Question about Vivitar Vivicam 3345 Digital Camera
Wont turn on
I put brand new battery's in my vivitar 3345 vivacam and now it wont power up.
  • Cam3345 Feb 06, 2008
    Can't get camera to turn on - even with fresh batteries. As battery door is closed display flashes "ON", then "OFF". Batteries measure fine using a volt meter and the stored pictures can be seen if I connect the USB cable to my PC>
  • harleyquin42 Aug 02, 2008
    i cleaned the leads like guest said to do and not so much, but everything registers just fine as fara s battery life is tyhere another solution
I had the exact same problem. The battery contacts are mildly oxidized. The problem is made worse beacause the outer contact does not put much pressure on the side (+) furthest from the hinge.
SOLUTION: Go to Radio Shack and buy a Deoxit Power Booster Pen. Wipe some on the battery ends that touch the inner contacts and insert while still wet. Rotate the batteries slighly to help coat the contacts. Wipe some deoxit on the outer contacts and close the door while pulling gently away from the hinge so you will get a good "wipe" when you slide the door latched.
I hope this works as well for you as it did for me. Scott L.
Posted on Mar 13, 2008
My vivitar T028 camera wont turn on
i also have a Vivitar ViviCam t028 and i just changed the batteries and it wont turn on i was just about to empty the memory card but it wont turn on so i can't i don't know what's wrong with it.
Dec 25, 2012 | Vivitar ViviCam X327 Digital Camera
Need a battery dor for vivitar 8370
Welcome to fixya. You can get a new door from the manufacturer's website for a few dollars. It is a simple replacement, involving a few screws to loosen the case in the door area,or you can check for their authorized sellers at this website:http://www.vivitar.com/p/where-to-buy.
Hope this helps.Have a great day.
Jul 22, 2011 | Vivitar VivaCam 8370 Digital Camera
My Vivitar Vivicam 5399 is refusing to turn on. It has worked perfectly up until a couple of weeks ago, when it started to turn off at random moments, usually soon after I had turned it on. Now, it doesn't...
Have you tried to see if the battery door is completely shut? This is usually the problem with many digital cameras with batteries. Clean the battery door and where the battery touches the metal of the door. Check to see if the door is completely flush with the camera body when you close it. I know for a fact that Vivitar cameras **** the juice out of batteries fairly quickly also. If you have the USB-cord provided with the camera, plug it into your computer and see if that holds a charge to your camera. If all else fails, call up Vivitar for further inquiry, your battery may be dead.
Mar 08, 2011 | Vivitar Vivacam 5399 Digital Camera
Camera turns on then turns off automatically
your cameras batteries are either dead or your camera is faulty / unable to extend the lens and it turns off. Or it can be any other hardware malfunction, take the camera to a repairer, you will not be able to repair it yourself unless it is poor batteries or dirty battery contacts.
Jan 17, 2011 | Vivitar Vivicam 3345 Digital Camera
I have a vivitar vivacam 25 and I lost my cd rom so I cannot put my pictures on my computer....what do i do?
I'm assuming you have a Vivitar X025.
Go to
http://www.vivitar.com/support
and click on "vivitar experience software" and fill in the form to get access to the software.
Let me know if you have any other questions. Thanks.
Jan 13, 2011 | Vivitar ViviCam 25 Digital Camera
The battery door has broke, it is just the cover and not the hinge
You can get a new door from the manufacturer's website for a few dollars. It is a simple replacement, involving a few screws to loosen the case in the door area.
May 12, 2010 | Vivitar VivaCam 8370 Digital Camera
My vivacam kills batteries within a few minutes
Do not use alkaline batteries. Buy NiMH rechargables and keep a couple of sets on hand fully charges. ViviCam's eat alkalines alive!
Apr 25, 2009 | Vivitar ViviCam 5100 Digital Camera
Problem with vivitar vivacam 4100
the problam is most likely the video card in the camra.take it back to the store you bought it from and have them take a look at it.
Feb 05, 2008 | Vivitar ViviCam 4100 Digital Camera
Vivacam
go to google type vivicam drivers follow links and download or contact me at sixmilepaul@yahoo.com and I will try to send you drivers from my disk
Dec 11, 2007 | Vivitar ViviCam 10 Digital Camera
Vivitar Vivicam 3345 Digital Camera Logo
78 people viewed this question
Top Vivitar Cameras Experts
Tony
SHARCNET-USA
SHARCNET-USA
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
