Question about Nintendo DS Console
Fitting a new case.
I dropped my ds and broke the case, so have managed to get a new one. The only trouble is that you are supposed to put the wire that attaches the top and bottom through a slot in the bottom part. How can i do this when the wire is attached at both ends. Don't want to pull the wire incase I can't get it back together. Any ideas welcome.
  • corinne1 Jan 26, 2008
    Thanks for the help. Didn't want to pull at wire incase it snapped, but now i know it doesn't i can fix it. thanks again
    Problem Solver:
  • 8 Answers
Check You Tube for a video that shows how. It is a tough repair, and I would not recommend the average person attempting it.
Posted on Feb 07, 2008
    Problem Solver:
  • 6 Answers
The ribbon wire comes off the motherboard by carefully lifting the black plastic at the frontedge in the connector. This releases the wire allowing you to thread it through the case and then re-connect it.
Hope this is of help to you.
Graeme.
Posted on Jan 26, 2008
Installing the monitor on HP Jornada 568?
ask hp,?
we are not HP
we be fixya
keep in mind that thing you have is legacy obsolete.
here they are real HP;
https://h30434.www3.hp.com/
Dec 27, 2017 | HP Jornada 568 Pocket PC
My ds broke
You can't unfortunately. If the system is completely fried, then you're out of luck. I'd suggest, for now, drying it out and putting in a new battery. If it doesn't work, you'll need to replace it.
Nov 08, 2009 | Nintendo DS Console
Ds lite top screen
Yes its fixable but it depends on what has broken.
There are two possibilities the small barrel hinge has broken, this is just a case of fitting a new one by opening the case, unscrew the light and gently pulling the top of the case away till you can change the barrel hinge.
The other one is the case has broken and is not holding the barrel hinge, can bodge it with some glue sometimes but most often you need a new case.
Jul 09, 2009 | Nintendo DS Lite Console
Code manager connection
CD is in drive: Plug in the DS and turn it on (going to the update screen on the DS), this -might- prompt you about a new software that has been plugged in and ask you to install the drivers for the "NDSLink" With the CD in the drive, it will find the drivers for the NDSLink
Wire Wiped Clean: It isn't the wire that needs cleaning but it's the pins, if the Pins need cleaning use an alcohol solution (Damp, not soaking). Otherwise pinch the wire and run your fingers across it to straighten the wires within the cord without pulling (pull too hard and you'll rip the wires) Though do note that exposed wires are not a good thing. If you received your cord with exposed wires, return the Action Replay and its accessories promptly and get a new one.
DS is Open: Again, your DS needs to be on in order for the computer to recognize that it's plugged in. It's the Action Replay that the Code Manager on the computer talks to, not the DS. The Action Replay needs an electrical current going through it to tell the computer that it's turned on. DS on = Action Replay on.
Other possibilities that are not explained: Did you happen to drop the Action Replay? Damage from falls is completely possible and ruins the state of the Action Replay, causing it to come lose easily or not work properly. I have needed to replace my Action Replay due to these accidents before.
Where was this Action Replay bought? If you bought it from a exchange store, you might have gotten a DS that was damaged before you got it (It happens), so if it is not too late, return it, and get a new one (Depending on the price difference between new and used in your area, for me it was a $5 difference)
Nov 12, 2008 | Panasonic DMR-E85H DVD Recorder
Ds lite
yes the new shell has this piece it's just not in the photo, it's in a bag not seen in most photos, you can replace this for about $25.00, or use a repair service on ebay
Aug 25, 2008 | Nintendo DS Console
Nintendo ds lite
Hi  Im  Patrick here  to  help.First  go  to  a  GAMEFREAK  store
Mar 14, 2008 | Nintendo DS Lite Console
Dropped and broke !
If your pretty good at dealing with small wires and parts there is a guide I found dealing with this problem
http://www.instructables.com/id/S405TMEFA0CVIFR/
Hope this helps and good luck repairing your son's DS Lite.
Jan 14, 2008 | Nintendo DS Lite Console
DS power problem
Hi Nerts,
These cables or ribbon cable and wire connects directly inside the upper LCD monitor. it is not feasible to replace these wires only.  I suggest you see about getting a replacement upper LCD screen which will give you the wires you need and a new screen to boot. Another porblem is the case itself is very hard to disassemble.  You will come near destroying the case to ge to the lcd.  You must disassemble the unit fully and put the correct curl in the ribbon cable to get it to fit right. In short, the price being what it is for a replacement LCD, and the trouble you have to go though to get this problem fixed, It may not be totally worth repairing. If you dont care and wish to do a repair, then my wishes for luck are with you.
Oct 18, 2007 | Nintendo DS Console
Nintendo DS Lite top screen broke on one side
The only way you can repair this properly is to replace the casing with a new one... the hinge is a common problem and over 90% of my customers on the DS and DS Lite need a new case due to broken hinges. Once the plastic bit has broken then it will only get worse. The small bit that you say fell out was the actual hinge itself (a small black part with a silver end that twists and locks your console into place when open). Hope that helps!
Aug 21, 2007 | Nintendo DS Console
Nintendo ds hinge fix
Well, you can buy a hinge from a lot of places, but the wire that broke, you are going to have to try and fix the wire, get it connected again so that it will work. The only other solution is that you will have to send it in to get fixed.
Aug 08, 2007 | Nintendo DS Console
Nintendo DS Console Logo
41 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Zhenya Ogorodnikov
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
