Xerox 416 Fuser
My paper jams in the copier as it enters the fuser. Do I need to replace the fuser or is their a repair solution?
  • snow0811 Jan 26, 2008
    Thanks a bunch. Well, I did try the blank sheet. Still the same. I removed th fuser and found the large gear on the right side broken. Hence m problem! Can I replace the roller or do I have to order the complete fuser? If so where can I get parts or a new fuser other than Xerox.com? Thanks
  • 239 Answers
If you are getting fuser acordian jams, it sounds like its the stirpper fingers on the fuser. They need to be replaced because the tips brittle and break off.
If the paper stalls in that area the fuser jam switch may be broken or the tip of that has brittled and broken off.
Also the plastic baffles after the paper leaves the fuser may be warped out of shape causing unlevel arrangment of copy exiting the fuser.
There are other problems that can cause paper jams including the exit fuser transport binding.
A service call may be needed on this machine because of the extensive involvment in troubleshooting and repairs.
Posted on Oct 17, 2009
I HAVE A WORKCENTRE PRO 40 XEROX. SOME TIME THIS MESSAGE COMES FUSER NEED SERVICE. I HAVE CHECKED THE FUSER ITS WARMS UP BUT SOME TIME IT DOESNT. ANY SUGESSTION OR SOLUTION.
Posted on May 12, 2008
This is the part you need:
http://www.precisionroller.com/gears-for-xerox-workcentre-pro-416/details_28533.html
but installing it can be tricky. It may be worth it to ask for Xerox to fix your fuser
Posted on Mar 19, 2008
  • 81 Answers
Check at precision roller. They stock fuser parts for the 416.
Posted on Feb 29, 2008
New fusers for this model are expensive. Xerox parts guide does not itemize individual fuser parts, just the entire unit.
I have a used fuser if you are interested. candman44 @ yahoo.com
Posted on Feb 01, 2008
    Scholar:
  • 53 Answers
Is it getting thru the "pinch of the fuser and catching on the stripper fingers? If so clean the fingers, ensure they are not worn or tips broken.(Running sheets with dark lead edge can cause sheets to stick to rollers,try running blank sheets to clean up, if they get thru then try normal copies)
If the sheet stops before entering the rolls more likely to be dirty entry chute, drive problem or sensor problem....need more detail
Posted on Jan 26, 2008
  • Anonymous Jan 27, 2008
    Xerox does supply drive gears separately for some models, but not all, they want you to spend your money! Local dealer might be able to help, or if you catch them in a good mood might have a fuser that has failed in some other way.( See if you can catch the tech "on the side") I don't think anyone else can help you
6ya staff
SOURCE:
I have paper jammed in Xerox 7700 rollers and cannot remove even though I release the green lever on right side. Do I need to release something else?
The green lever you are referring to are I'm assuming is on the fuser. If the paper is jammed in the fuser and you are unable to remove it try removing the fuser and trying to remove the paper again, there are two thumb screws that hold it in. Make sure the printer has been off for awhile because the fuser gets VERY hot. If paper is constantly jamming in the fuser or you are unable to remove the paper you should replace the fuser, part number 016-1887-00 iteminc.com offers them for $$235 new and $139 for a refurb. Hope this helps, good luck
May 16, 2011 | Xerox Phaser 7700DN Laser Printer
Phaser 6250 DP keeps on jamming at Fuser.
Paper type set correctly? Does the paper enter the fuser? If not, the fuser drive has failed, replacing the fuser may correct it.
Nov 19, 2010 | Xerox Phaser 6250DP Laser Printer
FUSER GETTING OVER HEATED IN XEROX PHASER 7400.SOMETIMES A4 PAPER GETTING JAMMED IN FUSER ,WITH A3 PAPER THERE IS NO PAPER JAMMING PROBLEM.
try to clean paper feeding rollers and chek fuser paper sensor, maybe paper comming too late...chek this just to be sure all its OK whit paper path and fuser.
...or replace fuser module!
Aug 23, 2010 | Xerox Phaser 7400DN Laser Printer
Xerox M15i has a paper jam 2 error, how to fix
Hi, open the right side as if you were removing a jam. You will see 4 silver phillips screws. Remove them, unplug the fuser and slide it out. I think you will find either a paper folded up in the fuser or in the paper path just past the fuser.
The fuser itself probably needs rebuilt or replaced.
Take care
Jul 19, 2010 | Xerox WorkCentre M15i Laser Printer
XEROX PHASER 6180 SAYS PAPER JAM, I CLEARED PAPER JAM, PUT IN NEW CARTRIDGE, AND IT STILL SAYS PAPER JAM
Check the fuser for paper stuck in it.
Check that the 'paper out' sensor arm (in the fuser) is not broken. If it IS broken, you'll need a new fuser.
Mar 16, 2010 | Xerox Phaser 6180N Laser Printer
Xerox M15i paper gets jammed above the fuser "paper jam 2" fuser is hot but i think its supposed to be. Almost every sheet gets jammed.
Yes it is supposed to be hot. Let is sit off for an hour.
Open the right side as if you were removing a jam. You will see 4 silver phillips screws. Remove them, unplug the fuser and slide it out. I think you will find either a paper folded up in the fuser or in the paper path just past the fuser.
Sep 29, 2009 | Xerox WorkCentre M15i Laser Printer
Paper Jam E2 error
On this model, the fuser assembley is mounted to the machine mounts, two of them inboard and outboard.
If the fuser gear is not cracked, this fuser is driven by the white small drive gear on the machine.
This rests close the drive gear. Sometimes you can hear a thumping noise which is coming from the gear skipping over the fuser gear.
This gear needs to be replaced a very involved service process.
Call Xerox for further repair if this is the case. Also behind this gear are many other gears that can cause this same problem. Very involved and time-extensive to repair even for a trained Xerox technition.
Aug 11, 2009 | Xerox WorkCentre XD100 All-In-One Laser...
My workcentre Pro 416 shows a jam, i have removed all jams that i could see. However it shows clear jam, and has 19 to dos on the screen, like open door, clean jam, close door, etc.. Is there a major reset...
On this 416 machine, there is one place you cannot see a jam.
Looking at the machine the right side doors need to be opened.
The lower trays feed paper and need to go up the by pass feeder area.
Just lower and behind the by-pass feeder the paper can get stuck, and you cannot see it.
If you try to push a card stock up from the bottom, the paper can be pushed out.
The other area is at the fuser. If the switch is worn it will not drop back into position. The tip of the switch wears and breaks off.
It is rare a sensor goes out on this machine, besides the fuser sensor. Each paper feed head needs to be checked to see if the paper sensors are bad.
Not seeing the machine, call Xerox for service repair if not resolved.
Jul 15, 2009 | Xerox WorkCentre Pro 416 All-In-One Laser...
Xerox Workcentre 24- Paper jam in the fuser
Shut down. Unplug!!! Remove fuser to remove jam. Fuser may be or be going bad.
Apr 22, 2009 | Xerox WorkCentre M-24 Color Copier
Phaser 7300N paper jam
What code is comming up with the jam? That would help me narrow it down for you.
Apr 05, 2008 | Xerox Phaser 7300DN Laser Printer
487 people viewed this question
jasbo
jasbo
Ekse
Marvin
Marvin
