Sony mhc 2600
Cd part would no close, it does open, if close manually, cd got stuck and do not play.
  • chahhh Feb 06, 2008
    Already done this, it did not work, worse it no longer plays cd now. But thanks anyway
  • 983 Answers
Open the player wit the door ejected then clean all dust particles inside it especially below the door and on the way where the door closes ... and then also clean the rubber belt & near by which is connected to dc motor... and clean the lens also... remember clean only wit dry clothes...
Posted on Feb 06, 2008
  • Dileep Keshavanarayana
    Dileep Keshavanarayana Feb 06, 2008
    may be the lens is damaged... it s the time to change ur player
6ya staff
SOURCE:
Disassemble the MHC GX20 sony stereo
There might be a small hole for a safety pin. Press that and it will pop open.
Dec 11, 2012 | Sony MHC-GX20 CD Shelf System
Cd got stuck in the caroussel
Somewhat confused. If it won't open, there should be something you can press a safety pin into and it will open it.
Dec 10, 2012 | Sony MHC-GX20 CD Shelf System
Sony mhc-2600 tape stuck
The tape has spewed out in the mechanical section preventing the door from opening, some outer doors can be removed by too thumb screws sliding up and out, others are held in by plastic clips, the door may have to be pried open to get the outer door off to remove the tape.
Jul 27, 2012 | Sony Audio Players & Recorders
I have sony mini hi-fi mhc-gnz88d now it's displaying DEST ERROR and can't open disk tray or run a CD. how to solve this?
i hv also this problem from yestrday.. all function are ok. bt when playing dvd ... there is 'please wait'error long time. and also tray not open after pressing open or exchange cd also... whats problem.. please help me.. waiting
Dec 25, 2010 | Sony Televison & Video
How do i open the cd tray on a sony mhc-rg70av shelf system that seems stuck
Most CD trays will open if you shut off equipment and pull gently but firmly to overcome the slight initial resistance. Don't use so much force that it seems likely that the tray mech will break. This calls for a serious bit of taking apart and is best left to the local repair shop.
Oct 31, 2009 | Sony MHC-RG70AV CD Shelf System
The CD Tray won't open on my Sony MHC-GX250
te same thing happened to me know i juat turn the stereo off to where the red light is blinking then turn it back on after the standby message disappears and then i quickly pree the eject button......tr it! and let me know!
Jun 24, 2009 | Sony MHC-GX450 CD Shelf System
I have an Sony RX66 the cd changer will not pop to play on.
My sony stereo rx66 after finish to play the first cd stand of going to play the second one, it put the cds one of the top of the other or under the tray. Can somebody help me?
May 04, 2009 | Sony MHC-RX66 Shelf System
CD SKIPS
well it depends on how you feel about opening your system. have you tried a cleaning cd? if not, then do that. If not, and u want to open it, then get some electronic cleaner spray (not sure how its called) and blow the laser clean. There are some resistors you can adjust, but thats getting very trick.
good luck
Dec 22, 2008 | Sony MHC-BX5 Shelf System
Cd stuck in player
You'll have to unplug the unit and remove the cover to get it out. Be careful and good luck.
Feb 28, 2007 | Sony MHC-GX355 CD Shelf System
1,005 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
