Washed out video on all channels/power lights blinks no power
I have a Hitachi model # 57UWX20B, Thats washed out on all channels, with vertical problem, I have replaced Tuner, TA1360N microprocessor, vertical IC, checked all fuses, connections and caps, still washed out, the units PIP work ok, I can play vcr and video games only in PIP mode, none in regular tv mode.
I have a PLILIPS, model #50P8341 that the power light blinks when pushed, you can push any button and the power lights comes on and blinks, there is not high votlage, the unit is dead.
  • Henry Brue Jan 29, 2008
    I have replaced the STK'S, But maybe I was not as careful as I should have been, they are STK 293-110'S,I did use heat sink compound, I will replace them again and be more careful.
    Genius:
  • 3,422 Answers
You could probably do the replacement by yourself.
First, go to the owners manual and make sure you have gone through the convergence set up. See page 45 of the manual. When pushing the magic focus button be sure that the set does inaugurate the convergence routine.
Your model has hundreds of parts listed at the www.partstore.com site; I did not search for the STKs but what you can do is find the part number on the case of the convergence ICs and search for it. They cost around $30 to $50 each and there are two of them of the same part number (usually). They must be mounted with great care.
Why would this happen again? Could be a poor design, could be poor mounting of the stks and heat transfer was not adequate, could be out of spec parts, etc.
Expect to take a couple of hours at least to do the replacements.
CAVEAT: We cannot be sure it is defective STKs, so do all the checking and testing you can to pursuade you that they are the real culprit - again.
If you go to http://www.freelists.org/archives/techassist/02-2005/msg00303.html and do a word search on "stk" you will find many interesting comments by others about replacing them and various other convergence comments.
Also, if you go to http://www.schematicsforfree.com/archive/?path=Video%2FProducts and look down the Hitachi list you will see a convergence file that may be helpful in doing the convergence...... It is for an older set, but I believe the procedure is about the same for your model. (This is in the manual setting area, not the Magic Focus automatic procedure).
If anything herein is confusing, please ask more questions. Good Luck with the repair.
Dont forget to rate me as fixya..
Posted on Jan 29, 2008
I just tried to try my NES (wichs hadn't been use for a long time) again. When i plugged everything and turned the NES on, the light start blinking. Then, I put a game in it and opened the tv on channel 3....
You can try to change the input to Video instead of channel 3 since you're using a RCA (Red, Yellow and White) cable.
Thanks for using Fixya.
Jan 31, 2011 | Nintendo NES Console
How do I set up an antenna for tv signal with my 57uwx20b? Do I need a special code to put into the converter box?
U planning to get free air tv?No need for a converter box,ur tv have digital tuner inside.Just plug in ur antena.Go to ur tv menu go to setup pick air scan all ur channels,well get all free air channels.
Feb 12, 2010 | Hitachi 57UWX20B 57" Rear Projection...
Hitachi, model 57UWX20B ghosting?
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer2_bing.gif Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 24, 2009 | Hitachi 53FDX01B 53" Rear Projection...
Hitachi 57UWX20B 57 in.
Projection TV sets have two very common problems listed below.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
*Screen Looks 3-D
*Colors wont align
Problem #2 - Another common problem is dull or washed out video.
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Sep 08, 2008 | Hitachi 57UWX20B 57" Rear Projection...
Hitachi 57uwx20b
First of all there is no light engine inside your set. Your model is CRT based. Can you better describe what you mean by the green only working occasionally? What exactly is the picture doing? Also, please confirm that your model is: 57UWX20B.
Thanks,
Dan
Sep 05, 2008 | Hitachi 57UWX20B 57" Rear Projection...
57uwx20b no picture and sound
We lost power today and our 2002 Hitachi 57uwx20b, has no picture or sound, yet the power light is on...any ideas. Thanks
Jul 21, 2008 | Hitachi Televison & Video
Hitachi model # 57UWX20B, IT HAS WASHED OUT VIDEO ON ALL CHANNELS WITH VERTICAL PROBLEM, PIP WORKS OK, WILL NOT PLAY VCR TAPES OR GAMES, BUT IT WILL PLAY THEM ON PIP. I CHECKED ALL CONECTIONS AND CAPS,...
The problem with the video from the VCR and Game console only being in the PIP window is likely cured by hitting the swap button (or its equivalent) on the remote control. With the Washed out video on all channels, that could be caused by defective capacitors on the CRT drive board, usually 470uF @ 10-16Volts . It could also be caused by dust buildup on the Lenses, and if the set was used in a room where people smoked, the mirror probably has a film of nicotene on it as well. I don't know what you mean by a vertical problem as well. If it involves retrace lines at the top and a shortening at the top and bottom, then I would suspect capacitors in the vertical circuit there as well. If it is a vertical jitter that you are experiencing, I would suspect bad solder connections in that same area.
Jan 25, 2008 | Televison & Video
Televison & Video Logo
70 people viewed this question
Top Televison & Video Experts
