Question about Radio Communications
Desk top radioscanner want scan can u help me
Pro 2018 200 channel desktop scanner
  • 204 Answers
Po66, first off this is a nontrunking scanner. Do you know the freq. coverage style for your area? Some are still the old standard, some are trunktracking, there is different versions of trunktracking and most are not compatable. I have very limited info to work with, so I'm going to take a best guess. Here is a basic guide for your scanner.
http://support.radioshack.com/support_tutorials/communications/20-424.htm
If your needing freqs for your location, go here.
http://www.radioreference.com/apps/db/
I hope this helps clear up your problem, and if not, reply back here and I'll try to walk you thru further.
Mechanic
Posted on Jan 26, 2008
Squelch sound unit wont scan sound wont go away
I need to look at mine it could be a stuck monitor button or a q or chip failed . will get back with you. JR
Aug 10, 2016 | Uniden Bc340crs Bearcat 100 Channel Police...
My pro 2049 desk top scanner is locked out shows all 0sss
Press 'scan' then press a number key to enable the group to scan.
Dec 13, 2013 | Radio Shack Pro-95 Handheld Scanner
How di i scan onto my desk top
It would require that you have a scanner, installer proper scanning software that comes with said scanner, and then running it where it will give you information on where to save the scan.
Mar 13, 2011 | Computers & Internet
Dear Staff: I have a Pro. 97 hand held scanner. I
Hi, my name is John. Press the FUNC and hold down the L/O button until it beeps twice......hope this was helpful..Rate this solution on the four thumbs-up......John
Sep 08, 2010 | Radio Shack Pro-97 Handheld Scanner
Pro-96 Scanner: My pro 96 scanner says all channels locked and it ...
If there is no frequencies on your scanner it will lock all channels out. if all your frequencies are on one bank and you accidentally hit that bank number and turn it off it will lock out all channels. If that's the case just hit that bank no. back on and they will unlock.
May 17, 2010 | Radio Shack Pro-96 Scanner
Will not scan. Screen shows banks and scan up message.
Try this,press manual,turn squelch to silent,press scan. hope this helps..
Mar 20, 2010 | Radio Shack Pro-95 Handheld Scanner
How do you set the scanner to your local police or
First you need to know what frequencies are in use in your area. For a comprehensive database, visit:
www.RadioReference.com
To enter (program) a frequency for future scanning:
- Slide the MODE switch to Scanner
- Press the E (PGM) key. This will turn on the PGM indicator at the top right of the display.
- Press the UP or DOWN arrow (above the SCAN and HOLD keys) to advance to the desired channel, OR enter the channel number using the keypad.
- Press HOLD
- Enter the frequency, including the decimal point (e.g. 155.67).
- To continue programming, use the UP or down key to advance OR enter a channel number, press HOLD, and continue programming as above.
When you're finished programming, press HOLD or SCAN.
I hope this helps. I have a BC370CRS on my desk, and I found that the programming is fairly simple -- once I got used to it.
NOTE: The BC370CRS will NOT work with trunked or digital radio systems. If these are in use in your area you will need a different scanner to listen in.
Dec 25, 2009 | Uniden BC370CRS Base Scanner
Pro 82 Scanner from Radio Shack problem!!
While its in scan mode press the # of the channel to select.. you will see the bar go under the # Then it will scan the channel
Jun 04, 2009 | Radio Shack Pro-82 Scanner
Radio Shack Pro-95 handheld scanner issues
Here is the online programming tutorial:
http://support.radioshack.com/support_tutorials/communications/200-0523/67345.htm
Here is the full manual Should include Quick guide:
http://support.radioshack.com/manuals/ome20-525.pdf
Here is FREE programming software for the PC:
Includes hardware info. You can buy programming cable at Radio Shack to connect to your PC.
http://www.starrsoft.com/freeware/win95/default.asp
Jan 02, 2008 | Radio Shack Pro-95 Handheld Scanner
Channels locked out
Mrs. Santa brought me a new PRO-97 yesterday. I'm new to this - just wanted an aircraft frequency scanner, but got the whole shameal. I had a bad AC adapter and attempted to fix the power problem as directed in the manual by re-initializing the scanner. That blew all memory away.
I received the feared All Channels Locked Out message and through a little research and fiddling, realized the scanner was pre-programmed. An Addendum came with the scanner with instructions to reload the 155 pre-programmed frequencies:
1) Turn off the scanner and then turn it on again.
2) When 'Multi-system Trunking Scanner' appears, press PGM.
3) Press 1.
This will reload the pre-programmed frequencies erased by the re-init. Press scan and it'll be as new as outta the box!
Best wishes,
Farnk
Aug 16, 2007 | Radio Shack Pro-97 Handheld Scanner
Radio Communications Logo
93 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
