Question about Refrigerators
Help my refrigerator sounds like it trys to kick on the it kicks back off after a few seconds ,and all my food it defrosting.an the other side it's not that cold what does it sound like to you? Please help!!
  • robert samples May 11, 2010
    i need the brand and model number
  • 126 Answers
It's the starter or the compressor that is gone. Is it old? Which brand is it
Posted on Jan 26, 2008
What could be wrong with a side by side refrigerator when both the fan in the freezer and the fan below kick off and on and there is a pinging sound going on too?
Is it a clicking sound? Does it repeat itself every few seconds? Is the compressor hot to the touch? If so, you may have a bad compressor.
If unit runs normally and then completely shuts down after a while and stays off, you might have a bad defrost timer which shuts everything down when unit goes into defrost mode.
Nov 14, 2015 | Refrigerators
FREEZER SIDE FREEZES UP REFRIGERATOR SIDE IS WARM
Hi I t seems like the Defrost timer is not working or is stuck. It could also be the defroster coil but probably not. The timer is located in the front of the refer where the toe kick is . remove the toe kick, check for a square or rectangle box with a big plug on the back. that is probably it. Check with the appliance zone online you need the Mod. # for the parts blow up. look for the defrost timer on the print. that will also show where it is located with a part #. you can then price it out . It is not too hard to install be sure to unplug it before removing any wiring.
Good Luck, Bill
Jan 07, 2018 | Whirlpool 25.6 cu. ft. Side-by-Side...
My ge refrigerator model pss26sgpa is not cooling in fridge or freezer
make sure the condensor fans are clean they are prob. full of dust. bottom rear of unit.
Apr 18, 2012 | GE PSS25NGM Side by Side Refrigerator
Samsung side by side fride
The first thing I would check is that the condenser grill under your unit is clean and the air flow is not blocked (also that the lower fan is blowing air across the coils. Even if that is not the total cause it will help your unit operate more effeciently. The condenser grill is under your unit accessed by taking off the front kick panel and also through the rear.
The second thing I would check is for ice build up around the evaporator coil (located in the back of the freezer section). If there is ice build up then you probably have a defrost system failure. This circuit is made up of the defrost heater, defrost thermostat (both located in the freezer section close to the evaporator coil) and the defrost timer which is located in the fresh food side (or if newer frig, part of the control board)
Jan 06, 2012 | Samsung RS2630SH Side by Side Refrigerator
Freezer part does not keep food frozen...and does not make ice cubes. What is the problem? We have cleaned the coils, etc. & it still does not help.
http://www.applianceblog.com/manuals/16025628.pdf
Here is a manual with decent infomaiton and troubleshooting tips. Since I can't walk you through each step of the troubleshooting process and see the results on the meter, I hope this will help you some.
Do you hear the compressor kick on and the beginning of a cycle - normally there is a click sound and then the fan kicks on? If it isn't kicking on, then look at the compressor relay.
Are you getting an ice build up behind the panel in the freezer compartment? If you are then check out the defrost heater, defroster thermostat and the defrost timer.
Please feel free to ask anything you don't understant and I will do my best to answer you.
Jun 10, 2011 | Amana Side-By-Side Refrigerator 26 cu. ft....
Where is the defrost timer?
Hi, the defrost timer can usually be found within the fresh food section of your refrigerator inside of the control panel. Although there are some models of refrigerators where the defrost timers can be found behind the kick plate in the front.
May 17, 2011 | Whirlpool ED5SHAXM Side by Side...
Freezer builds up ice and refrigerator side does not cool properly
Change the defrost thermostat. It you set you back about 25 bucks
Dec 18, 2009 | Audio Players & Recorders
My freezer defrosted and the refrigerator is not as cold as it was
That sounds like the compressor start capacitor,relay or overload. It could even be the defrost timer or part of the defrost Adaptive Defrost Control. I will need the Sear Kenmore model number. I will need you to communicate with me and look around the door of the fresh food section for a model number. Sears uses a different model number when they sell a Maytag, Whirlpool or any Brand nam. Their number after changing would look like this 231.65489 near floor behind door seal and near kick plate.I will help you if you let me know, Thanks Sea Breeze
Nov 13, 2009 | Kenmore 57182 / 57184 / 57188 / 57189 Side...
Side by side whirlpool refrigerator with easy water and ice, not
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Mar 17, 2009 | Whirlpool 21.7 cu. ft. Side-by-Side...
Kenmore Elite refrigerator stops cooling - Relay keeps cycling
The compressor is locked up. Basically it is stuck. You can pick up at the local appliance parts store a hard start relay, Home Depot ,Lowes, or or those guys wont have it. Its not too expensive and is worth trying because your only other option is you need to replace the compressor. The part is called a kick start or hard start, the guy at the parts store will know what you are talking about. It is simple to connect and has the wiring directions on it. Sometimes this is all it takes. I have been able to get a stuck compressor to go by placing a short 2x4 on it and whack it with a hammer a few times. This is only a temporary fix though, as it will eventually lock up again, but emergency situation this saved the food. If the fridge has a fan back there make sure it works too, it may have been the original cause. Good luck.
Dec 26, 2007 | Refrigerators
Refrigerators Logo
43 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
