Question about Maytag Neptune MAH6700A Front Load Washer
Neptune washer walking across the floor
Neptune Washer walks accross the floor during spin cycle...hate this machine..have tried everthing.
  • 1 more comment
  • duckhead Jan 26, 2008
    The machine was bough in Sept. 06. It is not on a pedestal and has been leveled. It is on linolium flooring. It has done this since it was new but seem to be getting worse.
  • Anonymous Mar 15, 2014
    On the spin cycle it shakes a lot and moves accross the floor
  • Anonymous Mar 25, 2014
    The washer is jumping on the spin cycle
    Brigadier General:
  • 6,277 Answers
Although you say it's level I would recommend you try my method to make absolutely certain
So- I don't know your particular machine but the initial cure is the same.
It is necessary to ensure absolutely that the machine has all 4 feet very firmly on the floor, and I mean firmly ;-0)
Doesn't matter whether it is empty or not but switch it off then-
very firmly push one front corner diagonally into the centre of the machine and see if the machine moves or rocks AT ALL, even the slightest. If it does you will need the open-ended spanner which came with the (new) machine........which of course went missing a long time ago?!! An adjustable spanner will suffice.
Adjust the foot under that corner downwards until it is very firmly- almost pushing- against the floor but not so far that the corner lifts up!
If this corner did not rock do the same to the other.
Once you cannot rock the machine the slightest little bit, screw the locking nuts up tight to the underside of the machine so that they will not move. Ideally the rear feet should also be locked.
(If this has not cured the problem it is possible that the internal suspension is malfunctioning.)
Good luck! John C
Posted on Oct 08, 2011
We have no complaints about the maytag neptune, except that it walks across the floor. My wife just called Maytag at 866-616-2601 , and was treated great, they are sending some parts to fix the problem, free of charge, and we are to get them installed free of charge when parts arrive. When you call that number, ask for someone who specializes in the vibration problems. Our maytag neptune is model # mah8700aww.
Posted on Feb 27, 2008
  • vayankeroo Feb 27, 2008
    PS; Ours sits on a pedestal also,
  • 196 Answers
Need to know how old your machine is and if it is on a pedestal. What type of floor is the machine sitting on ?
Posted on Jan 26, 2008
Maytag washing machine walks across floor during spin cycle
Did you set the back feet before leveling? On most units to set and lock the back feet you need to pull the top towards you so that the back is raised off the floor, then set it down again, this will release the feet and lock then down. The you level the two front feet. After this is done you must make sure your load is balanced. Distribute the items as evenly as you can in the tub. Once it gets to the spin cycle if its walking or shaking a lot, stop it and redistribute the items more evenly in the tub. Also try not to overload the unit or combining many heavy items with few light ones. If this is a new machine, did you remove the shipping locks from the back before using it? They have plastic strips attached to them, make sure they have all been removed, as well as any shipping bolts.
Feb 17, 2015 | Maytag Neptune MAH6700A Front Load Washer
My washer walks across floor in spin cycle, machine is level
what make is the washer is it a Maytag Neptune or a Samsung Neptune and does it looks like this pic below
Feb 11, 2013 | Washing Machines
Model MAH9700 - Washer travels across floor in the spin cycle
I suppose that the repairmen would know than I would, but I do know that any washing machine that is not level will walk and vibrate and really shutter on the spin cycle. I would try to level (using a level on the top part of the machine that is flat, if there is such a portion) the machine so that all four feet (pads) are secure with their locking nuts up against the body so that they can't turn and cause the machine to go out of level.
Sorry I can't be of more help.
Oct 12, 2009 | Maytag Neptune MAH9700 Front Load Washer
My Neptune washer (brand new) "walks the floor" during the spin cycle. How do I correct this?
Try to get it completely level and with all four feet firmly on the floor. If it's resting on three feet and/or not level then this is what will happen. The feet should be threaded so you can adjust them easily.
Aug 16, 2009 | Maytag Neptune MAH5500B Front Load Washer
Front load washer shakes violently during spin cycle
On something like this you will need to remove the washer wrap to inspect the suspension springs & base assembly. Please see the link provided for accessing the inside of the washer. Be sure the shipping pins have been removed. The tub should float freely.
Apr 03, 2009 | Washing Machines
I had this problem as well. I called dealer and Maytag. They made an appointment and stood me up several times.
I finally went to place that sells refrigeration equipment and bought an anti-vibration pad. It's a 12" square waffle pad used under large equipment to prevent them from vibrating loose on connected piping. I cut it into 4 pieces and put one under each corner of the dryer. Problem solved, in fact it worked so well that I stacked dryer over washer, placed pads between units and have not had a problem since. I also gained a lot of space in my laundry room as well.
Mar 04, 2009 | Maytag Neptune MAH5500B Front Load Washer
Unending Heavy Vibration on Spin Cycle - Maytag Neptune
level the machine, if you are on a wood floor it could be the floors fault, you could try using aanti vibration pads.
Feb 12, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune Series MAH5500BW loud noise during spin cycle.
very loud in spin cycle can mean a bad rear bearing, not something a homeowner would want to try to replace, parts would exceed 6-7 hundered dollars. you may have some extended part warr through the manufacture. still probly gonna be a 5 hundred when the labor is added in
Dec 06, 2008 | Maytag Neptune Washer
Maytag neptuneMAH9700 front load washer
Another computer generated flaw.The worst thing is alot of times that "flaw" can be a costly one
May 04, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune MAH6500
Sounds like some sort of broken support or spirng underneath. Flip it over and look. Expect a little water to run out though.
Feb 28, 2008 | Maytag Neptune MAH6500A Front Load Washer
Maytag Neptune MAH6700A Front Load Washer Logo
592 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
