Whirlpool thin twin washer dryer leaks at base not hoses
  • Anonymous May 08, 2008
    Hi, My thin twin whirlpool is taking long time to fill. This problem came after it was removed to replace the floor. Tks Arthur
  • shardie Jul 24, 2008
    leaks at bottom not at the back hoses
How do i stop the loud pounding noise on the spin ,ajust the balance???or what else,i think the women that first used it put 2 heavy rugs and threw it out of balance?
Posted on Oct 25, 2009
I searched for a similar problem on Google and found this article: http://www.applianceblog.com/mainforums/showthread.php?t=11131
Posted on Nov 05, 2008
The pump seems logical - access to it is a quandry!
aft
Posted on Aug 18, 2008
  • 770 Answers
Check the pump
Posted on Jan 26, 2008
Whirlpool thin twin LT5000XUWO why water not shutt off overflows
bad water solenoid, underneath that is the unit that the water goes to and there are wires coming from it it is sticking in the on position
Aug 25, 2014 | Whirlpool Thin Twin Washer and Electric...
Why doesn't my whirlpool thin twin fill up with enough water to was a large load?
No cannot over ride set at large doe the machine fill to a certain level then stop if so operating correctly if it never stops filling with water then there is a leak in the fill system either a hole in pressure switch hose it popped off tub or water leaking out thru drain system pump or siphoning thru hose again if unit starts to agitate there is enough water in unit per design
Aug 21, 2014 | Whirlpool Thin Twin Washer and Electric...
Kenmore twin washer do not drain yes
Does the pump engage and if so there might be something stuck in the hose before the pump
Mar 10, 2014 | Whirlpool LTE5243DQ 24" Compact Thin Twin...
Overflowing Washing Machine, water does not stop filling, overflows to floor. This is a Whirlpool Thin Twin Stackable
sounds like you have a bad water level pressure switch part 3362987
http://www.searspartsdirect.com/partsdirect/part-model/Whirlpool-Parts/Washer-dryer-combo-Parts/Model-LTE5243DQ6/1198/0152000/W0604125/00001?blt=06&prst=&shdMod=
go her part number 10 in diagram or there could be something in the hose,the hose could have fallen off or could have a hole in it,i can't find a video with a stack machine but this explains your problem
http://www.youtube.com/watch?v=jzKBUI5D0Vs
Mar 30, 2013 | Whirlpool LTE5243DQ Combination...
Whirlpool thin twin ylte6234dq2 washer/dryer water overflow!
first access the tech sheet and run any diagnostics it shows for the machine and if this passes,then check/change the fill switch on the control panel along with fill tube from the wash tub base if kinked or plugged
May 10, 2010 | Whirlpool LTE6234D Top Load Stacked...
Water leaking from stacker unit
No parts are replaceable within the pump. Buy a new pump.
Jun 22, 2009 | Whirlpool LTE5243D Top Load Stacked...
Whirlpool thin Twin Model #LT5000XL
check for corrosion or crack on the outer tub. also inspect the hose behind.
Dec 13, 2008 | Whirlpool LTE5243D Top Load Stacked...
Washing Machines Logo
1,048 people viewed this question
Top Washing Machines Experts
