Question about Sanyo DVW-6100 DVD Player/VCR
Channel 3 or channel 4 ?
There is no switch on the back to switch from channel 3 to channel 4. Is there another way to use this player on channel 4? I have some local interferience on channel 3. thanks for your help,
  • bronque Feb 29, 2008
    I'm installing a Toshiba DVD to my RCA TV. The installation went OK the first time I tried. But after I "paused" the DVD, I could not get the DVD to run. I have tried different combinations of the instructions with no success. Channel 3 I can get but it is broadcasting a program; channel 4 simply does not appear when I run through all the channels. What's going on?
Never Mind !!!
Posted on Feb 14, 2008
  • 28 Answers
I Have a Sanyo DVW 61XX VCR/DVD Player, For me, i have to turn the vcr off and hold the up button for 4 and down for 3 unfourtunaltly my remote is lost.
Posted on Oct 12, 2008
Plugging a DVD player into a RCA J25435?
The DVD player should have a coax cable output on it, You can switch its output to either channel 4 or 3. This channel 3 signal should play on your TV. murf427
Aug 04, 2012 | RCA Televison & Video
How do you change to 3 or 4 channel on tv for it to work?
on the back of the DVD/VCR you will find a little slide switch that will select either chan 3 or 4 for output ... your tv must be set to the same channel.
Jun 24, 2010 | Philips Magnavox DVD/VCR Dual Player
How can I change my esa 400 player to work from channel 4 from channel 3?
Check on the back of the unit for a small switch. The switch should be in position 4. Move the switch to 3. Good to go.
Read Ya,
Dec 31, 2009 | ESA E4000 DVD Player/VCR
How do you hook up the dvd player to the tv with a vcr hooked up to the tv
Leave the cable box powered on but disconnected from the TV or VCR. All other components should be disconnected and unplugged, giving clear and easy access to all connections. If components sit in an entertainment unit, make sure all A/V cables can reach the RF modulator and the cable from the modulator can easily reach the television.
  • Step 2 Hookup the first coaxial cable from cable box output, usually labeled "TV," "TV out" or "Out to TV" to the cable "In" on the VCR. Connect the second coaxial cable from the VCR's out to "TV" to the coaxial input on the RF Modulator.
  • Step 3 Connect the third coax cable from the coaxial cable "Out" jack on the RF Modulator to the coax cable "Input" on the television.
  • Step 4 Take one A/V cable, connect the red (right audio channel,) white (left audio channel) and yellow (video) from DVD player's "Output," to the corresponding DVD "inputs" on the RF Modulator. Place components as desired but still disconnected from power. Plug in all power cables including the RF Modulator's into the surge protected outlet strip.
  • Step 5 Make sure the Channel select switch usually found on the back of the VCR and the Channel select switch on the RF Modulator are both set to Channel 3. This channel is used on the television to view your components.
  • Step 6 Turn on the power strip and turn on the TV. Cable reception should come on as usual. Set the TV to Channel 3 and turn on the VCR. With VCR on test it by playing a video tape. The RF Modulator should sense the signal and automatically switch to "VCR."
  • Step 7 Switch off the VCR and with the television still on channel 3, turn on the DVD player. As the RF Modulator senses the DVD player signal and switches to DVD, its welcome screen should be seen on the television. Play a DVD to test and once you're done with the DVD turn it off and the cable should come back on.
  • Jul 15, 2009 | Televison & Video
    Auxillary channel for dvd
    You need to determine what output options your DVD player has. Take a look at the rear of the player. It will certainly have RCA jacks for video and audio outputs (yellow for video, red and white for right and left channel audio). It may also have RCA jacks for component video (marked Y, Pb and Pr). Finally, it may have a threaded connector marked "out to TV" or "antenna out" or something similar. This is called RF output.
    Most players today don't offer RF output because nearly every TV has direct AV inputs available. If your DVD player has RF output, connect the output connector to the TVs antenna input. You need a coaxial cable with F-connectors on the ends. One may have been supplied with the player. RF output is on channel 3 or 4, set by a switch on the back of the player or by its on-screen setup. Just set the TV to that channel to watch a DVD.
    If your player doesn't have RF output, you connect it to the TV using the AV jacks. You need cables with RCA plugs to to connect the video and audio from the player to the TV. Then you switch the TV to its video input to watch the DVD.
    This is where you might run into problems. Many TVs need the original remote control to switch inputs. (Some older RCA sets used channels 90, 91 and 92 to switch to their video inputs so any remote would work, but these sets were made before 125-channel tuning became standard. If your set is one of those models, those are the auxiliary channels you heard about.) If you can't switch the set to video input with front panel buttons and you don't have the right remote, you're not completely out of luck.
    If you can't use your set's AV inputs or it just doesn't have any, you need an RF converter. These cost around $15. They take the audio and video from the DVD player and convert it to channel 3 or 4. Then you hook that output to your TV as described above.
    May 17, 2009 | RCA Universal Remote Control
    Can't change output on DVD from channel 3 to 4
    Unfortunately, Broksonic's website doesn't offer manual downloads. But product information for the 810C and 810D both say the output is channel 3/4 switchable. So if there isn't a rear panel switch (or one hiding somewhere else on the unit), it must be through a setup menu via the remote control. If you have the remote it shouldn't be too much trouble to experiment with the options until you find the right menu. If you didn't get the remote along with the unit, you are probably going to have to live with whatever channel it's on already.
    Nov 30, 2008 | Broksonic DVCR-810 DVD Player/VCR
    Zenith TV
    have u tried using a universal remote and programming it for your tv? sometimes universal remotes can break a code that a common tv remote cant, hope this helps, just a suggestion!!!!
    Dec 28, 2007 | Televison & Video
    Unable to locat and select the AV channel on new LCD HD TV
    Hi, try switching your tv to channel 3 or 4 and see if that works- there should be a switch on the back of your DVD player beside the Coaxial Cable outputs-it will allow you to use Channel 3 or 4 as the default to play dvd's. I hope that helps-if more detail or wiring diagram is needed-please leave make and model numbers and i'll try to help.
    Cheers and have a Happy Holiday Season!
    Dec 21, 2007 | Televison & Video
    Trying to watch vcr on channel 4, but the vcr is set to channel 3
    You can watch the TV programs
    with the tuner of the unit. (Usually
    channel 3 or 4 of the TV is
    available for the RF converter
    setting.) Be sure to connect the
    unit to a TV using the RF cable.
    Select channel 3 on your TV.
    Press [VIDEO/TV] on the remote
    • If noise appears, change the
    RF output channel of the unit to
    CH 4 by pressing [VIDEO/TV]
    for 3 seconds. The RF output
    channel will alternate between
    CH3 and CH4
    Nov 20, 2007 | Philips MWD2205 DVD Player/VCR
    Sanyo DVW-6100 DVD Player/VCR Logo
    117 people viewed this question
    Top Sanyo Televison & Video Experts
    Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
