Hello there, I have Bissell Vaccum Model 6579 3...and it's not picking up the garbage..it works but nothing in going in the garbage container. Can you tell me how i can fix it.
That is the problem with the bagless cleaners. The dirt goes through the cup, directly to the filter. There is nothing to keep them seperate. You can try putting a single layer of paper towel against the filter. It will provide a breathable barrier for the dirt but, it will clog too.
You can purchase a wide variety of high quality Bissell replacement parts for your Bissell vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
You can cut the bad section of wire out of the cord, cut the insulation on the cord to get to the wires. Match your colors, strip the insulation from the individual wires and twist together. Wrap each wire with electrical tape (making sure no wire is exposed, can be a fire hazard), then wrap the cord with electrical tape. The cord will be a little shorter, but should work fine.
Could be plugged, check the hose and at the bottom by the brush roll, the inlet maybe clogged. Also check the filter under neath the dirt tank. There are filters above the dirt container, clean those out. If after that it is still loud, then maybe the motor fan or bearins are bad and will have to be replaced, part #2031214 sells for around $55.
