Question about Whirlpool GEW9250 Electric Dryer
How do you replace the heating element
No warm air at all.
  • 5 more comments
  • tobym Jan 26, 2008
    The dryer has a four prong plug. I'm almost certain it's a 220 circuit and not a 110. The dryer has two, 30 amp circuit breakers. I'm a computer engineer, not a electrical one Jim! :-) The dryer was working (had some heat while drying) but it seemed there was less heat over time. I had to repeat the drying cycle mulitple times to get the clothes dry. As of yesterday, there is no heat at all, leading me to beleive it's the heating element.
    Thanks for your timely response!
    Toby
    BTW, this is a new construction and the exchaust vent is free of obstructions....
  • tobym Jan 27, 2008
    Ok, I reset the breakers. I let them sit in the off position for 3 hours, no change. The dryer is still blowing cold air. I will think about becoming a member, using my talents might be worthwile.
  • whizbang Jan 31, 2008
    I have the exact same problem However I know I am on 220 since this dryer has been operating for years
  • tobym Feb 05, 2008
  • tobym Feb 09, 2008
    UNPLUG THE DRYER BEFORE ATTEMPTING THIS REPAIR, DEATH OR SERIOUS INJURY COULD OCCUR. To replace the heating element, you need to remove the bottom panel directly below the dryer door. There are two screws on both sides of the panel. It requires a 1/4 inch nut driver. On the right side of the dryer, there is a metal bracket that needs to be removed, it is secured with 1/4 sheet metal screws just like the bottom panel. There is a screw on the top and one on the bottom which supports the heating element housing, it is a pedistal that supports the ducting where the heating element is installed. After removing the the pedistal, there is another sheet metal screw just behind the power terminals. Remember, UNPLUG THE DRYER BEFORE REMOVING THE SCREW, ELECTRICAL SHOCK AND DEATH COULD OCCUR! Remove the power connections from both terminals (remember which wires goes where, there are to red wires, one with a white stripe, on my dryer the white striped wire connected to the bottom terminal) and remove the sheet metal screw directly behind the power termination point (where you removed the wires). Getting the heating element out was a bit of a challenge, it is secured by a pressure pushing mechanism (not quite sure what it's called) that causes the heating element to remain securly in place in the housing/duct. It takes considerable effort to remove the heating element from the housing. I used plyers and grabbed the support structure of the heating element coils and then pulled it out while holding the housing/ducting in place. The housing seems a little fragile so I used care while removing the heating element. I also used care while inserting the new one, it does take some forceful pressure to get the new one in place.
    After knowing where the heating element was (no thanks to this website, a local community repair specialist told me), I noticed considerable damage to the heating element. You may not see damage like I did on my dryer (the heating element wires were melted and fused to the housing/duct). After removing the heating element, carefully inspect it for damage, the smallest break in the coil could render it inoperable. If the heating element appears to be in working order (test it with an OHM meter) then the problem may reside in some other part of the dryer.
  • Anonymous Dec 12, 2008
    How u doing everyone? I do have the same problem with my dryer. The coils were melted down. The springs broke like a fuze burn out. You get service in your town at an small appliance store to help you with any question or to order new parts. That's it.
    President:
  • 1,314 Answers
First you need to make sure the heating element is the problem dryers will run on 110 but will not heat with out 220 first you need to confirm that you have 220 then let me know what you find hold my rating till we are done and don't buy a heating element yet
Posted on Jan 26, 2008
  • 1 more comment
  • robert samples Jan 26, 2008
    hey we ain't done im an appliance tech so you have two lines coming in each line is 110 together they make 220-240 one side goes to the drive motor the other goes to the heater lots of times double breakers can partially trip now i can get you to the heating element but don't want you replacing a part you may not need don't worry about it its not rocket science just a machine the best thing to do is just go rest the breaker and see if it heats you got a 4 prong plug because the codes in your area require a body or earth ground for the drier so green goes to the body of the drier white to neutral red to one 110 leg blk to the other 110 leg but ive fixed a lot of these by just resetting the breaker also if your a computer engeneer why dont you join the site here and become an expert can make cash here too doing live chats ive made about 70 bucks this month just setting here
    iwent on a new constution site one day and they had cut the hole in the drywall but not the outside wall lol point take nothing for granted
  • robert samples Feb 05, 2008
    first facing the dryer remove the filter then remove the two hex head screws pull the bottom out and away from the case over on the right hand side you will see the vent tube with the heater in it.
2 Suggested Answers
hunter19_46m
  • 7482 Answers
SOURCE: Mayrag dryer blower is working, heating element
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Check to make sure you are getting full 220 Volt power to the dryer, if you are then:
Check your Wiring
Often the main wiring connection from the house, at the dryer, burns and the connection breaks. If this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Check the Door Switch
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. Check for continuity you should have none with door open, and should have a reading when closed. If not replace the door switch.
Check to make sure you heating problem is not a lint build up in the discharge hose or the dryer,as this condition can cause heater/thermistor problems such as overheating of the heating coil leading to failure of the coil and burnout of the thermostat/thermistor due to overheat.
