Question about Sony XL-2100U Projector Lamp for KF-42WE610, KF-50WE610, KF-60WE610, KDF-60XBR950, KDF-70XBR95
I have read that OEM compatible LCD Rear Proj bulbs don't typically last as long as the OEM name brands... is this true? I have a Sony Grand WEGA KF-50WE610 I see bulbs w/complete housing units at Electrified for $129.00 + Shipping & I see other sites with OSCRAM bulbs only for $199 is there really a difference?
    Problem Solver:
  • 6 Answers
The answer is yes and no. Typically OEM compatible or OEM equivalent lamps last as long as the original, but you have to remember that since it isn't the XL2100u that it's not guaranteed to work the way the OEM lamp does.
Every reseller doesn't use the same specs when they put the lamp and housing together, some of the bulbs aren't always going to be up to the specifications of the OEM, but it will fit in and work.
The best tip I can suggest is to buy a lamp from a store with good warranty, so if something does happen after you bought it, you have some recourse.
Posted on Aug 08, 2008
6ya staff
SOURCE:
Where to buy repair parts
hello try this place tvparts- online.com or ebay
regards
shaun
Jul 08, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
I have no pic sony lcd proj tv model # kdf-55wf655, 57in,
Lamp or ballast bad. If ballast good and lamp bad, will here a mosquito buzz every 15 secs. after turn on.
Apr 20, 2010 | Sony Grand WEGA KDF-55WF655 36" Rear...
Where do i buy the bulb
The best place to buy the lamp is Discount-Merchant.com!
They usually have sales going on, and you'll get the OEM for your TV which is made by Philips Lighting of North America. If you have the original lamp in your TV it's made by Philips... a P22h if you've got an LCD projection.
These lamps should last 2-3 years at minimum.
Always buy from authorized distributors and buy original OEM parts whenever possible.
Feb 05, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
Recently changed my bulb for my Wega LCD KF-42SX300U TV. Since then it is turning itself off, with no particular pattern. It can come straight on and last for a few seconds, or last the entire evening....
This is a classic case of a faulty lamp(even though it is new). Possible that it is a ballast(lamp power sply) problem but it is more likely that the lamp doesnt quite meet the required specifications. Your lamp may be a Non-OEM or a refurb. You should try to get it exchanged with the vendor you bought it from.
justlamps.com is a great source for bulbs.
good luck
Jan 07, 2010 | Sony Grand WEGA KF-42SX300 42" LCD TV
Sony wega rear proj-i believe the bulbs burned out ,tv works in BW only
Because your TV is still projecting a B&W image doesn't mean the lamp is bad. This TV is having something else going on other than a lamp. Possibly a processing board issue if it's only projecting B&W.
This will need to go into a trusted service shop. I would call and see if you can get an estimate of repair first.
Blessings,
A/V Media Tech Guy
Dec 19, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
I have a Sony Grand Wega KF-E42A10 and a blue aura has appeared at the bottom centre of the screen. I recently changed the bulb, but it was working fine for the last 2 months or so, since I changed the...
you have a light engine problem its a warped blue lcd plate
it will require a light engine change out ou might see if you have your reciept and get your model and serial and call sony and see if there is still assistance for this problem
Oct 23, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
Third bulb out in 3 years
I would suggest you getting the shop to look at your cooling fan, assembly or the current surge suppressor connected to the bulb filiments.
Oct 10, 2007 | Sony Grand WEGA KF50WE610 50" Rear...
Sony XL-2100U Projector Lamp for KF-42WE610, KF-50WE610, KF-60WE610, KDF-60XBR950, KDF-70XBR95 Logo
128 people viewed this question
Top Sony Office Equipment & Supplies Experts
jasbo
jasbo
Eric Rotmil
Eric Rotmil
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
