Question about AMD Turion 64 X2 TL-56 CPU
Compaq Presario AMD Turion 64 X2 Dual-Core TL-56
I have 2 of these models that I just bought and also got 2 gig sticks to put into them.Tried different configurations and got the same result every time. After I put them in, the computers would continually shut off. The power light would come on and then after a few seconds,would shut back off and try to start again.I tried the sticks in 2 other compaqs with the same results.The RAM was made by Buffalo.
Sound/audio driver is not install to xp professional
Posted on Feb 19, 2008
    Genius:
  • 1,554 Answers
It hates the taste of the memory you put in.
use
2GB 667Mhz DDR Memory
Posted on Jan 25, 2008
6ya staff
SOURCE:
I currently Have I Gig of Ram. I am trying to install 2 x 1 Gig of Matched Ram in the Correct slots but the computer will not boot up with 2 sticks of Ram. If I take either one out it boots up fine
What slots you put the RAM into can make a difference - Assuming you have more than 2 slots, try staggering the RAM placement so there's an empty slot between the 2 RAM sticks. You'd have to look up your motherboard model online to see what specific instructions there are.
Jan 12, 2011 | Intel D945GPM Motherboard
ECS PT800CE-A 3.4 P4 HT CPU and DDR400 (PC3200) problems
I seem to be unable to find any information about what an ERAND error even is. No one is really identifying it on the net. One thing you may try though is to find out if the bios settings are maybe causing this. Is the system overclocked at all? Are the voltages correct? Maybe try resetting Bios to default settings and trying again.
Oct 04, 2009 | EliteGroup ECS PT800CE-A...
Same situation - Everex VA 4103M recog 1 gig when have TWO
Mine will not see 2 gig either... i tried putting the 1 gig and the original 512mb in, and it does see all 1.5 gig... not a perfect solution, but better than only one gig.
Oct 02, 2009 | Everex StepNote VA4103M Notebook
I have attempted to upgrade a Gateway GT52223 from 1= Gig existing 2X 512 DIMMS to 2 Gig on two separate occasions first using Using Crucial -2-1GB 240-PIN 128Mx64 DDR2 PC2-6400 UNBUFF CL6 the system...
Your last results is running your comp OK because it is really only running on the 512 stick. When putting 2 different sizes together it will only run on the smallest, with this said here is a website http://www.4allmemory.com it will test your comp to exactly what type RAM you need . I buy for my clients all the time from this website. Very reliable,Try it..and remember about the 2 sizes
Jul 15, 2009 | Gateway GT5220 PC Desktop
Adding ram, but computer freaks out.
there is a jummper on the mother board you need to take off.
Jan 05, 2009 | E-Machines eMachines Desktop PC
One of the ram isnt recognised???
This is likely a memory timing incompatibility. You can go into the BIOS settings of many motherboards and set the timing specifically for each RAM slot, but without knowing exactly which piece of RAM you have I can't tell you what to set it at. You could use the utility CPU Z, install one stick, run the utility and write down all the memory information, then install the other stick and write it down too. Then go into your BIOS and see if you can set all of your specifications to match the memory.
Of course if you could find someone to swap sticks with that would be easier. Some motherboards are more picky than others about which sticks they work well with, name brand manufacturers are more picky than aftermarket in general.
Dec 30, 2008 | Computers & Internet
Ga-k8ns memory problems
did you go into bios and check set up of ram speed etc
Jul 14, 2008 | Gigabyte GA-K8NS Motherboard
Not seeing other stick of ram
MAYBE YOUR COMPUTER ISNT CAPABLE OF HANDLING MORE THAN 1 GB ram UPGRAPE LOOK AT THE SPECS ON THIS MODEL TO SEE WHAT MAX MEMORY IT WILL SUPPORT.
Jan 17, 2008 | Compaq D310 (287944-CTO-4) PC Desktop
Problem accessing memory stick
I had the same problem. I bought a 2 gig memory pro-duo with the adapter and it gave me that error even though it fit just fine. I then tried a 512 memory stick and a 1 gig memory stick and neither one worked it gave me the C:13:01 error code. So I found out the hard way that the camera will not read it. The Sony DSC-S85 will not take memory above a 128. Try the Lexar 64MB memory stick. I just bought 4 and they work perfectly fine.
Nov 02, 2007 | Sony Cyber-Shot DSC-S85 Digital Camera
Memory/Graphic problem
This might have something to do with DVMT or Digital Video Memory Technology. Basically, the amount of video memory is dependent on the amount of memory installed. I'm not very familiar with acer system BIOS but try to look for VIDEO under system BIOS and try to select any fixed video memory if possible. you can also try to disable DVMT.
Sep 30, 2007 | Acer Aspire 3680 Laptop
AMD Turion 64 X2 TL-56 CPU Logo
183 people viewed this question
Top AMD Computers & Internet Experts
Ekse
Alun Cox
Carlo Barzo
Carlo Barzo
Are you an AMD Computer and Internet Expert? Answer questions, earn points and help others
