Home | HP | iPAQ RX3115 Pocket PC | Ipaq rx3115
HP iPAQ RX3115 Pocket PC
Problem for HP iPAQ RX3115 Pocket PC
Ipaq rx3115
By Aceofhearts on Jan 25, 2008
Same problem, my Ipaq rx3115' touch screen won't respond; I soft reset, hard reset; I connected it to my computer, the computer sees it, creates an association, etc. The screen will not respond, it is just stuck on the align screen, screen, and it will not work. The battery light, when I plug it in, blinks; however, it blinks red, not amber. Then it stops and is steady state on, but, like I said, it is red, not amber.
Solution #1
posted on Jul 24, 2009
Not Rated)
Great_items
Rank: Guru
Rating: 90%, 42 votes
If I understand correctly your problem, the touch screen of your PDA is not working.
Well, this is a common IPAQ failure. When happens, the only options to repair it are:
1. Soft reset of the PDA. If still does not work, then go to next step.
2. Replace the top digitizer glass.
It requires a very skillful person to do it. If you have not experience with fixing electronic devices, then I do suggest you to send it to repair.
Besides that is necessary to open it, you will require a soldering iron, and desolder the digitizer part and remove it from the LCD screen, which if is not done properly with the right tools, it's easy to damage the LCD screen assembly.
Also, if it's not opened right, is possible to damage permanently the mainboard if is bent or warped.
Also, even though there are a lot of cheap digitizer replacement parts on-line (mainly from China), they have a compatibility issue that prevents to use them in the RX3715 (or RX3115) PDAs.
I have nothing against Chinese manufactured parts, but after buy around 10 digitizers in the last couple of years for different Ipaq PDAs, I found out that only 3 worked fine, so I know what I am talking about.
Best regards,
Was this helpful?
Yes
No
Popular Solutions for HP iPAQ RX3115 Pocket PC
Questions and Unsolved Problems for HP iPAQ RX3115 Pocket PC
Do you recommend HP iPAQ RX3115 Pocket PC?
Answer
Answer
Im having same problem as bexta27783.I also cant access the music I download to my Nashi. I have a... (More)
Answer
i need te services manual of the ipaq rx3115
Answer
My iPAQ rx 3115 will not turn on. I left it in my briefcase but now it just does not start. I did a... (More)
Answer
is there a media player upgrade for my pda?
Answer
my ipaq 210 hard reset itself everything i use soft reset, causing data loss. how to solve this?
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For HP iPAQ RX3115 Pocket PC:
Top PDA Experts
Rank: Guru Guru
Solutions: 554
Experience: Experienced a lot in computer troubleshooting. Knowledgeable about cellular phones.
Ask Me
Find more PDA Experts
Top Computer & Laptop Repair
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
