Question about Toshiba 19A26 19" TV
Volume goes full blast when turned up from zero to just a "1" onscreen
This set has a good picture, but when you turn the sound all the way down it is queit, of course. as soon as you hit the volume up, and it goes to a "1", the set blasts with volume. i tried to change the audio output, but no difference.
I am a tech, by the way...have never seen this, though...
Please help with any info...
Thanks in advance,
fred
    Problem Solver:
  • 4 Answers
I have seen a similar problem. get to design mode (that trick with the remote mute & the set menu button) & look for a data address in the audio section that is set to all (F)s. sorry i can't remember the exact address. you could always just guess just make sure you write down where they are currently set .
Hope this helps.
Posted on Jan 28, 2008
Power is hooked up. Ground is connected. Both subs are connected. The triangle light is red, and there is now sound. All wires are hooked correctly...
on most amp red isnt good that means it in protection mode try turning your setting on the amp down all the way and turn the volume down tell you can get sound out of them then turn up the volume to were you would to them most and set the to what sounds the best but make sure the light doesnt dim down when the base hits
Jan 16, 2011 | Kenwood KAC-7204 Car Audio Amplifier
I have a RCA XS Stero TV. I don't have remote. I connected DVD player right connections. But I am not getting any picture in the Screen. Actully it is showing Blue screen all the time. No TV picture also....
Sounds like you're stuck on..... Video 1 or Video 2 (whichever). If you can access your TV's menu at the front panel, you should be able to switch over fairly easy. Hit MENU. Using your VOLUME UP & DOWN buttons, Go to CABLE/SATELITE/ANTENNA, hit VOLUME UP or DOWN 'til it switches back to TV picture then hit ENTER. If you do not have an access panel in front but possibly have any other remote (cable or satelite or home theater, etc...) that can be paired with this TV and has an INPUT button, you can change the setting that way.
Hope this info was helpful. Good Luck!
Jan 29, 2010 | RCA Televison & Video
Lost remote, blue screen
Jan 29, 2010 | Mitsubishi VS-50611 50" Rear Projection...
No sound (ringer, keyboard, etc.)
You may have hit the mute button, you may have turned the volume down using the buttons or you may have accidentally put it in airplane mode or another mode where "sound off" is specified.
Hit the volume mute button, hit the volume up button, go to settings for the volume option, go to the settings menu and change the mode that the phone is set to a standard mode
Dec 18, 2008 | Cell Phones
Picture trouble
Good Day, britt93;
It sounds like you have the TV's CLOSE CAPTION on; in the text mode, turn off and you and the TV will be fine.
Good Luck, big IRISH.
Aug 21, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Volume up then pic gone
Good Day;
The TV's front panel may be bad, manual buttons. TEMPT FIX; remove speaker, cloth covered, cover, disconnect cables. TV will work but only with remote.
Good Luck!
Jun 12, 2008 | Mitsubishi WD-52525 52" Rear Projection...
MPVR+ CB Picture Sound
I have this camera and unfortunately there doesn't seem to be a way to turn that sound off. It's odd because I have an IS-DV2+ also and if I turn the volume all the way down, that sound is muted as welll. I don't know what goes on at Aiptek...
Dec 14, 2007 | Aiptek MPVR Digital Camera
Sound Stuck on High
change the audio ic it has a short within.this will restore your set to normal dont forget to make checks in that same circuit as there might be resistors,diodes or caps that had contributed to the failure of the ic.good luck.
Aug 03, 2007 | Toshiba 19A25 19" TV
Mitsubishi WS-65711 Volume
have a tech repair your set the problem is in the eeprom circuit or the audio circuit.good luck.
May 13, 2007 | Mitsubishi WS-65711 65" Rear Projection...
Volume goes up on its own and stays up.
Aren you sure that the volume up button is not stuck in . It should feel just like the rest of them A little click? It could still be shorted,or the capacitor across the switch could be defective. If all this seems good then the eeprom, or the microprocessor,or the line or trace going to the volum button could be shorted. This is not a repair you should attempt unless your a tech. Now the button thong can be looked at after the set is unpluged and the back is off, gently slide out the chassis toward the rear of the set just a little and slide it back to see if the button is released. if that dosent help then you will need to take the set to The repair center. Good Luck
Jun 10, 2006 | RCA F31672ET TV
Toshiba 19A26 19" TV Logo
99 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
