Question about Minolta CF2001 Copier
Minolta CF2001 error code C3720
My copier is showing error code C3720.
1. Can anyone tell me what this error code means?
2. Can anyone tell me how to clear it so I can see if it comes up again?
3. Where can I get a list of what all error codes mean for this copier? (I have purchased the owners and service manuals- neither one contains this information.
Thank you
  • stepeq Jan 26, 2008
    I found answers and decided to post here.
    1. This code is for the original glass fan.
    2. There is a reset button you get to by opening the front panel and putting a paperclip into a small hole on the lower right side of the area the front panel covers.
    3. It turns out there are multiple books for both parts and service. The troubleshooting service manual has the codes in it. I was lucky and found these on the web.
    As for my problem, I used the reset button and all is working. We'll see for how long.
Original glass cooling fan motor turning at abnormal timing
Posted on Apr 17, 2008
What is Code C13CC
Enter in the service mode Stop0Stop001 press the trouble key or close and open the front door.
Nov 14, 2009 | Minolta CF2001 Copier
Minolta CF2001 has error coode C0060 after clearing a paper jam in the fuser unit.
well the fuser motor is jammed. remove the fuser and replace it. hopefully the motor is not burned out, and or worse the motor took the control board also
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Nov 11, 2009 | Minolta CF2001 Copier
Minolta CF2001 C410 error code
To clear the fuser error code, perform the following after correcting the cause:
1. With power ON, open the front door and locate the small, rectangular hole below the imaging unit removal tool.
Note: after opening the front door, it is in the lower right corner.
2. Insert a suitable object into the hole to actuate the reset switch.
HOPE THAT HELP
LET ME KNOW
Oct 14, 2008 | Minolta CF2001 Copier
Minolta 1080
how the code appeared?
I suppose you worked with the cyan low toner attention untill the machine stopped. in this case you should make an ATDC sensor adjustement! but firstly you should reset the error!
Jul 14, 2008 | Minolta CF2001 Copier
C0206 code meaning
press buttons in the exact order, utility-meter count-stop-0-0-stop-0-1. you are in service mode. now you enter counter - reset counters, or trouble and see the meaning of C 0206, if I well remember it's a corona wire problem! you can either change the wire and reset the error code or, in case that it wont work, to measure the tension at wich the corona charges!, probably the first thing will do the job!!!
Apr 11, 2008 | Minolta CF2001 Copier
COF37 error code
C0F37: Abnormally high toner density detected by Black ATDC Sensor
Toner density that is 4 % or more higher than the target level is detected ten consecutive times during a print1.gif cycle, ATVC, or image stabilization sequence.
The sensor for this error is in the black imaging unit not the toner hopper. See the steps below. If that doesn't work then visit my website1.gif for contact and I will sell you a full service and or parts manual on CD.
Step
Check Item
Result
Action
Imaging Unit Bk is installed correctly.
NO
Check and correct ATDC
drawer CN of imaging unit Bk.
Each of Imaging Unit Bk contacts makes
NO
Clean or correct.
good contact.
ATDC Sensor harness is open-circuited.
YES
Change Imaging Unit Bk.
Jan 20, 2008 | Minolta CF2001 Copier
KONICA MINOLTA CF2001 ERROR C0096
C0096 is an error with the transfer belt.
Jan 15, 2008 | Office Equipment & Supplies
MINOLTA CF2001
You need to change the EEPROM for the Black toner.
Look at the link
http://www.hcservicetech.com/konicodes/c350.html
Oct 31, 2007 | Minolta CF2001 Copier
Fault code C0500
That error code indicates a fuser problem. Most likely the heater lamp or thermistor is faulty. In either case it is definitely a job for a tech. Sorry John
Jul 09, 2007 | Minolta CF2001 Copier
452 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Marvin
Marvin
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
