Question about Sony PlayStation Portable (PSP) Console
UMD ejection switch replacement
My PSP is missing the UMD ejection switch. I have a new one ordered, but not quite sure how to go about installing it. I've never tried to repair electronics myself, so any help would be greatly appreciated.
  • sprucecourt Jun 17, 2008
    To:shamrock8088. I just came across your post. What was involved in replacing the UMD eject switch? My son's broke and I found a cheap replacement on Ebay but I wanted to see how involved this is before I order and wait on it. Thanks!!!!
    Problem Solver:
  • 4 Answers
Lick it
Posted on Jan 26, 2008
Error 80010087
Check the firmware of your PSP. Some games may not work if the latest firmware is not installed.
You usually get this message if the UMD has errors reading or the UMD is not present or was ejected in the middle of playing a game. You should try testing your PSP with other disks, if it doesn't have the same problem with other disks then your UMD is most likely scratched or damaged.
If you are using a modded PSP then you will get this error if you load a game from the memory stick without having a disk inserted in the drive. Or if the game that you are trying to load requires a higher firmware version. You will need to install a higher modded firmware to fix the error if that is your case.
Hope this helps.
Jun 29, 2011 | Sony PlayStation Portable (PSP) Console
When I switch on my PSP, it directly goes onto load the UMD game and when I try to quit using HOME button, the buttons and consoles dont work. Then I need to use the hold button after which though the...
Hi. Since you're in UMD Autoload mode, you need to configure that in the PSP Settings. To do this, turn off your PSP and remove your UMD. Now, turn it back on and it won't autoload your UMD since it wasn't there anymore.
Now, go to "Settings" and scroll down to "System Settings" and press X. Scroll down again the selection until you see "UMD Auto-Start" and press X. At the right side will appear the options "ON" and "OFF". Select "OFF" and press O button several times to go back to main screen.
Insert your UMD. Now, try playing games from Memory Stick. You may have to turn off your PSP and turn it on again to finally play homebrew...
I hope this helps...
Jun 07, 2011 | Sony PlayStation Portable (PSP) Console
How to put a game on psp?
Behind your PSP there is a circle in which is written PSP. Try to push it and the disc ejects, then put your new UMD inside and play. To play you have to gao to the UMD in the menu and press X on the keypad.
May 16, 2010 | Sony PSP-3000 Black Console
Can't replace plastic umd cover
There are 3 types of PSP around, starting with model number 1000,
this is the first PSP also known as PSP Fat.
PSP model 2000 series, wich has a better screen and more memory on board, it is also thiner als the previous model.
PSP Model 3000 series wich has a microphone and a better screen.
The body parts of all PSP models are diferent, this has to do with the placings of internal hardware components.
Remove the battery from your PSP, underneath is a sticker located with
the model serial number, if you know the serial number, you'll know for what PSP type you need to order parts for.
Jan 18, 2010 | Sony PlayStation Portable (PSP) Console
The UMD icon ony PSP is not displaying?
the umd icon does not show on my psp?
Jan 01, 2010 | Sony PSP (Piano Black)
Psp error # 80010087 The game can not be started
Hi robbimic,
The first thing to check is the firmware of your PSP. You should make sure that your PSP has the latest firmware loaded. Because some games will not work or load up if the latest firmware is not installed or loaded up.
You usually get this error message 80010087 if the UMD drive has errors reading the UMD disc or otherwise the disc is not present or was ejected while in the middle of playing a game or loading a movie. I suggest that you try to testing to see if the problem happens with other UMD discs, if it doesn't then most likely the disc could be damaged or scratched.
Now if you are using a modded PSP then you will get this error if you load a game from the memory stick without having any UMD disc inserted in the drive. Or if the game that you are trying to load requires a higher firmware version installed into the PSP. You will be required to flash a higher modded firmware to fix this error if this is your case.
Hope this helps!
Peace! :)
Oct 21, 2008 | Video Game Consoles & Games
Where is the UMD?
UMD is Universal Media Disc, its a small disc are used for PSP.  press the "eject" button on the top to open the disc tray. Usually the problem its not from the UMD, but from the console.
The first check the version you are running on psp, >> Go to the PSP Menu and move across to the "Settings Menu". Scroll down, select to "System Settings" >> "System Information" and you should see version of your PSP. If the UMD has a high version than ur console, u need to update ur psp.
plz visit my blog, for psp update guide.
Oct 28, 2007 | Sony PlayStation Portable (PSP) Console
Psp
Hi Jleew,
You should check to see if another UMD will work first.  Also try them in another PSP.  If your sure your PSP is not reading Discs, then and only then, Clean the Laser lens carefully.  Using a strong flashlight and magnifying glass, look into the UMD drive with the UMD door open and look for debris like hair or lint, and also dirt and dust.  A black switch pokes up on the left inside the UMD drive.  Its a little black stick.  When you press down on this Black stick, your UMD disc motor should spin for  second or two.  The UMD laser lens should light up when your press this switch.  If any of this does not happen, you need to replace the UMD drive. If you need someone to do this which if you have never done it, you need some knowledge big time.
I can do this for you if you're in the USA for $55 including a New UMD drive, REturn Shipping, and 90 day warranty. Contact Repairtech@playstationclinic.com
Oct 23, 2007 | Sony PlayStation Portable (PSP) Console
Psp
Here ya go !! http://store.richspsxparts.com/pspbainumddo.html
Aug 03, 2007 | Sony PlayStation Portable (PSP) Console
Sony PlayStation Portable (PSP) Console Logo
42 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
