature
You probably have a bad thermistor.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
(At that site, that part is misspelled as "thermister" for your model).
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
Accessing some components for testing will require you to remove the oven from the wall.
Jan 02, 2009 | Microwave Ovens
GE JVM1790 1000 Watts Convection / Microwave Oven Logo
205 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
