Question about Raymarine C80 GPS Receiver
Alarm after MOB was hit will not go off
After marking a spot with the MOB, an alarm continues to sound every 10-15 seconds and the soft key for navagating isn't available.
  • donsudduth Jan 25, 2008
    The problem was solves when I held the MOB button in for a few seconds. Is that what you call resetting?
  • 1,944 Answers
Did you try to reset the unit? Do you have the latest software for your unit?
Posted on Jan 25, 2008
  • Damen Wong
    Damen Wong Jan 25, 2008
    Yes, but does it solve it completely?
Ford edge alarm sounds when key used to start car
sounds like the alarm needs resetting , look in the owners manual for the procedurer,might even just need a new battery in the key/fob unit
Jul 24, 2014 | 2007 Ford Edge
I got into the car went to start it, accidently hit the lock button on the key and activated the alarm. Now alarm won't deactivate and the car won't start
put the key back into the ignition and push any key buttons and hold for 10 seconds and the alarm should reset.adrian,,,,,,,,,,,,
Aug 14, 2010 | 2003 Land Rover Discovery
I bought a Chevy Trailblazer, used, had keyless remote access Viper Alarm after manufacturer. Had trouble with transmission and alarm....took to Chevy dealer they replaced transmission. Now the remote...
You need to find the black push button called the valet button. That is the overide. Get in the car turn the key to IGN as the alarm is going off and then you have either 5 or 10 seconds to push that button once and then 2-5 seconds later the alarm is shut off. To put the car into valet mode which means no alarm at all you put the key to IGN push that button once then pull key out at which point the blue light should turn solid blue.
Or option two is you open a door and hit the lock, then unlock, then lock button again on the remote and the blue led will be solid which means no crazy alarm.
Mar 08, 2010 | 2004 Chevrolet TrailBlazer
Set all 3 alarms and they never go off. Big problem since it is my only alarm clock for work and just recently quit working have used for almost 2 yrs
You need to make sure the Ringer is enabled. Here are the instructions:
Alarm Clock
The Alarm Clock tool allows you to set up to three
When you set an alarm, the current time is displayed.
When the alarm goes off, Alarm 1 (or 2 or 3, as
applicable) will be displayed on the LCD screen and
the alarm will sound.
1. From standby mode press the Center Select
Key c [MENU], then press the Directional Key
r right twice for SETTINGS & TOOLS, 2
Tools, 4 Alarm Clock.
2. Press the Directional Key j up or down to
highlight an Alarm (1, 2, or 3), then press the
Center Select Key c [OK].
3. Enter the alarm information including:
• On/Off
• Time
• Frequency
• Ringer
4. Press the Directional Key j up or down to
highlight the information you want to set, then
press the Left Soft Key L [Set] to view your
5. Set information and press the Center Select Key
c [OK].
6. Press the Center Select Key c [SAVE] after
setting all of the applicable Alarm Fields.
Feb 24, 2010 | Casio G'zOne Boulder Cell Phone
Everytime I lock the car using the key fob, about 30 seconds later the alarm sounds but the lights do not flash and the horn does not sound. Only when I unlock the car will it go off. I have disconnected...
you may have a bad door switch, theres a switch on the drivers door lock, when door is unlocked with fob or key the switch is activeated to shut alarm down,the lock moves to hit switch with key or fob,so if the switch is bad it will not shut down alarm, i would start there,door panel has to be remove,then latch has to be remove to get to switch, then test with a meter see if it opens and closes the connection, hope this helps.
Dec 26, 2009 | 2000 Jaguar S-Type
How do i turn off the alarm on the samsung jack
While in standby mode, press the left soft key for Start
Select Organizer
Select Alarms
From the Alarm screen, highlight Wake up alarm (1)
Press the left soft key for Edit
Press the OK key to check a box, then enter the time for the wake-up alarm, using the keypad
Press the OK key to check the boxes for the desired days of the week
Highlight Tone, using the navigation keys
Select a melody for the alarm Tone, using the navigation keys
Highlight Snooze, using the navigation keys
Select a Snooze time interval, using the navigation keys
Press the left soft key for Done to set the Wake-up alarm
Note: You can set up to 3 different wake-up alarm times, but not on the same day
Nov 26, 2009 | Samsung Jack Cell Phone
Kia rio key fob power lock/alarm problem
if the lights flash when you hit the panic button but the horn does not beep, then the alarm horn is bad. Vehicle has a second horn just for the alarm
Sep 16, 2009 | 2003 Kia Rio
Do 2005 chrysler 300 base come with an alarm system.
lock the doors from the switch with the door open. That turns the included factory alarm on.
Dec 08, 2008 | 2005 Chrysler 300
Reminders and wake-up-alarm problems
Here is how to hard-reset your MDA/Wizard using a key combo - courtesy of a smart T-Mobile tech support help desk guy who wrote a note about it as it's not in official help doc's: 1. Simultaneously hold down the Communication Manager and Voice Dial buttons and put the Soft Reset 'button' with the stylus tip - all at the same time. 2. You see a very scary looking black screen with white letters in System font reading something along the lines of ?Are You Sure? Press Send key to continue.? 3. When you push the 'Send' key, the Green pick-up the phone key process starts 4. Next you will see what made me smile like a kid - Formatting FAT partition and very briefly in matter of few seconds began normal first boot.
Aug 19, 2007 | i-mate K-jam Smartphone
Raymarine C80 GPS Receiver Logo
686 people viewed this question
Top Raymarine GPS Experts
Shehu Pro
Shehu Pro
Are you a Raymarine GPS Expert? Answer questions, earn points and help others