Remove the back/or front just under the door of the machine and try to locate the air duct going from the blower to the drum. Normally inside/outside the air duct you will find the heating coil and the thermostats/thermistors. Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor one at a time by removing the two wires and taping them together with electrical tape or with an ohm meter to test the thermostat/thermistor. (Should have/show continuity)
If the coil heats up then replace the thermostat/thermistor.
(Thermal fuse.If it overheats the dryer will not operate. It's located on the blower housing. It cannot be reset. A vent clogged with lint can cause it to overheat. You can test it with an Ohm meter or continuity checker, if no continuity, replace it)
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST.
This could cause a FIRE, as you have removed the safety of overheat from the machine.
Right after replacing a dryer element, always run the dryer on 'air fluff' / 'no heat', and go outside to verify there's plenty of air coming out your vent system.
If the vent's clogged, that new element can burn out very quickly.
For video and pictures on how to replace the element go to the following website:
davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm
This is a FREE answer, Please rate me
Posted on Dec 05, 2010
GE dryer dwsr463eg7ww timer isn't working and doesnt heat up
The heating element assembly warms the air before the air enters the dryer drum. If the dryer won't stop, it may be because the heating element assembly isn't working - which greatly increases the drying time. Check the heating element for continuity. http://www.repairclinic.com/RepairHelp/How-To-Fix-A-Dryer/7-3-850356-/GE-Dryer-won-t-stop-DWSR463EG7WW
This GE Website has descriptions and videos you can watch. Also shows the price of replacement parts and the skill level needed to preform repairs yourself.
Sep 12, 2014 | GE Dryers
How to heating. it's always cooling
Keep heat mode and temp setting+5 degree than your room temp.Still no heat check power to heating element. No power replace heating temp senor. If it's with RV, check power to RV and also warm in suction pipe(higher size pipeline near compressor).
Jan 27, 2011 | LG LS-K2430HL Heat Cool Mini Split Air...
Kenmore model 58072187300 a/c and heat window unit. When I Set on heat , i barely feel the air get warm.
Toget proper heat, keep your temp setting at 30+ degree and also mode in "heat"position. If still no heat, check your heating sensor for closed circuit by anOHMs metre.It it's with RV, check power to RV.If it's with heating element check power toelement. If power is there but still no heat means element defective. Replacenew heating element. Thanks
Jan 10, 2011 | Maytag M7Y15F2A Air Conditioner
Blows warm air but after a few mins turns to cold air...
Toget proper heat, keep your temp setting at 30+ degree and also mode in "heat"position. If still no heat, check your heating sensor for closed circuit by anOHMs metre.It it's with RV, check power to RV.If it's with heatingelement check power to element. If power is there but still no heat meanselement defective. Replace new heating element. Thanks.
Jan 02, 2011 | Kenmore 75124 Wall/Window Air Conditioner
My heil heat pump is not blowing warm or hot air
Assuming that the fan is okey, there's only one item to be checked, and that is the HEATING ELEMENT.
This answer is based from your comment that it is not blowing warm or hot air. So, I conclude that it is blowing air but neither hot or warm, only ambient air. So, unplug it, and check the heating element. It may need to be replaced to make it work. May this will
help you.
it u
Jan 10, 2010 | Heating & Cooling
Central heat does not blow hot air, just warm air weakly
Sounds like some of the elements are not working. You being in Florida they may not have put very many elements in. It was 61 degrees last week. I know because I'm a Dolphin Fan. You will need a current sensing meter to check the elements.
Jan 04, 2010 | Heating & Cooling
When the temperature gets in the low 30's the heat is not enough to warm the house. I turn the heat strip on but it doesn't warm the house up much. It will get to 72 no higher.
Not to bad 72. The unit may be a little undersized or some of the elements are not working. Must have a current measuring meter to check heat elements.
Jan 03, 2010 | Intertherm P3RC-030K Air Conditioner
Dryer not blowing warm air
If the air is not warm, very simply, your element is not heating. If the element is getting power, then you have a bad element. Good Luck. I hope you find this very helpful!
Nov 27, 2009 | Whirlpool Dryers
Heating Element on my A/C not getting hot
It definitly did not open the element the 24vac isn't enough. I would go back over the wiring.When your t- stat calls for heat you want it to energize both sequencers. the easist way to assure this is to connect the whiet and purple two gether at the a/h.
Mar 14, 2009 | Goodman CLQ36AR49 Air Conditioner
Jennair dishwasher jdb8910aww
Start by puting timer in heat dry for about 4 seconds and see if element got warm. If so check you rinse aid and make sure it is full. I like the turbo dry made by jet dry. If it is empty, this is your problem. about the smell, you would use a cleaner such as diswasher magic made by GE. If element did not get warm, put unit on heat dry and and test voltage at the element. 120 volts present replace element. if not check voltage at thermal fuse for 120 volts. If no voltage there replace timer.
Jul 26, 2008 | Jenn-Air 24 in. JDB8910 Built-in...
Whirlpool GEW9250 Electric Dryer Logo
1,196 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
