Hi there. In order to do that, you will need to hack your PSP.
BEWARE, the hack might either completely stop your PSP from working or it can be successful which will then allow you to download games for free. NOTE: Hacking a PSP is illegal and the Warranty is instantly voided once the hack has been installed.
The following website contains the PSP hack files. There is also a video link which shows you how to hack it. The hack order is as follows: 5.00-m33 > 5.03 GEN-A > 5.50 GEN-B > 5.50 GEN-D3
I had the same problem with mine. You will have to take it apart and remove any obstruction and tighten the screws holding the analog stick together. Here is a quick guide to get into the PSP: GUIDE
- Fixed a bug when playing within Infraestructure - New system version - Improved the Pops flashing system - New update server.
Just copy the CFWEnabler folder into /PSP/GAME , then go to Games and run the installer
1)INSTALLING 5.03 OFFICIAL AND LOADING CHICKHEN R2
a)INSTALLING 5.03 OFFICIAL
Firstly, you CANNOT do this unless you hava a PSP with Version =<5.03 . To check your PSP FW go to Settings-> SystemSettings-> System Information . If the version is 5.03 , skip thispart and follow the guide below to install ChickHEN . If you have alower version follow this GUIDE in order to install OFW 5.03 .
-Download 5.03 OFW (http://135ff34d.seriousfiles.com) -Connect your PSP to your PC via USB and create a folder in PSP/GAME named UPDATE. -Copy the .EBOOT file in PSP/GAME/UPDATE. -Run the update from your PSP . Now you should have a 5.03 OFW PSP , just what you need in order to load the Tiff Exploit.
b)LOADING CHICKHEN R2
Some useful tips for those who can't get the ChickHEN to work :
-Restore Default Settings -Set UMD Auto Start and Cache OFF. -Make sure you're on 5.03 OFW -Format Memory Stick. ( this will erase all the data from your MSso you'd better backup your files on your PC before doing it )
-Try another method as this video shows : (http://ad452dd7.linkbucks.com) -Don't give up , just try and be patient.
Note that the files needed for PSP 2000 and 3000 series are different than the ones needed for PSP 1000 so don't screw it up.
DOWNLOAD: FOR PSP SLIM ( 2000 & 3000 ) :
-Download ChickHEN R2 Easy to Load (http://0639570b.thesefiles.com)
FOR CLASSIC PSP ( 1000 ) :
-Download ChickHEN R2 Easy to load (http://d249d993.thesefiles.com)
-Copy h.bin to the Memory Stick ROOT . -Copy ChickHEN folder to PSP/PHOTO ( create one if needed ) -Navigate to your PHOTOS folder , and enter the ChickHEN folder.And wait, you will see some images, these will start to loadthumbnails.Go all the way down to the last image. Your PSP may freezeand reset. Just keep retrying and ChickHEN R2 will load up….But if yousee flashing colors, your PSP will reboot loading the ChickHEN.
For those who can't load the ChickHEN files check above for useful tips and remember to restore default settings.
Check your PSP's version to make sure. If the version is somethinglike 5.03 ChickHEN R2 you should be fine and ready to install CFW.
2)INSTALLING CUSTOM FIRMWARE
Do NOT try this on any PSP 3000 or PSP 2000 unhackable mobo's this is only for PSP Phat and 2000 hackable series. This will permanently install CFW onto your PSP ChickHEN must be enabled.
-Download Recovery Flasher 1.60 (http://926291d9.thesefiles.com) -Download 5.0 OFW (http://a3b04c08.thesefiles.com) -direct download -Copy the Recovery folder to PSP/GAME . -Also copy the 5.0 official update renamed as 500.pbp to PSP/GAME/RECOVERY folder . -Go to GAME and run the program and install 5.0 M33-6 !
In the end , press SELECT while in XMB and change UMD Iso Mode to''M33 Driver'' or ''Sony NP9660''. I also recommend formatting memorystick. Place your CSO/ISO games to the ISO folder on your memory stickroot.
GUIDE created by : PSPgamen OF AFTERDAWN Any questions ? probs ? post here ! Enjoy :)
a. why the hell would you put water on it?
b. you can clean the umds without water
c. try resetting the psp. this should change any settings disallowing the games to be played
Maybe your psp is not updated...
my psp can't play games too, i downloaded a nfs mostwanted it didnt work...
One guy told me that, my psp will be updated to firmware 3.80
so that i can play games on my psp...
If you're using umd...
you can find an update icon just below the UMD Game icon...
Follow the instructions while running the update
