Question about Sony FD Trinitron WEGA KV-36HS20 36" TV
Sony Trinitron KV-36HS20
When I hook up anything to comp 1080i the set has bars on top and bottom. Why
I have this set also..
When you set up for an HD signal (1080i) it is broadcast in 16:9 which is a widescreen format. The Sony set is a 4:3 format (more of a square shape) which means the black bars at the top and bottom appear so that you get the widescreen 16:9 format to appear.
This is one of the main negatives I have about this set, however, I can't really complain as I have had it for 6 years and it works great.
I never knew about the other format until I got an HD receiver from my satellite dish provider last year.
Hope that helps explain it for you..
Posted on Feb 02, 2008
3" black bars top and bottom of screen. Can't
either you have the video setting of the television set to wide screen or you are purchasing "WIDE SCREEN" format dvds instead of "FULL SCREEN" format dvds
Oct 12, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sometimes picture is good,other times no picture at all
There is an intermittent problem in the video stage of the circuit board, probably due to bad solder joints that need to be addressed.
Feb 06, 2011 | Sony FD Trinitron WEGA KV-36HS20 36" TV
Want to know if my soney wega trinitron is hd compatible
is hd compatible but your hd will have black bars on top and bottom and shrink your tv to about 19"
Jun 02, 2009 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Top of screen slants on the right and left side horizontally
go in touch with SONY i assume ur set is still under warrenty.....call customer help and support
Mar 12, 2009 | Sony FD Trinitron WEGA KV-36HS420 36" TV
Sony wega kv-36hs20 will not turn on
SEVEN Blinks---High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits.
Mar 02, 2009 | Sony FD Trinitron WEGA KV-36HS20 36" TV
Sony vega kv-36hs20
Have just posted this - twice, elsewhere - I'm afraid the sets are getting old:
"I think you are either suffering from a failed power supply or the supply is cycling because of a 'downstream' problem that could be in the high voltage circuit. In each case, the blink count probably would tell you approximately where the problem is located but only a Sony tech will have access to the codes. After all, we are only mortals.  "
Aug 25, 2008 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Problems with Sony FD Trinitron WEGA KV-36HS20
The set is going in to the protect mode.
There are some components that have become thermo sensitive from age and use. After the defective parts come up to their operating temperature they go out of specs.
Most of the time this type of problem comes from the power supply. Sometimes it is from another board that is causing the shut down.
The fix is to start by replacing the power supply for a start. If there are still any faults, the tech will try the boards to zero in on the defective one. Once he locates the defective board, if it is not worth to service, he will leave the new board in the set.
This type of repair can be in the average range between $200 to the $500 range depending on the exact fault. This is providing that the fault is not inside of the screen itself.
Jerry G.
Jun 02, 2008 | Sony FD Trinitron WEGA KV-36HS20 36" TV
Kv-36hs20
Have you tried disabling SVM (scan velocity modulation)? Often touted as a "feature" of TVs, it's a way of artificially making a picture appear sharp. Totally unnecessary. When SVM (sometimes called VM) is on, it can lead to some color bleeding around edges.
Mar 24, 2008 | Sony FD Trinitron WEGA KV-36HS20 36" TV
Need to center the picture
This is a defect in the vertical scan amplifier. It is not an adjustment. Most of the time there are a number of capacitors in the vertical deflection amplifier that can cause this type of fault. Sometimes the output drive IC can cause this fault, but more rarely.
An experienced service tech can locate the defective parts and replace them. The average time involved is about 1 to 1.5 hours.
Jerry G.
Dec 30, 2007 | Sony FD Trinitron WEGA KV-36HS20 36" TV
Picture Shaking
Do you have any big speakers or some other appliance near the TV?
Magnetic fields make the screen images 'shake'.
Dec 09, 2007 | Sony FD Trinitron WEGA KV-36HS20 36" TV
Sony FD Trinitron WEGA KV-36HS20 36" TV Logo
103 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
