Question about Electrolux EL7055A Bagless Canister Vacuum
Electrolux baglass twin filter
Three times it has said the filters need cleaning. done exactly as books says but machine refuses to start to to clean filters, or even start to do normal vacuuming. been in to be fixed to no avail. one year old. pain in the butt
  • Anonymous Mar 25, 2008
    Red light flashed indicating that the filter needed cleaning would not start after.
  • 75 Answers
I would trade it in on an Aerus vacuum.
Posted on Jan 26, 2008
  • Liz Dahl
    Liz Dahl Jan 28, 2008
    Alot of people do have problems with this model.... Sorry!!!
An Electrolux Z8266 won't stay on. It'll turns itself off in 2" after it's been switched on. Could you help? Thx! Gary.
Electrolux Twin Clean Washable Hepa Filter EF78 900196701 8
Check for clogs first Motor restricted air flow will cut it off, also change your filters if you havent done it your vacuum is quite old
Apr 01, 2017 | Electrolux Vacuums
Tip
Electrolux Twin Clean Has Lost Suction - How to Maintain it.
Hi There I have this tip over on squidoo if you would like to post a comment on it.
The Electrolux Twin Clean vacuum is an excellent vacuum cleaner for home. Like most things though if you don't look after it properly it won't perform at it's best. I am often asked as a technition for www.nelsonvacuums.com.au and http://vacuumspot.com.au how to properly look after this machine. Its a really simple machine to look after and if you follow these simple steps it will last for years and years
Lift up your clear lid, they come in a variety of colours so don't worry that mine is blue and yours green (or red).
Check in the hole where you put the hose for any junk and remove it.
Also lift up the filter assembly by the knob in the centre and check the cavity where the fitler was.
This is a pretty common spot for stuff to start building up.
Directly inbetween the round filter cavities is a little trap door.
This is there so you can check for blockages, trouble is most retail stores don't tell you about it and some don't even know it's there.
A small build up like this can restrict suction and cause a big blockage in only a couple of vacuums.
The next step is really easy just put your filters back in the machine. The ones in the picture are really new so don't worry if yours are a bit dirty we'll use the machines self clean function next.
This is the part that most people misunderstand.
With the machine still TURNED OFF rotate the dial in a clockwise direction. You will feel it "clicking" as it goes around, after a few clicks the machine will turn itself on. At this point it is directing its suction straight on to the filter on the left, continue to turn the dial (slowly for best results) untill the machine turns itself off again. Now lift up the filter and swap them around - as in put the one that was in the left hole over to the right.
Do the same procedure again.
Now your fitlers should be clean, pull them up and have a look. If they are not clean just do it over again. If it has been a while since you remembered or the dirt is really stuck in there you might have to buy a new set. VacuumSpot.com.au or NelsonVacuums.com.au can help you here.
Pick your machine up and turn it around so you are directly behind it.
Push in the lock button and lift the handle as if you were going to empty out the bin.
With the bin removed you should be able to see the lift tabs I marked on the picture. Just gently but firmly pull those towards you. They will unclip and allow the door to lay down nearly flat.
Have a look at the picture and compare it to yours.
If there is a split like this there is no point cleaning it, you will have to throw it out and replace it.
Ok so now you need to give your filter a clean. For this to work well you really have to do it once a month.
The best method is to vacuum it with another machine or gently blow it out with an air compressor.
If thats not an option just turn it over and tap it out on a piece of newspaper.
The manufacturers say you can wash the filter but in my experience this has limited value - if you want to theres no harm providing it is bone dry before you use it.
If the filter is as bad as the one in the picture just throw it away and get a new one. This is past it's use by date.
You can get a new one easily from www.nelsonvacuums.com.au or http://vacuumspot.com.au .
Now simply reassemble and Tah Dah your done!
You should have full suction now, and because there are no issues your machine will run cooler and last longer too.
