Question about Polaroid FLM-323B Television
Black screen with sound
TV works great for about 30 minutes. The screen goes black the sound and the remote still work. I leave it off for 15 minutes and it works for about 10 minutes more before it goes out again. I found a swelled capacitor on what I assume is the power supply board for the lights. I replaced it with the same type cap. This didn't solve my problem. Any ideas?
The TV lasted a little over a year & I'm glad I didn't get a warranty. A repairman estimate was $512 but he is still waiting for a control module replacement for other customers. They purchased the exteneded warranty but have been waiting over 6 months for parts that are still not in. I trusted the Polaroid name, my mistake to trust a name.
Posted on Feb 15, 2008
Screen goes black on toshiba tv how to fix
I would check to see if any capacitors have gone bad or are going bad.
Oct 07, 2012 | Toshiba 32A60 32" TV
Screen goes black after 30 mins of working.
There are a few things you need to check here.
1. It could be that your computer power management is set to turn your monitor and harddrive off after 30 to 45 min.
If the computer is however working for 30 to 45 min while you doing stuff and it shuts off, the there is an internal problem "Hardware"
I would suggest you check to see if the power management is set to turn off monitor 30 min and harddrive after 45 min. IF that is not so, then we go on to the next test.
It could possibly be your processor fan is not working so once your processor gets over heated it shuts off the computer.
Turn off the computer, remove the case "this is only if you know what you are doing" with the case off, power on the computer and see if the processor fan is working.
You can get back to me and I can walk you through it.
Hope thiss help.
Aug 23, 2009 | Dell Dimension 5100 (D51L1) PC Desktop
The image leaves and the screen goes black.
Either the picture tubes are going, or they are dusty. Take apart the front grill and take off the black cut away behind the grill. Inspect the tubes and the circuit boards. If they are dusty blow them off with an air can duster. It might work and its free and takes 5 minutes.
Mar 23, 2009 | Sony KP-61HS10 61" Rear Projection...
Well, not completely true; the fluorescent backlight is still a high voltage device, even if only hundreds of volts instead of kilovolts, and either the lamp(s) or the power supply for it (them) is causing the dropout of your picture. When it does it next time, look at the screen from various angles, I think you will see that video content is still there.
Jun 05, 2008 | LG 47LC7DF 47 in. LCD HDTV
Screen goes black with sound
the lcd control board is out side the control box, its probably the culprit, its under 20 dollars new. the swollen cap means that its getting too much voltage to that component. better do voltage checks on the power supply each transformer is labelled for voltage output make sure its providing the correct voltage and not surging, this can cause the tv to fail with serious problems. now mr zuzu13 you need to have the tv on a surge protector and be careful not to let it arc when plugging in. you also need to do the same checks as above its most likely a power supply problem causing the shut downs. also reset your tv to factory settings by punching in 8282 on the remote this might also solve your problems. but dont forget to check the power supply now it might save you a costly repair.
Jan 25, 2008 | Polaroid FLM-3232 Television
RCA HD61LPW42 runs for an hour then pic goes out for a minute and comes back
sounds like another crappy color wheel issue, just like my samsung hln617w.
Aug 04, 2007 | RCA HD61LPW42 61" Rear Projection HDTV
Screen problem
this may be a problem of a loose component, looking through the main board and soldering loose components, IC, transistor, all components, just have patience, this may solve the problem.
May 14, 2007 | Sharp 27H-S60 TV
Screen tuns black after 15 seconds and comes back after about 15 minuts
The solder joints on the vertical output IC have cracked. This is a very common problem on those sets.
Nov 14, 2006 | Panasonic CT-27G34 27" TV
Polaroid FLM-323B Television Logo
149 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
