check primary fuel filter for diesel.If none take hose and blow back to tank.You should hear air bubbling. then try letting pump pick up fuel.You could have a clogged screen in the tank.
1995? it has 3 location 1 in the tank or on the side of the frame, more likey your fuel pump is in the tank and if in the tank the hose that feeds the FD in the tank is leaking, and thus no pressure to the fuel distributor
Follow the fuel line from the fuel tank to the engine. If it has an external fuel filter you will find it. If you find none then it has a fuel filter in the fuel tank that is non-replacable.
that particular model has an external fuel pump is located underneath and if you take the rear driver side wheel you will get to it easier but not if you are going to replace you fuel pump replace the fuel filter also or otherwise the new pump will not last. and have a large container handy because wend you take the fuel pump off. you will spill a large amount of gas . the tube going from the pump to the gas tank in on the bottom of the tank and will spill all the gas in it unless you move quickly.