Feel free to leave a comment or question on the guest book below.
on Oct 25, 2010 | Vacuums
The electrolux twin bagless shuts off right after putting on... is there a sensor that needs to be replaced, the cannister is empty and doesnt need to be emptied..
Good chance it is overheating. Make sure you clean the pre-filter (the metal tube inside the dirt collector) and pull out any other obstructions in there. More likely, though, you must clean the black square filter on the outside of the dust collector. This may help: https://www.youtube.com/watch?v=K3MumYn9C70
Jan 20, 2015 | Electrolux Twin Clean Bagless Canister...
Self clean and power lights flashing on electrolux
you either need new filters or you have a bad electronic board or possibly both. Most of these machines only last a couple of years. Not to discourage you, but do yourself a favor and don't buy another one. It's a chinese made Eureka with a lux label. Electrolux went bankrupt many years ago and Eureka bought the name. Miele, Sebo, Riccar, or Lindhaus are all better choices.
Oct 19, 2013 | Electrolux Twin Clean Bagless Canister...
My electrolux twin clean won't turn on
What you might have done is burned out the cable that supplies the power to the actual working of the machine. This happened to be and I had to end up replacing the internal components which took a lot of time, and money. You are better off trying to get a new one and selling this one online for parts.
Jul 14, 2012 | Electrolux Twin Clean Bagless Canister...
I HAVE TURNED THE FILTERS AND i HAVE WASHED THE FILTERS A WEEK AGO THE LIGHT IS STILL FLASHING AND THE VACUM WONT GO AT ALL.
If you mean 'it will not turn on, only hiccups and blinks its lights, turning the filter does not (or at least not reliably) turn on the machine, nor does pushing the power button' the cause might be the controller board which sits between the filter holders in front of the machine. On that controller board you'll find a large-ish HQX (or similar) 1uf capacitor which is part of the power supply for the microcontroller (MCU, underneath the board). That capacitor might have lost so much of its capacity that the power supplied to the MCU goes below spec when the motor starts drawing power, leading to a reset.
Replace that capacitor with a similar or bigger version and it might just work again. In my machine I replaced the 1uF HQX X2 (250V~'275V~GMF) with a 2uF SHW 250V~ ripped from an old fence charger and the machine came back to life.
The large capacitor on the right side of the board is the one I replaced.
While you're at it, check the soldering on the controller and sensor boards and reflow anything which looks suspicious, there were a few cold joints on the sensor board on my machine which caused intermittent problems. Also clean the vacuum tube between the pressure sensor (on the left side of the machine) and the air intake (on the right side) and blow out the dust from the nipple which that tube connects to, on the right side of the machine in the air intake duct. You might also find the rubber hoses used to connect the tube to the pressure sensor and the nipple to have grown so much in size that they do not fit tightly. I solved this by pushing some insulation sleeve (ripped from an old wire) over those nipple.s, this makes those connections air-tight again.
Apr 10, 2011 | Electrolux Twin Clean Bagless Canister...
Hi, My Electrolux twin clean vacuum has both red and blue lights flashing and I can not get it to turn on to clean the filters. Any suggestions
Try taking the twin filters outside - also take a dustpan brush and tap the filters gently on the bottom, then brush the dust away as it comes out. This can take quite some time, and you will find that LOTS of compacted dust will come out!
Feb 20, 2011 | Electrolux Twin Clean Bagless Canister...
Electrolux canister vaccum 2100
The filter for your Electrolux 2100 is located on the rear top of the machine. It is covered by a plastic grill. You simply place your finger in the rear of the plastic grill, push the tab in slightly and lift the grill up to expose the filter. The filter is approximately 4" by 6". It is NOT washable. Most Vac Shops sell replacement filters in addition to them being available at the local Electrolux distributor.
Jul 06, 2008 | Electrolux UltraLux 2000 Bagged Canister...
Electrolux EL7055A Bagless Canister Vacuum Logo
552 people viewed this question
Top Electrolux Vacuums Experts
Marvin
Marvin
Chris Nomland
Chris Nomland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
