Question about Pioneer SD-P50A5-K 50" Rear Projection Television
Volume loud and quiet when tv is first turned on
When I first turn on my TV the sound goes extremely loud then quiet. After about 10-15 min it usually settles down.
Sometimes it might do it a few more times after the 15 min.
  • Pioneer Master
  • 5,138 Answers
Your set must have cold solder joints,this means once set gets hot enough that connections are then made correctly,this will not stop untill you have someone solder all cold solder points.
Posted on Jan 31, 2008
My vizio tv is practically brand new as of christmas, when a movie or even tv is on the voices are very soft and the music or background noises are EXTREMELY loud, so I am always turning the volume up and...
I had this problem with my previous TV (Syntax by Olevia, an off brand). It only happened to me on certain channels, and for certain shows. What is happening is the TV station is broadcasting the audio in Dolby 5.1 format. For some stupid reason, the TV is playing the background speakers (effects) instead of the speaking parts. You get a little bleed-over of the voices into the back speakers, so voices are there but really quiet. Unfortunately my TV didn't have any surround sound options to fix this.
See if your TV has a surround sound option. Otherwise, you will need to connect the TV sound output to a surround sound system that can properly decode the audio channels.
Feb 06, 2011 | Televison & Video
Movies will play fine however the music is at normal volume and the voices are very quiet. To hear them you can turn it up but then music is too loud.
This might be your TV many of the SONY and PHILIPS TV's have an Auto Volume control setting that is used to prevent the TV advert music from being too loud compared to the programs try turning this ON and OFF and see if it helps.
Jun 16, 2010 | Toshiba SD-2150 DVD Player
32 inch tv goes from normal sound during program to extreme loud
May be a defect but, if you notice the sound changes with different channels or movies or HD or Standard, look for a volume limiter control button in the menu setup under audio control. Sometimes the menu has a control that you can turn on to limit different volume levels during the shows origination.
Mar 12, 2009 | Televison & Video
Picture comes in and out
you can fix this problem, your light bulb in the tv is on its last leg, and needs to be replaced, usually around $100-$200.
Sep 30, 2008 | RCA R52WH73 Projection Television
RCA Wireless headphone triggers off after 35 seconds of operation
ya the volume of your source is your issue.
if it is too low, the unit cuts out after 45 seconds or so...
crank up the volume and turn it down on your headset
Mar 16, 2008 | RCA WHP140 Consumer Headphones
Sound won't turn down
Change out your audio cables ,if this does not work some where you are missing ground.or its not connected right.ThankYou for using FixYa. Have a Nice Day.
Feb 17, 2008 | Toshiba 51H83 51" Rear Projection...
The Output Volume Is Extremely Low!
Sometimes the rear channels can be used as a 2nd zone. Does the unit have A&B speaker selection on front panel? Usually if it has a 2nd zone it will say in owerns manual or on back of unit or on front panel as well. That is when you have the option to adjust the volume in the menu on the 2nd zone. GURU JAY
Feb 07, 2008 | Sony STR-DE545 Receiver
Sony STR-DE475 - Sound levels dropping
When did this start? Did it ever work right?
How's the sound from your TV speakers by itself and from DVD? The same? Problem's in the TV.
If it's just the receiver doing it from both sources that's where we start.
Check the settings for dynamic range (ratio of loud sounds to soft sounds) in both your receiver and your cable TV tuner. Many devices have a setting sometimes called "MidNight Mode" to be used in the event you're listening while someone else might be sleeping or otherwise would be disturbed by the TV volume.
The assumption is that you will turn the TV down but that normally means you would lose the quiet programming in the background nosie of your home. Through the magic of dynamic compression the quiter sounds are raised to audibility while loud things like explosions and fanfares will be limited in volume. Depending on the design and whatever the broadcaster is doing to the sound themselves this could be anywhere from pleasingly effective to aggravatingly inconsistent with odd variations in the levels.
Hope this helps.
Dec 17, 2007 | Sony STR-DE475 Receiver
Samsung TXE1370 13" TV - volume out of control
try this..turn off ur tv by remote,press mute followed by 187 then power,if this work u shall see reset underneath the sub menu goto reset..the tv must turn off and on.donot explore other u might kill your tv!!
Feb 25, 2007 | Samsung TXE1370 13" TV
Pioneer SD-P50A5-K 50" Rear Projection Television Logo
94 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
