Question about Sakar Kidz Cam Digital Camera
Software... Model 16380 I installed the software for this model at least 10 times and it keeps sending me an error report then closing the program. We havent even been able to start anything with this camera. If this is suppose to be for kids and and adult can't use it, then how is a child going to be able to use it?
  • 76 Answers
Re: Software...
0 characters
3 Points
What do i need to install Photomax with Vista?
The problem can be found where the DL for the program hasn't installed and as a result the software reports an error. Delete the program, fresh install in a new location and then try running it again. If it continues to crash, check your security settings for program installation to ensure this is not set too high thereby prohibiting the running of the program. If you are using an illegal copy of the program then the game is up and you will need to purchase the full program. If you continue to have problems and you do actually own the software then get in touch with the software company and let them assist you.
**You need either ubunthu or fedora 8
Nov 07, 2010 | Polaroid PhotoMax Fun 320 Digital Camera
Keep getting a code 1312x17x4252799284x and want install program.
I?m not sure if you?re fault code is showing on the computer, Easy Share Software, or the camera itself. Therefor I will list 2 possible solutions: If the fault message is on the LCD on the camera: There is no firmware available online for this camera model. Therefor you do need to set up a "repair" with KODAK directly. An Out of Warranty repair for this model for this fault is about 88 pounds + shipping. KODAK also offers a Trade up option where you will have the opportunity to trade up to a newer model 25-30% cheaper than the market price. In order to arrange your repair/Trade up: Contact KODAK: If you're experiencing this fault code on the computer: Please do a Clean Install on the Easy Share Software: Please follow the instructions: Uninstall Easy Share software: Select Start > Settings > Control Panel > Add / Remove Programs. For Windows XP operating systems, select Start > Control Panel > Add / Remove Programs. Select Kodak Easy Share software. Select Remove (or select Change, and then select Remove). Run the Clear utility: Visit the CLEAR Utility for Kodak Easy Share software Web page at Click the Download button, and then follow the on-screen prompts. After restarting your computer, visit the Kodak Easy Share software Web page at and install the latest version of Easy Share software.
Jan 20, 2010 | Kodak EasyShare One Digital Camera
I have a vivitar vivicam 10 digital camera. It is 640 by 480 pixels. it is an older model camera and I have lost or misplaced the software for the drivers and photo programs to instal it on my computer....
If you have WindowsXP, Vista or Windows 7, then your camera should be detected automatically, you just need to plug it in PC via USB cable. It should appear in MyComputer as new disk.
Jul 24, 2009 | Digital Cameras
Can not download CD for Saka model 16380
Click Here Click There And Once You Reach The Page Hit The Download Drivers Button To The Right Of Your Cameras Picture.
Please Rate A Fixya If Its Exactly What You Needed.
If Its Not Please Let Me Know.
Michael Scott
Feb 04, 2009 | Sanyo Digital Cameras
Software issues
There is an 'Easy' solution to this well known problem
Remove the software from the computer.
Out the CD back in the box it came in.
Windows does not actually need software to read a camera and there is plenty of free software out there that does work
Picasa for starters
Jul 04, 2008 | Kodak EasyShare Z740 Digital Camera
In this case u can contact sakar customer service# 8773978200 and they will send u the link of the software and drivers
Apr 24, 2008 | Sakar Kidz Cam Digital Camera
Transfer window
Model 16380. I installed the software onto my computer at least 10 times and it keeps sending me an error report. I have all of the directions, software, cords etc. and I can't get it to work. This is getting very frustrating because its suppose to be for kids. If I'm an adult and can't get it to work, how is a child going to be able to work it? Any suggestions?
Dec 25, 2007 | Sakar Kidz Cam Digital Camera
Can I use the PDC 1100 camera with Windows XP?
Yes, you can use the camera with Windows XP, but you will no longer be able to use a USB port to download your photos. Only serial port downloads are supported under Windows XP for the PDC 1100 camera. Follow the instructions below to reinstall the PhotoMAX software and camera drivers using Windows XP's Program Compatibility Wizard. 1. Insert the PhotoMAX CD-ROM in the CD drive. If the program begins installing, press OK to close the "not compatible with Windows NT" error message. 2. Start the Wizard by clicking the Start button and choosing All Programs > Accessories > Program Compatibility Wizard. Follow the on-screen prompts. 3. On the second screen, select I want to use the program in the CD-ROM Drive and click Next. 4. Select Microsoft Windows 98/Windows Me and click Next. NOTE: You may have to scroll down to see this option. 5. Uncheck the following items: * 256 colors * 640 X 480 Screen Resolution * Disable Visual Themes 6. Click Next. 7. Click Next again. The PhotoMAX software will begin installing. Follow the on-screen prompts. 8. Follow on-screen prompts to finish the installation and click Finish. 9. When the Compatibility Wizard asks if the program worked correctly select Yes and click Next. 10. When the program asks if you want to send information to Microsoft, select No and click Next to finish the installation. 11. Shut down and restart the computer. After the restart, you should be able to download photos using Windows XP.
Sep 14, 2005 | Polaroid PhotoMax PDC 1100 Digital Camera
Error Containing "0x123454" when installing software
Any error code beginning with "0x" is related to a problem with incompatibilities with the InstallShield program which is used to install all of the components. To fix this find the "InstallShield" folder on the computer (the location varies by computer OS, but is generally located in "c:\Program Files\Common Files\") and move the contents to a new folder on the desktop of the compter. If everything works well you can discard the new folder (and the old InstallShield contents). Run the Nikon installer again and it will install properly.
Aug 29, 2005 | Nikon Coolpix 5700 Digital Camera
Why can't my computer communicate with my digital camera?
The cause and solution may include one of the following: There is a problem with the configuration of the USB port on the computer.See the USB.html file on the EasyShare software CD. The camera is off. Turn on the camera. The battery is not charged. Recharge the battery. Some Advanced Power Management utilities on laptops turn off ports to save battery life. See the power management section of the laptop User's Guide to disable this feature. The USB cable is not securely connected. Connect the cable from the camera to the computer port. The software is not installed. Install the software. The software is installed incorrectly. Do the following to install the software correctly: Disconnect the USB cable. Close all open programs. Uninstall, then reinstall the software. (To uninstall, go to Start > Settings > Control Panel > Add/Remove programs.) Too many programs are running on the computer. Do the following to close all running programs: Disconnect the camera from the computer. Close all software programs. Reconnect the camera. The Battery Monitor or similar software runs constantly. Close the software before starting Kodak EasyShare software.
Aug 29, 2005 | Kodak EasyShare C360 Digital Camera
Sakar Kidz Cam Digital Camera Logo
183 people viewed this question
Top Sakar Digital Cameras Experts
Sanath Kumar V
Justice McPherson
Level 1 Expert
Are you a Sakar Digital Camera Expert? Answer questions, earn points and help others
