Question about Toshiba 27A44 27" TV
JSILVA I HAVE A PROBLEM MY TOSHIBA DISPLAY LINES HORIZONTAL NO VIDEO NO SOUND MODEL CX2769J
  • 4 Answers
The "no sound" part worries me, but the board may have bad solder connections in the vertical section or simply the vertical deflection IC is bad. No sound may be the result of not being able to know you are on a correct channel. Usually when this happens, the bad solder connections are very obvious. I don't have a service manual so I can't direct you. If you do choose to inspect the board, unplug the unit first and note that CRT TV's commonly hold charges before you go touching around inside, if that worries you then don't do it. Most vertical IC's are straight in-line pinned, inexpensive, and when they go may take a load resistor with them so look for burnt/scorched resistors, possibly even a cap that's blown it's stuffings out. You should have or know the basic theory of TV process or you are just hoping for a magic fix and shooting in the dark.
Posted on Jan 25, 2008
FIXS LNES IN TOSHBIA SRS WOW THEATER WIDE TV !
sounds like vertical retrace lines. The horizontal line fault called so. Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Pull up older posts.
Type in this key phrase " my service table today " in the search box at the top right of the display window of the home page, to get gathered some pages which has the details of practical experiences to the author of that site.
Apr 23, 2016 | Toshiba 32A33 32" TV
When tv is turned on you get poicture and sound but there are broken horizontal lines from top to bottom of screen. this occurs on all hdmi inputsincluding roku and dvd player.
How to fix lcd lines on Sharp tv screen, hdmi video board ...
? 3:43
https://www.youtube.com/watch?v=cHki4D0EwOo
May 24, 2014 - Uploaded by Tampatec
How to fix LCD lines on Sharp TV screen, hdmi video board easy ... Make Money From Your Broken Cracked LCD LED PLASMATV ... TV Repair Help for Vertical & Horizontal Lines on Your TV Screen ... Sharp Aquos LC-32 37 46 52DH65E 66E 77E - NoPic/Sound with ... Get video URL at current time.
comments on LCD Display Symptoms and causes. - YouTube
https://www.youtube.com/all_comments?v=DedJvyNm_s4
We have frequent outages causing the TV to turn on from standby mode when power returns. (These ..... Sharp LC-70LE650U 70-Inch Aquos TV TURNS ON WITH PERFECT PICTURE AND ..... It has thin horizontal lines on the top quarter of thescreen. ..... hey there, bought a 52lg60-ua had no image/picture but had sound.
? 2:01
https://www.youtube.com/watch?v=DedJvyNm_s4
Jan 28, 2016 | Sharp aquos 52 in lcd 1080p aquos 52...
When tv is powered on tv only displaying channel number and sound -no raster. using video mode displays are ok. sound is also ok
Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Dec 06, 2014 | Sharp Televison & Video
How to fix problem of jvc crt tv model av-21l31 power ok no video/audio no display with lines coming from flayback
Look at the horizontal output transistor then the fly back transformer.Check ALL the voltages coming from the power supply. One or more of them have to be missing for the audio and video to be gone at the same time.
Sep 24, 2014 | Televison & Video
Toshiba CZ32V61 no picture
1) you have problem with the Raster
2) the main causes are a) raster b) picture c) sound d) synch
3) since this are not video, the problem is raster. your must
test the voltage from section horizontal out +125vdc+vertical output +80v+all other circuit +12vdc
4) test the power supply for defective. see the diagram attached
Jul 12, 2012 | Toshiba CZ32V61 32" TV
Hi My toshiba CX36H60 has a problem -- no picture but sound is good. what could be the issue and how to rectify it. Please suggest.
As sound output is ok, main board is correct with respect to sound output, video IF and ther stages. The fault lies on the horizontal output section. It may be LOT fault. Check it further for horizontal oscillator stage, and horizontal output stage. Check the collector voltage at the horizontal driver transistor. If you have a frequency meter, check the frequency of that point. It should be somewhere near 15625Hz. If the frequency there is Ok, then proceed to horizontal output stage. Check the horizontal output transistor. If it seems to be faulty, replace it with similar type and number. If the replaced horizontal output transistor heats abnormally within seconds after swich on the set, surely LOT has troubel. Replace it also with same model mumber and type.
Oct 16, 2010 | Toshiba CX36H60 TV
Operating Manual for aToshiba CT-9371 remote or TV #CX2769J
press menu or red button ( NOT STANDBY ) find pic format( aspect ) and change screen size to match tv
Nov 07, 2009 | Toshiba Televison & Video
Toshiba TV -- horizontal line
sounds like you have feild colapse.take off the back and on the ciruit look for the horizontal and when you get it sue a screw driver and a mirror. put the mirror in front of the tv once you locate the horizontal plug the tv back on and look at the mirror and as soon as you turn the horizontal you will see the picture come back up to the correct size, if no good???? take it out and get a new one if you look on the side off the component you must get tthe same for safety, solder the new component in and try again
Apr 20, 2009 | Toshiba Televison & Video
Toshiba 27
you just say horizontal lines / and across a top of your television.I expect your trouble is the vertical line of your television . sound ok? try trouble the vertical section the check the resistor?
Apr 19, 2008 | Televison & Video
Toshiba 27A44 27" TV Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
