Typewriters
Problem for Typewriters
Generic problem for all Typewriters
Selectric III Key Stuck
By eyeangdds on Jan 25, 2008
I have an IBM Correcting Selectric III. When I power the typewriter on, the light comes on, but the keys are all dead. I noticed that the "Z" key is stuck down and the rest of the keys on that row seems to be not able to press down as much. What can I do to unstick the "Z"? Is this possibly the reason why the rest of the keyboard is dead?
Comments:
Apr 01, 2008
- Hello Coldcut, sorry for the delay and the ranking, that was done in error. There was a stripped screw for the knob, after some delay, I did get the knob off and opened the IBM Selectric III. I then turned the power on, nothing moved (including the belt) and all keys still nonfunctional. The assembly that holds the ribbon cartridge is stuck to the left sided.
Solution #1
posted on Jan 25, 2008
Somewhat Helpful)
Coldcut
Rank: Wiz
Rating: 84%, 730 votes
remove the cover , latch on bottom each side of unit.
turn it on is the belt running or jumped off.
if it is running then the clutch is jammed.
Comments:
Apr 01, 2008
- Well if the motor is turning and everything is stuck.
normally the first is to wash everything down in a degreaser,
I used to dip them .
but a spray of wd40 may help.
Its been so long since I'v worked on them that the pic is fuzzy.
the clutch area that the belt drives is the main concern.
mainly you have to play with it to learn the operation and where its binding/jammed, I can't remember if you can reverse the clutch.
I wouldn't take it apart as you may never get it back together.
just remove the platten ,cartridges ,head all, rubber items before you spray. then work the levers and clutch. see if the carriage moves freely when you find the lever that unlocks its movement.
remember it should be an easy fix you just have to find where.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Typewriters
Questions and Unsolved Problems for Typewriters
Answer
I cannot figure out how to type a @ on Brothers 100 typewriter. Can you help, please?
Answer
the margin release is not working on ML 100 typewriter
Answer
My ML100 typewriter does not type the right letter when typing. I have changed daisy wheel and it... (More)
Answer
Need a manual for an XD4700
Answer
I need a Manual fo rthe Brother GX-6750 Manual. How do I automatically do a carriage return at the... (More)
Describe your Typewriters problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Typewriter Experts
Top Copier & Fax Repairmen
in , AK
(877) 434-9747
Full service mobile shredder repair service to...
Pacific Coast Shredder Repair
(800) 816-6855
Over 50 years in the office equipment repair &...
EBS Scantracker
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
