Question about Kodak EasyShare V603 Digital Camera
Camera Screen I dropped my camera and the LCD screen broke. Now I have just a black screen that is cracked. What can I do?
  • Anonymous Feb 07, 2008
    broken screen
  • sal sal Jan 08, 2009
    i have the same problem!! now im going crazy because that was a new camera and there is no way my husband will let me get a replacement, is there anyway i can cheaply fix this problem????
  • 502 Answers
There is a company in new york that carries parts for small digitial cameras : Camera Repair NYC
Posted on Apr 28, 2009
    Problem Solver:
  • 18 Answers that should help you
Posted on Sep 13, 2008
  • 2,130 Answers
The following procedure works on the V603. It uses the same LCD screen as the V803 & V1003.
It would appear you have a damaged LCD screen. The same problem happened to my daughter's V803. The camera will take pictures fine but you will only be able to see them if you download them onto a PC. A replacement screen can be easily ordered and replaced. Call Eastman Kodak. Their parts department can be reached at (800) 431-7278 ext 3. Tell them the model number of your camera and tell them you want to order a LCD screen for it. The cost of the new screen is $31.00 + $15.00 shipping. Don't let them talk you into sending it back for repair. You are looking at a repair bill over $80.00. To replace the screen, remove all of the small philips head screws that are in the chrome band that runs around the center ridge of the camera. After removing the screws, you will be able to separate the rear half of the camera from the front half. The LCD screen is pressed into a rubber gasket in the rear half of the camera. You will see that there is a small, flat orange ribbon cable that connects the old LCD screen to a black connector on the camera's motherboard. Using a VERY small flat blade screw driver, pry up the top tab on black connector. This will unlock the connector and allow you to remove the flat ribbon cable from the black connector. Remember the orientation of the old screen and its cable, as you will want to replaced the new screen and cable exactly the way the original was installed. Using the same small flat blade screw driver, pry out the old display. Install the new display into the rubber gasket into the back half of the camera. Insert the ribbon cable into the mother board's black connector and press down on the panel to lock the cable into place. Lay the rear half of the camera face down on the table (rear buttons facing down) and place the front half of the camera over top of the rear half. This will allow you to put the camera back together and help prevent the new LCD screen from falling back out. The LCD screen has pads attached to the surface behind it. When you reinstall the front half of the camera, those pads help hold the LCD screen in place with pressure from the motherboard. Replace all of the screws. If you did it correctly, the camera will operate like new. Last word of advice. Buy a padded hard shell case for this camera. These cameras are well known for LCD screen failures due to shocks and drops.
Good Luck!
- Jim
Posted on Feb 12, 2008
Hi, my son dropped my LZ2 camera and now it starts when I power it on, all menus and functions seems to be ok, but no image is displayed in the LCD. Any ideas what's going on?
The LDC screen most likely broke the screen did not crack by the actual underlying LCD screen broke the only option is to replace the screen or have it replaced at a local camera shop
Mar 05, 2011 | Panasonic Lumix DMC-LZ2 Digital Camera
Cracked Camera
This depends on your warranty, if it covers cracks and the product being dropped I'm sure they will give you a new one to replace it, or find parts to repair it.
Sep 10, 2009 | Cameras
Dropped my camera, screen black
Sounds like you need new LCD display, Yours may be cracked from the drop, Would probably cost about, $120.00.
Feb 25, 2009 | Sony Cyber-shot DSC-W120/B Digital Camera
Broken LCD screen on Kodak EasyShare M853 digital camera
No It Can Not Sorry To Say but your camera is internally broke the lcd ink pad is broken
Jan 03, 2009 | Polaroid i735 Digital Camera
Cracked your LCD screen, the black lines are where it broke.
Nov 03, 2008 | Sanyo Xacti VPC-T700 Digital Camera
A brokem screen
LCD is broken and needs to be replaced.
Jun 15, 2008 | Sony Cybershot DSC-T200 Digital Camera
Screen and not resonding to buttons.HELP!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Black and whiten in a cracked form indicates damage. Sounds like a drop/cracked lcd.
May 14, 2008 | Sony Cyber-shot DSC-S700 Digital Camera
Oops dropped it.
Jyst buy a new camera all together and get something other than Samsung.
Mar 23, 2008 | Samsung Digimax D53 Digital Camera
Cracked Camera
No easy fix. Pressure or impact is the usual cause of a cracked LCD. Try not to get the black stuff on's pretty toxic! The screen needs to be replaced (assuming there's no other, internal damage). They are usually in the range of $75 US.
Feb 19, 2008 | Nikon COOLPIX S200 Digital Camera
Screen black
If screen is black on both the playback and camera modes then LCD unit is probably cracked more likely it needs replacement.
Dec 02, 2007 | Sony Cyber-shot DSC-W100 Digital Camera
Kodak EasyShare V603 Digital Camera Logo
213 people viewed this question
Top Kodak Cameras Experts
Are you a Kodak Camera Expert? Answer questions, earn points and help others
